displaying posts 1 to 25 of 42
Author Subject: oil pressure
Stillj20
Hi all,
I have a phase 1 gti 6, a lot of work gone into it, had to put another engine, timing belt, water pump, fully serviced the works and for the want of a better word, sounds s**te, bit like a tractor or sumtin even cut out the other day. My wuestion is, my mechanic reckons its the cylinder head, possibly the tappets and will be alot of money, the car is runnin constantly at around 7.5 / 8.0 bar oil pressure, could this cause the engine noise and the car to cut out,
Many thanks,
James
Posted 1st Apr 2014 at 22:12
Niall
Pressure should be about 80ish psi at cold idle dropping to 30-35psi hot idle and it should make 60psi at 4k.
Can you get a video?
Mine tapped its tits off until i warmed it up properly and then the tappets filled with oil and it was fine.
Posted 1st Apr 2014 at 22:18
Was the engine sourced from a good reliable source ? Who did the cam belt change ? Did you use a good bottom pulley that has not slipped to time up the engine ?
Posted 1st Apr 2014 at 22:23
Stillj20
Living in ireland and there wasn't an engine to be found, got it from england on ebay, sounded fine at first but gradually got worse, my mechanic is a1 and I would trust him to get quality parts, but then again I know feck all bout cars, so guess it comes down to trust in the end
Posted 1st Apr 2014 at 22:33
It's an easy mistake to make - ask him if he checked the bottom pulley and cams all lined up before the cam belt change ?
Posted 1st Apr 2014 at 22:40
Stillj20
She's constantly up around 8.0 bar no matter how warm she gets, and sounds awful the whole time.
Posted 1st Apr 2014 at 22:41
Stillj20
I'll ask him if everytin lined up, more than likely wouldn't be that simple
Posted 1st Apr 2014 at 23:03
Does it sound like a sewing machine?
  • Posted 1st Apr 2014 at 23:39
    Stillj20
    Hard to describe it mate, all I know its definitely not right.
    Posted 1st Apr 2014 at 23:49
    Stillj20
    How do u upload videos anyone
    Posted 3rd Apr 2014 at 16:59
    Easiest thing with videos is to put them on youtube or photobucket then post a link on here.
    Posted 3rd Apr 2014 at 17:13
    jeffers Forum Admin
    8 Bar is a lot of oil pressure..... And it Definately should drop once warmed up....
    Team Running Engine again!
    Team Negative Camber!
    Posted 3rd Apr 2014 at 19:15
    Stillj20
    Thanks, I uploaded it on you tube yesterday, still pending, ill post it and see what u think, sounds rough out.
    Posted 5th Apr 2014 at 10:48
    Stillj20
    Posted 5th Apr 2014 at 12:40
    Stillj20
    My great sounding engine
    Posted 5th Apr 2014 at 12:43
    Stillj20
    To add insult to injury, the car cut out again, barely got up to temperature and just gave up.
    Posted 5th Apr 2014 at 16:09
    Sounds like a tapper to me ? Or it's not bee timed correctly due to a slipped pulley
    Posted 5th Apr 2014 at 16:52
    honestly3k
    Sounds f**ked that's for sure.
    Sounds like bent valves but then when he rev's it, instead of increasing the tapping it kind of goes silent? Which is a bit odd.
    Posted 5th Apr 2014 at 17:00
    Niall
    Exactly what i thought. The initial tapping just sounds like very noisy injectors or a bad tappet or two but there is also a more dull tapping which sounds like a big end to me!
    Posted 5th Apr 2014 at 17:08
    jimmyhackers
    try some xado
    Posted 5th Apr 2014 at 17:51
    Stillj20
    Not good then so, worth fixing or scrap yard
    Posted 5th Apr 2014 at 19:08
    Where did you get it from ? I'd get the timing checked with a good pulley first but chances are its a bad engine ?
    Could also whip the sump off and get the bearings checked ?
    Posted 5th Apr 2014 at 19:31
    Stillj20
    Only place could find one was on ebay, took a chance. May just see what the verdict is when my mechanic has a look.
    Posted 5th Apr 2014 at 19:36
    I'd talk to the seller explain you had it installed by a proper mechanic - maybe get a proper written report and see if you can get your money back ? If you paid through eBay you can start a case against the seller as the item was not sold as described ? That is if it was described as fully working ?
    Posted 5th Apr 2014 at 20:28
    Niall
    This. Normally id just say that whoever has done the belt has cocked it up hence the tapping but its not quite a belt tap and even that wouldn't explain your high oil pressure.
    Are you sure the pressure gauge is wired in correctly? Pretty sure most top out at about 8 bar so are you sure its not just maxed out due to a wiring problem?
    Posted 5th Apr 2014 at 20:35
