displaying posts 76 to 100 of 105
Pages (5): first .. 3 [4] 5
Author Subject: swirl pot setup
jorg
Post #76
just spent the weekend mocking my setup under the boot floor
will hopefully have it all plumbed in on thursday
306 2.1 S16 Tarmac Rally Car
Posted 9th Feb 2014 at 17:54
Post #77
Looking forward to seeing this, I think I'm going to get some proper threaded ends welds onto my swirl pot and fuel rail
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 9th Feb 2014 at 17:57
pete-gti
Post #78
Get some nice pictures of plumbing it all in, nice to see how other people do it:-)
Posted 9th Feb 2014 at 17:58
pete-gti
Post #79
pete-gti wrote:
Here's a quick picture when I started laying it out, in the week I will make full guide showing all connections etc, need to upload quite few pictures, I had it running earlyer seem fine:-) so well happy
I went with filter before feeding into swirl pot, then from pump into ooriginal fuel filter ,
Posted 9th Feb 2014 at 18:00
pete-gti
Post #80
Nearly made full guide on this once I've got my camera cable back :-)
Anyway these are the connections I'm using on the original fuel pump and filter
Fit bang on
Posted 16th Feb 2014 at 19:33
craig903
Post #81
can't help but think to my self that only half of the swirl pot is actually used?
208 GTI Owner
Posted 16th Feb 2014 at 19:47
Post #82
I suspect the pickup tube has a 90 degree bend so that it picks up from the bottom.
Posted 16th Feb 2014 at 19:55
pete-gti
Post #83
Is that a rich w swirl pot?
Posted 16th Feb 2014 at 20:41
jorg
Post #84
the swirl pot i'm using is a rich w one yes Yes
Posted 16th Feb 2014 at 21:26
clen666
Post #85
I've been told the pickup does run to the bottom internally, as I asked the same question when I looked at it Smile
Team 'unintentional rat look'
Posted 17th Feb 2014 at 02:44
pete-gti
Post #86
How much was rich w swirl pot?, I've fitted mine inside car just for the fact I wouldn't of been happy with all that fuel stuff hanging under my car , just me being silly lol, mine was 100 pound
Time you got connections , hoses , filter , pump, about 400 just on the new system
Where best place to get 4 bar pressure regulator?
Posted 17th Feb 2014 at 17:11
rich_w
Post #87
On my swirl pots the pick-up tube goes right to the bottom.
It also has a baffle welded onto the pick-up tube - which is pressed out of a circular piece of stainless steel, into a lamp-shade profile.
This is used to deflect any bubbles (that may be pumped into the swirl pot via the in-tank pump for example) away from the pick-up location.
Cool
Contact Details:
07732 822546
Posted 18th Feb 2014 at 09:49
rallyestyle
Post #88
They are made of stainless steel buddy. More chance of something puncturing the fuel tank than getting through one of Rich's swirl pots Yes They are rather beautifully made too, bit of a shame to put it under the car Doh
Just Drive It
Posted 18th Feb 2014 at 10:19
pete-gti
Post #89
Where mine is inside I had to go for different type so couldn't get one of rich w ones
Yea right just in my head would always be thinking hope nothing hits etc, just for my peace on mind I've fitted it inside, its all up and running:-) , guide with good pictures be up soon
Posted 18th Feb 2014 at 18:23
pete-gti
Post #90
Here are a few pics of my setup :-)
I went for :
Alloy fuel swirl pot nm-6 inlets and nm-8 outlet
Nm-6 hose and short piece of nm-8 hose
Fittings
Bosch 044 fuel pump
Sytec f1 bullet fuel filter
I used these fittings to join the return from the swirl pot back to the tank same fitting used on the feed from the tank
The same fitting will join onto the original fuel filter
From the Bosch pump I routed it threw the hole that was used for the spare wheel, then to the original fuel filter
From the original fuel return line I used this connection to join into it then back to the swirl pot
This is how it will look , but I'm going to extend the fuel return line to the swirl pot so I can run t round by the other two hoses
Later on I'll show how I wired the pump up
Posted 22nd Feb 2014 at 16:30
rallyeash
Post #91
Is that PTFE lined braided? If not it'll smell of fuel
309 3dr K20 Type R
Posted 22nd Feb 2014 at 16:20
pete-gti
Post #92
No its not, I havnt really noticed a smell badly?, maybe just smell it but nothing really, you really have got to get these connections right other why's it will smell
Posted 22nd Feb 2014 at 16:33
Post #93
Awesome work but have you used a grommet where it passes through the spare wheel hole?
if not I'd suggest using a grommet to stop it rubbing thru over time on the thin bare metal or getting cut in 2 if somebody rear ends the car hard.
You may have to drill the hole out bigger to fit a grommet in there looking at it.
Posted 22nd Feb 2014 at 17:16
pete-gti
Post #94
Yea I will use a grommet or something like that:-)
Posted 22nd Feb 2014 at 17:35
pete-gti
Post #95
Where best place to buy a 4 bar fuel regulator , I dont want buy cheap one on eBay,
Posted 24th Feb 2014 at 17:49
Post #96
It will smell, the petrol vapour permeates the rubber hose and lets out the petrol smell sooner or later, it's not leaks from the connections you need to worry about. They normally put a disclaimer on the box or in the sales ad, saying not suitable for use inside the cabin if it's the non PTFE stuff.
Posted 24th Feb 2014 at 19:28
pete-gti
Post #97
See how it goes :-) I've seen few setups like this with this type hose in cab, things get to bad I will just have to change it Thumbs up
Posted 24th Feb 2014 at 20:35
pete-gti
Post #98
Can some one help me with the Bosch part number for the 4 bar fuel regulator?
Posted 26th Feb 2014 at 18:35
pete-gti
Post #99
Decided now to go with the Teflon stainless braided fuel hose inside car , if I'm going to it proberly might aswell do propa job, if you going to do it do it right:-) , so Teflon hose and fittings turned up today so will change that over weekend
The hose that I did use to start with I'm going to use to replace the original fuel line from rail back to tank , so the whole system will be braided:-) just need to weld some fitting onto the fuel rail connections
Posted 5th Mar 2014 at 20:02
clen666
Post #100
Did you find a 4 bar regulator? I have one if you need it
Posted 5th Mar 2014 at 23:34
