Author Subject: Gti6 engine swap
Cjwatson27
Hi i got my 306 back tonight with the gti6 engine fitted , i fitted some cams i brough from rich6 it now seems to be quite lumpy on idle and the engine sounds abit tappy . Is this something that will settle down the garage said it will take awhile for the hydraulic tappits to settle , I'm only really used to working on a series engines and I would say its timings out but the garage have said its correct thyve gone from the orginal timing marks is this right ? Dunno
Cheers Chris
Posted 31st Jan 2014 at 18:25
luke306rallye
What cams went in?
Posted 31st Jan 2014 at 18:30
Cjwatson27
SOLD
Set of non standard cams.
Base dia is approx 37.75mm
Base + lift is 48.85mm
Lift: 11.1 mm not sure of the make, a couple of symbols on them but not a manufacturers mark.
but they dont seem to be standard which have 10mm lift if im correct.
I had them in my 6 when I got it. It made good power through the rev range that didnt drop off in the higher revs.
Posted 31st Jan 2014 at 18:34
Cjwatson27
These mate
Posted 31st Jan 2014 at 18:35
jamiek_uk2000
Lairy cams will make an engine run lumpy on idle, though they can't be too lairy as I assume you've not had any piston work? The tapping is something I'm not sure about
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 31st Jan 2014 at 18:42
luke306rallye
If welshpug wasn't banned I'm sure he'd have an answer.
Has the head been skimmed at all?
Posted 31st Jan 2014 at 18:54
Cjwatson27
I don't know the history of the car i brought it and crashed it the same day then left it in a barn for 3 years till i reshelled it recently , so it's all new to me at the moment it didn't seem to noticeably tap when we started it before the cam swap , the garage mentioned something about exploded followers and they settle eventually ? He seem confident on this
Posted 31st Jan 2014 at 19:00
Cjwatson27
Ohh the lad i brought it from said he'd replaced the head gasket so i presume it's been skimmed and i haven't had any piston work done
Posted 31st Jan 2014 at 19:02
Tap or a tick?
  • Posted 31st Jan 2014 at 19:38
    Cjwatson27
    Now you mention it I'd say a light tapping/ a bit like a ticking noise it's defiantly from the cam covers
    Posted 31st Jan 2014 at 19:40
    Marcdimma
    I had a similar noise
    I took off cam covers and pushed down on each tappet they were all solid apart from 1 replaced it and tapping has gone
    Posted 31st Jan 2014 at 21:11
    eddy_gti6
    Tapping noise will be your tappets, should settle down once the oil has warmed up and circulated around the head property and filled up the tappets. It will be lumpy if you have just fitted the cams and not had a remap. Your air/fuel will be all messed up.
    Posted 31st Jan 2014 at 21:23
    I suspect the tapping noise may well be from the tappets which need time to settle, however prepare yourself for the fact that the garage might not have fitted the cams correctly and could have bent a couple of valves during fitting. Sad
    Let's just hope it quietens down with running first. Yes
    Posted 31st Jan 2014 at 21:36
    Did they check / use the crank pulley to time up the engine ?
    Should always time a 6 engine with a new or solid pulley
    Posted 31st Jan 2014 at 22:00
    I suspect timing issue so do not use the car until you have checked with a good pulley ?
    Tappets shut up pretty quickly after they have filled with oil
    Posted 31st Jan 2014 at 22:03
    Cjwatson27
    Ok he does a lot of engine work he said he timed the cams up from marking off the orginal cams , and turned the engine over twice by hand to check the cams and rechecked them when it first started up after it was quite loud , I'm just wondering if they should be timed the same has normal or weather there timed differently ? How long does it take for the tappets to fill up ive done about 10 miles in it , its a lot quieter now than it was when it first started
    Thanks for the help
    Posted 31st Jan 2014 at 22:31
    scotzman
    If it's getting quieter hopefully you should be ok.
    Posted 31st Jan 2014 at 22:35
    Cjwatson27
    This will probably be anyone one got a new engine thread by next week lol
    Posted 31st Jan 2014 at 22:39
    miles
    You need to time the cams up properly not off std markings, But then you may have piston to valve issues, Pain with these engines unless you do a dry build
    www.pugracing.com
    Posted 31st Jan 2014 at 22:59
    Cjwatson27
    Thanks miles Is there anyway of timing them correctly with the engine in ?
    Posted 1st Feb 2014 at 08:44
    aaron6
    After 10 miles they should be fully pressurised and stop tapping. I have a lazy lifter in mine, sometimes taps for upto 5 mins but goes away completely. There is definitely a good chance of a couple of bent valves.
    Posted 1st Feb 2014 at 09:44
    Cjwatson27
    I knew when I drove it into that puddle/pond i should of left it there , Peugeots are so ungrateful
    Posted 1st Feb 2014 at 09:49
    allanallen
    Looking at the max lift I doubt you could time those cams in properly on a standard engine anyway. If they have been fitted like normal cams and set to the standard timing pins I'd say there's a strong chance you've had some valve/piston interference Sad
    Easiest way to set is by checking and adjusting the lift at TDC, as a rule on an unskimmed head you can get away with 1.4mm of lift a TDC. Anymore and you're treading on thin ice! Obviously of the heads skimmed etc you need to reduce this accordingly.
    There's bugger all room for aftermarket cams in gti6 engines and the valves stems are made of celery!
    Facebook
    Posted 1st Feb 2014 at 12:30
    Cjwatson27
    It does go well and the hesitation i think is down to the clutch but the fact it sounds like sewing machine still has me worried , if it had bent valves wouldn't it misfire ? ,
    Posted 1st Feb 2014 at 17:01
    Cjwatson27
    I might pull this apart again, can you get standard pistons pocketed ?
    Posted 2nd Feb 2014 at 18:48
