displaying posts 51 to 75 of 105
Pages (5): first .. 2 [3] 4 .. last
Author Subject: swirl pot setup
allanallen
Posted 29th Jan 2014 at 20:18
clen666
Post #52
Allan, Did you make your whole tank or purchase it from somewhere?
Team 'unintentional rat look'
Posted 29th Jan 2014 at 20:22
pete-gti
Post #53
pugheaven wrote:
At the end of the plastic lines they get a lot more harder where the original clip on connectors are, just cut the line going into the original filter a few inches away and push the new rubber hose all the way upto the connector and use a small worm drive clamp as close as you can to the connector, job done, no need for aftermarket parts
Alright I see what you mate possible way off doing it, Smile , when it leaves the filter your be left with original line going fuel rail?
Posted 29th Jan 2014 at 20:34
pugheaven
Post #54
Yep that's how the supercharged cars have done it, or at least my ones anyway, I'm using the 2 standard fittings on the pump with my braided line pushed over the existing connectors to feed my swirl pot and return from the swirl pot
Posted 29th Jan 2014 at 20:47
pete-gti
Post #55
Got you mate :-). All clear, that's what I'm going do
Posted 29th Jan 2014 at 20:57
pete-gti
Post #56
Right and the original fuel return going to the standard pump gets routed to swirl pot yea? So just need to extend it where it use to join top of pump ?
Posted 29th Jan 2014 at 21:02
pugheaven
Post #57
Yep you got it mate it goes to the second one down on the pot
Posted 29th Jan 2014 at 21:15
pete-gti
Post #58
Cheers mate right got my head round it all now, sweet :-)
Posted 29th Jan 2014 at 21:28
pete-gti
Post #59
This correct way to wire up pump, ? switch from the OE pump is the blue wire yea?
Posted 29th Jan 2014 at 22:11
Post #60
I Like that
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 29th Jan 2014 at 22:38
allanallen
Post #61
I did it 'pre bridgecraft'. I designed and made the bits for it but someone welded it up for me. It works brilliantly, never surges and completely empties itself Smile Between me and Martin we can make them thoughWink
Currently making a box for it to sit in so it meets msa regs.
Facebook
Posted 30th Jan 2014 at 01:10
clen666
Post #62
It looks ideal, I've been looking for a decent tank with integrated swirl pot Smile
Posted 30th Jan 2014 at 01:55
pete-gti
Post #63
If I use a filter before the swirl pot , it be OK get rid of the standard filter ?, so after the HP pump it will just go straight to the rail as standard filter be removed, that be OK want it?
Posted 30th Jan 2014 at 19:55
allanallen
Post #64
Ideally I'd put the filter in between the swirl pot and the hi pressure pump
Facebook
Posted 30th Jan 2014 at 20:05
pete-gti
Post #65
Yea :-) I make you right there, makes better sense
Posted 30th Jan 2014 at 20:17
rallyeash
Post #66
Daveyboy,
whats the score with venting the tank on yours? cant see an outlet for vent
309 3dr K20 Type R
Posted 5th Feb 2014 at 12:29
Post #67
I've got to put one in myself.
Posted 7th Feb 2014 at 09:51
russbez
Post #68
as per my thread that is the way i done it
My Rallye project thread
Posted 7th Feb 2014 at 10:10
pete-gti
Post #69
Pretty much have this all setup, I'm running low boost, I have some quick connects so can join into the original fuel filter,would it be ok to run it see if it works?; or will it do harm?
Posted 7th Feb 2014 at 10:16
pete-gti
Post #70
Posted 8th Feb 2014 at 19:19
Post #71
Can't see any reason why it would do harm, unless there's something missing from what you described
Posted 8th Feb 2014 at 19:31
pugheaven
Post #72
Let the swirl pot fill up first and then connect the uprated pump after that.
Also disconnect the lines at the rail and allow the fuel to become a constant flow before connecting to the rail, this will help bleed the fuel line and give the pump some fluid rather than it pump dry for a bit
Posted 8th Feb 2014 at 19:35
pete-gti
Post #73
OK nice one Smile, job tomorrow
Posted 8th Feb 2014 at 20:54
pete-gti
Post #74
When I got time I'll make a thread guide on this with pictures
Posted 8th Feb 2014 at 20:55
pete-gti
Post #75
Here's a quick picture when I started laying it out, in the week I will make full guide showing all connections etc, need to upload quite few pictures, I had it running earlyer seem fine:-) so well happy
Posted 9th Feb 2014 at 17:52
