displaying posts 26 to 48 of 48
Pages (2): 1 [2]
Author Subject: ceramic coating cost
oldbrownshoe
i'll write it again: "expensive procedure for ordinary mild steel",
meaning it's not financially wise to protect a hillbilly shack with top class anti theft system.
That's how you should read it anyhow .
French military victories?
Did you mean French military defeats?
Posted 22nd May 2014 at 11:05
rallyestyle
It's expensive yes but it does the job best.
Creating a intricate carbon fibre front wing for an F1 car is an expensive procedure for something that’s likely to shatter when clipping another car, it does the job best though.
Just Drive It
Posted 22nd May 2014 at 11:19
oldbrownshoe
F1 car is also the spear head of mega million business,
306GTi-6 is Not.
Posted 22nd May 2014 at 11:29
pugheaven
But a 450 odd hp 306 produces a lot of heat and also sets fire to your engine bay so ceramic coating helps prevent this!
Iirc gti6 manifolds are stainless steel
Posted 22nd May 2014 at 11:40
Niall
You don't seem to get the point brownshoe. It's not about protecting the manifold. If it was, it wouldn't be financially viable. It's about keeping engine bay temps down.
Posted 22nd May 2014 at 12:05
oldbrownshoe
I think that you don't seem to get my point,
i know about ceramic coating and plasma spraying process from 1983,
i don't have any doubt about it's efficiency in isolation,
i just question how wise is to implement it on material prone to corrosion like mild steel.
Posted 22nd May 2014 at 12:44
pugheaven
What is mild steel? And what point are you trying to get across?
Posted 22nd May 2014 at 14:56
306GTi-6 is Not.
LOL
Posted 22nd May 2014 at 14:48
oldbrownshoe
pugheaven wrote:
What is mild steel?
I guess this is good example
That expensive coating is justified when it's done on a long lasting materials.
Posted 22nd May 2014 at 15:39
Post #35
that is not mild steel, its low grade stainless.
Posted 22nd May 2014 at 15:41
oldbrownshoe
Post #36
Bad guess.
so it's finally will corrode ?
Posted 22nd May 2014 at 15:48
Post #37
That's pretty damned cheap, got a quote for almost a grand for the buggy's exhaust Doh
Posted 22nd May 2014 at 15:59
pugheaven
Post #38
Well some exhaust manifolds are at least 17 years old and iv never heard of one corroding......
Just to make it clear ceramic coating is not to stop corrosion it's to lower engine bay temps!
If you don't have the money to "waste" on getting it done don't worry about it but I myself decided that it was worth while getting it done
Posted 22nd May 2014 at 16:03
oldbrownshoe
Post #39
Posted 22nd May 2014 at 16:50
Niall
Post #40
oldbrownshoe wrote:
Bad guess.
Well they are all at least 12 years old now and I've not seen any that have corroded away yet so i would say that it corroding in any of our ownership of our cars (except Stans which will rot before his eyes in his garage over a 30 year period) is not a problem.
Posted 22nd May 2014 at 19:52
fatlapit
Post #41
It will prevent corrosion and keeps engine bay temps down. The materialls are fully cleaned before the coating is applyed. Its awesome stuff until ure manifold cracks then you have to put it in the bin.
Posted 22nd May 2014 at 20:23
oldbrownshoe
Post #42
When i wrote "expensive" i didn't mean that i can't afford it, just in relation to manifold worth.
Posted 23rd May 2014 at 06:09
aaron6
Post #43
What exactly is the material. You say low grade stainless, but that looks very mild. Is it something like 4003 or something?
Posted 23rd May 2014 at 19:43
fatlapit
Post #44
Gti6 manifold is 304 stainless
Posted 23rd May 2014 at 20:43
aaron6
Post #45
Thats a proper stainless. Not a hybrid. Only real difference worth noting is isnt very resiliant to salt. When we build baf tanks and other vessel's we normally use 304. If its going to get salt or more aggressive chemicals ran through it then we use 316.
Must only look like mild due to getting so hot then.
Posted 27th May 2014 at 09:16
jamiek_uk2000
Post #46
Its also what they use to make commercial kitchen eqipment. Proper stainless
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 28th May 2014 at 13:31
oldbrownshoe
Post #47
316 is also 6-7 times more expensive than 304.
Posted 28th May 2014 at 15:34
russbez
Post #48
learn something new every day
My Rallye project thread
Posted 28th May 2014 at 17:14
Pages (2): 1 [2]
