displaying posts 26 to 50 of 105
Pages (5): 1 [2] 3 .. last
Author Subject: swirl pot setup
I did yeah, I could've gone an inch or so lower but I didn't want the tank to be the lowest point on the underside of the car.
Posted 29th Jan 2014 at 13:22
Manufactured by Daveyboy upside down under floor Group N swirl pot group buy?
  • Posted 29th Jan 2014 at 13:26
    You'd all die of old age by the time I got around to making one...
    Posted 29th Jan 2014 at 13:28
    pete-gti
    So what's best way to join the new line to the original line? Going to the fuel rail, anyone got any pictures of this?
    Posted 29th Jan 2014 at 13:40
    pete-gti
    Posted 29th Jan 2014 at 13:48
    I've seen people braze AN fittings to the fuel rail.
  • Posted 29th Jan 2014 at 13:51
    I've tig welded -6 fittings onto fuel rails for a few people now. I prefer them off the car and drained of fuel first though as I'm a wuss.
    Posted 29th Jan 2014 at 13:55
    pete-gti
    I mean I've seen some pictures where fuel lines under bonnet have been kept the same, so they must of joined it into the original line back towards the tank some where?
    Posted 29th Jan 2014 at 14:05
    Could try something like this?
    http://www.ebay.co.uk/itm/6-AN6-STRAIGHT-Push-On-Fuel-Hose-Fitting-/380678996059?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item58a23c805b
    Posted 29th Jan 2014 at 14:12
    rallyeash
    Post #35
    does make some extra space! what did you do about filler neck? just fill from the inside?
    also where did you get it all from?
    309 3dr K20 Type R
    Posted 29th Jan 2014 at 14:25
    pete-gti
    Post #36
    That looks good fitting to join to original line :-)
    Posted 29th Jan 2014 at 15:44
    Post #37
    LOL
    andrew315rawson@live.co.uk
    Moonstone phase 7 gti6
    Posted 29th Jan 2014 at 15:39
    Post #38
    No, I planned to run a filler to a bracket bolted on the rear of the cage with a connecting pipe so I don't have to lean into the car and try and tip a heavy fuel churn. I got all the gear from Rally Design, the tanks come from the States though and can take a while if it's not a common size.
    Posted 29th Jan 2014 at 15:55
    mcvite
    Post #39
    Excellent work from you again jim,well done keep it up Thumbs up
    http://s1160.photobucket.com/albums/q486/mcvite/
    Posted 29th Jan 2014 at 16:15
    Post #40
    It's actually not exactly right. That fir tree fitting is designed for a different type of hose that doesn't use a crimp and would be likely to split if you used it on the plastic fuel hoses that come with the car. But you need something along those lines.
    Posted 29th Jan 2014 at 16:38
    Post #41
    Ta Love
    Posted 29th Jan 2014 at 16:42
    rallyestyle
    Post #42
    Gonna do a project 'pump' thread Pete?
    Just Drive It
    Posted 29th Jan 2014 at 16:44
    pete-gti
    Post #43
    Yea I will do mate, when I'm fitting it, step by step, hardly any good information on setting this system up on these cars,
    Yea something along those lines Dave, fuel line under the car is rubber yea?, that would fit over the barbed nipple, then your braided hose and an-8 fitting would fit on end of it, so that is kind of the right setup
    Posted 29th Jan 2014 at 17:06
    Post #44
    The fuel lines under the car are a form of thin wall hard plastic. Being 10+ years old they may not take kindly to having a hose barb of the type I linked to shoved in them. You'd be best talking to Austin at Torques UK directly and seeing what he recommends. I'm sure he will have a neat solution among the hundreds of product lines he sells.
    Posted 29th Jan 2014 at 17:53
    rallyestyle
    Post #45
    Good man, look forward to the read Thumbs up
    Just Drive It
    Posted 29th Jan 2014 at 18:13
    pete-gti
    Post #46
    Yea will have a word with torques see what they say, worse comes I'll have to run complete new lines to the fuel rail
    Posted 29th Jan 2014 at 18:30
    rallyeash
    Post #47
    Torques are spot on for the stuff. Got all of my gear from there. Prices are right too!
    309 3dr K20 Type R
    Posted 29th Jan 2014 at 18:32
    rallyeash
    Post #48
    Daveyboy,
    what did you do about supplying fuel to a swirl pot?
    my standard fuel pump lifts to the swirl pot then the from there the Bosch 044 takes care of the job
    309 3dr K20 Type R
    Posted 29th Jan 2014 at 18:39
    pugheaven
    Post #49
    At the end of the plastic lines they get a lot more harder where the original clip on connectors are, just cut the line going into the original filter a few inches away and push the new rubber hose all the way upto the connector and use a small worm drive clamp as close as you can to the connector, job done, no need for aftermarket parts
    Posted 29th Jan 2014 at 18:52
    Post #50
    rallyeash wrote:
    Daveyboy,
    I've got a Facet low pressure high volume red top lift pump to pull fuel from the tank and feed the swirl pot.
    Posted 29th Jan 2014 at 20:05
