displaying posts 1 to 25 of 37
Author Subject: Starter Motor Slow with Race Battery
demondriverdan
Ever since I fitted the race battery the car has struggled to start. Obviously this is kind of expected with a smaller battery but it does a really slow first rotation, then suddenly kicks in.
We were thinking it could be the starter motor on its way out?
Rallye Race Car
Posted 21st Mar 2014 at 12:10
try it with a jump pack.
could be headgasket.
Posted 21st Mar 2014 at 12:22
How long is the wiring and what gauge...
Posted 21st Mar 2014 at 12:51
demondriverdan
We've never had to use the jump pack as it has always started, just sometimes after 2 rotations.
Battery is behind passenger seat so approx 1.5m. of 170A
Rallye Race Car
Posted 21st Mar 2014 at 13:20
Hmm, should be good, what battery is it and what's the voltage drop look like when it's cranking?
Posted 21st Mar 2014 at 14:02
Castor_Troy
If you try it with a jump pack and it makes no diffrence it rules out the battery and points to other problemsThumbs up
Posted 21st Mar 2014 at 14:21
RetroPug
If the HG is going wouldn't you expect it to turn over at a normal speed but not fire due to the condensation?
This doesn't rule it out but the HG itself doesn't cause slow turning over on the starter motor does it?
Castor_Troy
Can do water doesnt compress
Posted 21st Mar 2014 at 14:51
demondriverdan
It's only done it since we changed the battery, before then it was absolutely fine so I don't think it's HG. Plus there's absolutely no mayo in the cap (although I know that isn't conclusive).
Rallye Race Car
Posted 21st Mar 2014 at 14:58
Mine cranks a bit slowly too on a race battery. Never bothered me though as it will always start, i like the fact it takes a second or two of cranking before it fires as it gives the oil pump half a chance to get some oil round the engine, that may just be my backwards logic though. LOL
Posted 21st Mar 2014 at 15:11
Cjwatson27
Bad earth maybe
Posted 21st Mar 2014 at 17:41
RetroPug
Really? It's normally a small seepage that stays in there as condensation isn't it?
If the cyclinder was physically full of water the HG wouldn't just be not sealing it'd be not there! Surely there'd be other symptoms before that stage?
I'm not saiyng you're wrong I'm just asking?
Posted 21st Mar 2014 at 19:04
jeffers Forum Admin
This sounds like a case of maybe bad earths, if the head gasket was bad enough to half fill cylinders with water you'd have other symptoms while it's running. I'd start by cleaning all the earths and go from there! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 21st Mar 2014 at 19:51
demondriverdan
I'll have a look at the earths. When we moved the battery we connected back up to the original earth by running a cable back, I wonder if the connection is not that great
Rallye Race Car
Posted 22nd Mar 2014 at 09:52
Just put the orginal earth to a good spot on the body and earth the battery to the body near where it's bolted in...
Posted 22nd Mar 2014 at 17:23
darkgti6
A new starter motor will help. I replaced mine recently, was 14 years old and covered 174k. The improvement was noticeable. It turns over a hell of a lot quicker and sounds healthier when cranking over compared to the old starter motor.
Team Peugeot Sport 308 Gti�
Posted 24th Mar 2014 at 20:35
Long skinny undersized battery cables on crap connections would be my guess.
Posted 24th Mar 2014 at 20:37
pete_rallye
Is the engine standard or higher compression? Mine was always fine with a standard engine but when I put my new engine in with higher compression it was sluggish, but then it did always start. I changed my starter for a diesel starter which was brilliant but I couldn't live with the additional weight so took it off again.
Lap of the 'ring
Posted 24th Mar 2014 at 20:53
Laugh my ass off
Posted 24th Mar 2014 at 21:05
dcc
Sometimes before you post, read what you've written before pressing submit.
+1 for the lols
205 GTI
Xsara HDI
Posted 24th Mar 2014 at 21:08
demondriverdan
Like I say, probably 1.5m of 170A cable to shouldn't be too bad.
Think it might just be the battery is tired, started 100% with the jumper on it. Possibly not getting charged enough by the alternator
Rallye Race Car
Posted 24th Mar 2014 at 21:50
Earth the battery to the body near where it is now located ?
Posted 24th Mar 2014 at 22:02
It's 3 metres if you've took the earth back forwards LOL:
Posted 24th Mar 2014 at 22:49
demondriverdan
Didn't think it would make that big of a difference but can try.
Rallye Race Car
Posted 24th Mar 2014 at 22:52
rallyeash
Have you earthed the battery locally? My earth is only 12 inches long from my battery in the boot
309 3dr K20 Type R
Posted 24th Mar 2014 at 23:00
