displaying posts 26 to 42 of 42
Pages (2): 1 [2]
Author Subject: oil pressure
Stillj20
I'll check the wiring, probably the least of my worries, try c whats up with the engine, would the worst case scenario be that it needs a new cylinder head or would the bottom end be f**ked aswell
Posted 5th Apr 2014 at 21:13
Niall
Well people who have had belts snap and fitted a new head (if they can get away with it) normally never have any more troubles but i have heard a few rumours of bottom ends going a while after the belt snap. Why i don't know but there must be a relation there somewhere. If it turns out it is a tapper, id be tempted to have the pistons out whilst the head is off, fit new rings and new big and main bearings.
Posted 5th Apr 2014 at 21:32
Stillj20
Would be a good idea alrite, may just wait and see what my mechanic says the extent of the problems first
Posted 5th Apr 2014 at 21:58
What vehicle did the engin come from ? Later Gtis don't have have oil pres senders ? Ask your mechanic if he checked the timing before he changed the belt ? It's very easy to get it all wrong if the crank pulley is no good ? Or you rotate a cam in error to get it timed up ?
What cam belt kit did you use ? 136 or 137 tooth belt kit ?
Posted 5th Apr 2014 at 22:25
That isn't a valve 'tapper'.
It definitely has bottom end problems though. Yes
Posted 8th Apr 2014 at 00:17
Stillj20
Either way tappers, bent valves or bottom end, it's goon to cost a heap of money to fix, which I dont have, time to cut my losses I think
Posted 8th Apr 2014 at 15:58
Niall
May not be a huge amount. I had a big end go a few weeks back and caught it just in time to just need a very light polish on the crank and some new big ends. With oil and a filter, cost me £70. Of course you need to get the crank and rods checked as well.
Posted 8th Apr 2014 at 20:28
astor gray 2014
get another engine
Posted 8th Apr 2014 at 21:20
Stillj20
Engines not that easy to come by here, have to try find one online and take the risk its running good. Theres a lot to be said for seeing and hearing an engine rather than buying online.
Posted 8th Apr 2014 at 21:59
Stillj20
Post #35
I'll have to see what my mechanic says when he looks at it, £70 fix I would be delighted, doubtful though. Hard to trust my mechanic now 2 when he could have caused the problem in the first place with the timing
Posted 8th Apr 2014 at 22:03
astor gray 2014
Post #36
yeah fingers crossed for you let us know what happens either way
Posted 8th Apr 2014 at 22:04
Stillj20
Post #37
Will do mate
Posted 8th Apr 2014 at 23:52
Stillj20
Post #38
Looks like it's the tappets after all and get her timed up properly, hopefully will do the trick. Where would the best place be to get a set of tappets.
Posted 20th Apr 2014 at 19:50
astor gray 2014
Post #39
thats good to hear not too sure where you would get the tappets somebody here may have spare
Posted 22nd Apr 2014 at 15:01
rallyeash
Post #40
I'd be surprised if it was the tappets. Don't normally become a problem on these engines.
309 3dr K20 Type R
Posted 22nd Apr 2014 at 21:22
Post #41
I doubt that's the problem either
Posted 22nd Apr 2014 at 21:54
demondriverdan
Post #42
Sounds like big end if it's increasing with revs, same problem I had on the race car.
Rallye Race Car
Posted 22nd Apr 2014 at 21:56
Pages (2): 1 [2]
