displaying posts 376 to 400 of 434
Pages (18): first .. 15 [16] 17 .. last
Author Subject: Eddy's VLR + Omex 600
eddy_gti6
Post #376
Thanks. Yeah always good to have something different Big grin
Posted 30th May 2014 at 17:57
eddy_gti6
Post #377
More problems today Sad give the car a wash and took it out for a drive and 1 of the pipes off the head on my maniflow has snapped! Going to pull it off and weld it up tomorrow so hopefully should be ok. Got a little more wiring ro tidy up too.
Posted 31st May 2014 at 15:48
fatlapit
Post #378
Can u not put the omex sumwhere??
Posted 31st May 2014 at 16:20
eddy_gti6
Post #379
I want it moved from there but dont know where to put it? Not really the best place for it there as in the winter it will get covered in water and crap. Was thinking of putting it in the standard ecu box and bolt it to the chassis leg. Need to order some ducting hose for the throttle body too as I dont like it open where it is.
Posted 31st May 2014 at 16:54
Post #380
Blimey .!!!!.....Now that's what I call shoehorning in ....
Great work Eddy Thumbs up
Posted 31st May 2014 at 17:04
eddy_gti6
Post #381
Been trying to find a BTCC header tank but nothing about. Managed to get measurements to have one made up tho Big grin definitely gets some looks with the sound it makes now Cool
Posted 31st May 2014 at 17:09
Post #382
eddy_gti6 wrote:
Well all that chopping was a total wast of time Laugh my ass off PAS relocation kit arrived today. Totally different setup to what i was expecting. Looks like I could have 2 options on what pump to run? Standard gti6 pump with smaller pulley and auto tensioner or the bigger MI16 (I think) Pulley with manual tensioner.
http://s1259.photobucket.com/user/eddy-gti6/media/20140221_234726_zpsa31935df.jpg.html
I'm sure someone will beat you to it ....what's the new mount from ...I cut mine down ...the other looks much better Thumbs up
Posted 31st May 2014 at 18:47
eddy_gti6
Post #383
Its a 2.0l 16v XSI setup IIRC
Posted 31st May 2014 at 19:30
rallyeash
Post #384
Move the ecu, the vibrations will cause it problems after a while. Mount it inside in the passengers glovebox or down that way
309 3dr K20 Type R
Posted 31st May 2014 at 19:56
eddy_gti6
Post #385
What was what I wanted at 1st but dont think loom is long enough.
Posted 31st May 2014 at 20:11
Post #386
Thanks Thumbs up
Posted 31st May 2014 at 20:17
eddy_gti6
Post #387
Had abit of an issue yesterday. I thought my manifold had just cam apart so went to put it back together today to find 1 of the pipes off the bead had snapped! Sad time to get the welder out. Pulled all the heat wrap off at the same time as it was a bit tatty and worse for wear. All welded up and sounds a lot better than before. Must have been ready to go by the look of it tho. Also found a talbot grill sticker I bought when I had the 205 so what the hell, that went on too Big grin
Posted 1st Jun 2014 at 19:27
ozonehostile
Post #388
Haha that Talbot sport sticker. Looks good though :-)
What are you btcc header tanks like btw?
Current Peugeot stable:
'99 306 gti6
'02 306 hdi estate
'97 306 Dturbo
'94 106 rallye 16v
Posted 2nd Jun 2014 at 10:55
eddy_gti6
Post #389
There alloy ones what sit on the chassis leg in place of the PAS bottle. Will be replacing my PAS for an electric one at some point so will have some room.
Posted 2nd Jun 2014 at 15:18
Post #390
The electric pas pumps weigh a ton Chris, i couldnt believe the weight of the one i got!
I'm currently without pas on a ph1 xsara rack with loads of caster, trying to park is hilarious - much like the golf caddy thing in austin powers Laugh
Posted 2nd Jun 2014 at 18:18
eddy_gti6
Post #391
Laugh my ass off I can imagine. I just want rid of the PAS bottle off the chassis leg. Is it really that heavy? Could always look into moving the PAS bottle instead if it comes to it
Posted 2nd Jun 2014 at 18:39
Post #392
Yes I thought i'd be clever and get an epas setup but instantly binned that idea when it arrived in the post and felt the weight of it. If i get chance tomorrow i'll weigh mine and put it on here, guessing its around 10kg. I may have to fit it in the future though once i get a proper diff. Sad
Posted 2nd Jun 2014 at 21:01
demondriverdan
Post #393
Or hit the gym? :p
I'm not looking forward to seeing how the race car is without PAS and a diff on sticky tyres!
Rallye Race Car
Posted 2nd Jun 2014 at 21:04
eddy_gti6
Post #394
Drove my mates 205 GTi6 with A048s on and wasnt too bad really but I use my car daily and like a lighter steering wheel LOL
Been onto allanallen to see about having an alloy header tank made up so if I can get one sorted then EPAS it will be.
Posted 2nd Jun 2014 at 21:17
Post #395
demondriverdan wrote:
Or hit the gym? :p
PMSL ...I've got PAS & 2.4 rack with 3j LSD & sticky tyres ...today I used it all & it felt much harder to turn than normal but I could feel the road better ....all the best with no PAS Thumbs up
Posted 2nd Jun 2014 at 21:24
eddy_gti6
Post #396
I dont really intend to run sticky tyres at this moment in time either so should be of. Sticky tires are too expensive and dont last long on everyday cars as I found out when I bought some a048s when I had the v6
Posted 2nd Jun 2014 at 21:52
ozonehostile
Post #397
Regards to your problem of lack of ecu protection, I think someone suggested it before somewhere, but one of those electrical housing boxes from rs components would be ideal. Ip rated to withstand the elements and it could all be mounted nice and securely inside.
You could even paint the box yellow or something haha
'99 306 gti6
'02 306 hdi estate
'97 306 Dturbo
'94 106 rallye 16v
Posted 3rd Jun 2014 at 14:13
eddy_gti6
Post #398
Yeah maplin do elecreical boxes would offer the protection it needs for next to nothing. Want something thays going to look tidy in the engune bay if I cant mount tge ecu inside the car. Black would be best instead of yellow tho LOL
Posted 3rd Jun 2014 at 15:15
allanallen
Post #399
Your arms need re-calibrating Steve! Razz
They're not light but you can fit them anywhere you like
Facebook
Posted 3rd Jun 2014 at 19:16
eddy_gti6
Post #400
Are they too noisy to fit inside the car behind the dash or not?
Posted 3rd Jun 2014 at 19:33
