pin is out release arm but im stuck and not sure what to do about actually separating/removing the release bearing part??
any help much appreciated. thanks
cherry rallye daily (the money pit)
displaying posts 1 to 25 of 38
| Author | Subject: quick one gearbox question... |
chiefton
Seasoned Pro Location: cranleigh Registered: 09 Dec 2012 Posts: 1,195 Status: Offline |
right all bolts out everything all good pin is out release arm but im stuck and not sure what to do about actually separating/removing the release bearing part?? any help much appreciated. thanks ________________________________________ cherry rallye daily (the money pit) |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
Moved to correct section! Iirc if the pin is out the release arm, remove the arm then ease the box off, you may need to help the release arm round so the forks disengage from behind the release bearing fork then pull the box off! ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
But sometimes the fork is a cvnt to get off some heat may be required |
superchargedblack1997gti6
Yep it will be tight in there that clutch has not been changed for 40,000 miles mate? If that's out of my old black one mate?________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
jeffers
bigbadbowen wrote: But sometimes the fork is a cvnt to get off some heat may be required Where are you going to apply heat to Chris?? ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
Top of the arm ? Or just bend it up to allow the fork to rotate it round |
demondriverdan
bigbadbowen wrote: Top of the arm ? Or just bend it up to allow the fork to rotate it round Exactly what I did, much easier than trying to get the pin out. Once the box is off you can take the pin out if as you can spin the fork round and get the pin to an easy location. ________________________________________ Rallye Race Car |
chiefton
superchargedblack1997gti6 wrote: Yep it will be tight in there that clutch has not been changed for 40,000 miles mate? If that's out of my old black one mate? that engine yes mate. iv got it now sorted il post up pic of damage for viewing pleasure ![]() ________________________________________ cherry rallye daily (the money pit) |
Plenty of grease when putting it back together helps future removal |
You say a bit dropped down that hole?Looks like that definatly caused that damage. Seen a few threads on here where people have dropped things down that hole and was wonderjg what could happen : lol ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
chiefton
Well thats what I thought but looking in the first picture the missing bit is there on top of the box.im really not sure as to how this happened!!??? Cor what a b*stard the box is to get back in. Im sure the fork is through the bearing now so not much to do now. Is there a fill for the diff or will it fill when I fill up through the breather bit on top?? ________________________________________ cherry rallye daily (the money pit) |
Looks like whatever was flying around in the hell housing smashed the bell housing causing the leak and hit the bit in the first picture breaking that bit off, that's sat on the top ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
no, more likely to be the planet gears s**tting themselves and flying about through the diff casing bouncing off the flywheel up through the top/________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Or that lol________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
chiefton
Hmm I just cant find what caused it,,very strange unless it just smashed to bits whatever it was.alot of metal in there lol il be hopefully finished this evening....fingers crossed cus its lovely weather and iv got a t plate toyota avensis.....boring and very boatish lol ________________________________________ cherry rallye daily (the money pit) |
chiefton
I reckon it was a planet gear too theres nothing else I can see that wouldve done it!!________________________________________ cherry rallye daily (the money pit) |
if the pin is in the arm then you haven't got the forks behind the bearing.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Did you slide the for behind the thrust bearing when installing the box it's tricky to do ? If you had the fork facing the rad the it won't be right ? The fork needs to be facing the bearing cut outs so it slips in behind when the box goes on |
chiefton
so gear box back out??? yeah I didn't mean pointing to the rad but slighty over that way then as I jiggled the box I heard it pop in and believed it to be behind the cut out in bearing.. ________________________________________ cherry rallye daily (the money pit) |
Need a hand?________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
chiefton
superchargedblack1997gti6 wrote: Need a hand? I think iv gotta leave it till 2moz now missus wants to go home you see but round 2 tomorrow ding ding lol, I may give you a shout tho mate if your about?? ________________________________________ cherry rallye daily (the money pit) |
Yeah give me a shout took one out the other week. I'll try and give you a hand and get it done________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
chiefton
Sweet cheers fella il let you know ________________________________________ cherry rallye daily (the money pit) |
