displaying posts 301 to 325 of 434
Pages (18): first .. 12 [13] 14 .. last
Author Subject: Eddy's VLR + Omex 600
jimmyrallye
Post #301
Good luck mate can't fault your work effort in any way , you might be cutting it fine tho with the mapping as your bound to have some teething problems looking at the state of your engine at tho mo
Posted 17th May 2014 at 08:15
Post #302
Keep at it mate Thumbs up
Posted 17th May 2014 at 08:42
eddy_gti6
Post #303
We still have 2 days yet. Engine only really looks a state with the wiring all over at the minute but that will be tidied up today. On my way back down to jims no to make a start on whats left to do. Not really that much when I think about it. Will update again once I am home.
Thanks lads Thumbs up will update at the end of the day again.
Posted 17th May 2014 at 09:21
Post #304
Tidying can come later. Function over form etc.
Posted 17th May 2014 at 10:09
jimmyrallye
Post #305
Go eddy go Smile
Posted 17th May 2014 at 13:37
eddy_gti6
Post #306
Next update. Got quite a bit more done today. Keep things short as I cant be arsed to write step by step info again LOL
Jim finished off all the wiring and tidied it all up while I cut the slam panel to bits so we could fabricate a something new. Cut some new end plates and had weld it all up, I ground the welds down to tidy it up then we welded a straight bar in place to strengthen it back up. Welded 2 brackets on for the rad and 1 in the middle for the grill.
Next job was to fit the 205 cooling system. A lot of hunting about to find pipes to fit ect. I made up a new bracket for the header tank too. A lot of fiddling about today but not too far away now. Will be back down tomorrow afternoon to hopefully finish it off ready for mapping monday. Didnt get many pics today but will get plenty more tomorrow.
Posted 18th May 2014 at 00:28
tvrfan007
Post #307
Messy workshop lol. Interesting approach this, never come across a vlr inlet... What is it off?
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 18th May 2014 at 06:49
Post #308
A touring car, I guess the 406?
Posted 18th May 2014 at 08:02
Post #309
Yup, hence not fitting in a 306 LOL
Posted 18th May 2014 at 09:17
eddy_gti6
Post #310
Yes its off a 406, tried finding pics of the old touring car engine bays and cant seem to find any then came accross this while watching touring car legends at the start of this years BTCC season.
Work shop isnt too bad now, swept it out yesterday. Its with the road outside being gravel and all the dust blowing in the door.
think im going to cancel mapping for tomorrow and run the cooling system for a week just to make sure its all ok. Dont want the car over heating during mapping and f**king the engine. Going to see if the vlr will run on the mapped gti6 ecu too. I have the map sensor in the vlr, and all other sensors still in the TB for the time being so will just see what happens today.
Posted 18th May 2014 at 13:15
tvrfan007
Post #311
Ah right that makes sense now. Nice to see something different. Big grin
I'm Si btw Tee hee
Posted 18th May 2014 at 13:28
eddy_gti6
Post #312
Thanks mate. I was set for a supercharger at the start of the year till I seen the VLR for sale and decided I have to try it. No1 else has so I thought I will be the 1st and have a unique engine what no1 else has Cool
Posted 18th May 2014 at 14:22
eddy_gti6
Post #313
Had a late start and late finish today. Didnt get into the workshop till after 4pm. Jim finished the wiring while I made up a blanking plate for the throttle body and modified my bumper ect... next job was to test everything. Cooling switch tested and kicks in at 97oC, fan rewired and works fine. Then we tested fuel pump and pressure what were fine. Bit the fuel rail we modified had a few holes where fuel was getting out. Back off for abit welding then tested. Still no better. This went on for about 45 minutes, each time getting worse. In the end we gave up and luckily found another one what was perfect. No leaks.
Then we tested for a spark. Nothing! Bit fiddling about and still nothing!! So left that and tested the injectors. Nothing again. Ran a few tests and found there was a wrong relay supplied with the ecu so jim knocked his own up. Tested spark and injectors again and both were working fine Big grin
10.15pm 18th May. Now will it fire... yes Thumbs up ITS ALIVE! Sounds f**king mental. Only problem is we have no idle so have to keep the revs up to stop it cutting out. Oil pressure was between 5-6psi. Air/fuel was between 13-15.5 depending on revs with fuel pressure set at 4.5bar. This was set at this due to the injectors being further away than standard also helped idle a little. Mapping should sort idle and dave will sort fuel pressure at the same time.
Few little things to sort in tge morning like a small leak from the rad, air leak in the inlet and the rev counter isnt working but other than that we should be good to go. Heres a quick video Cool
You tube
Posted 19th May 2014 at 02:49
eddy_gti6
Post #314
Up bright and early to try iron out all the rough edges and hopefully make mapping before dinner time.
Posted 19th May 2014 at 06:55
ozonehostile
Post #315
That 205 rad looks more at home in a 306 than the car it's off haha
Current Peugeot stable:
'99 306 gti6
'02 306 hdi estate
'97 306 Dturbo
'94 106 rallye 16v
Posted 19th May 2014 at 07:25
Post #316
Great to see someone try different ideas....
Really....really hope it maps well & hope it turns out amazing Thumbs up
Great work .!!!!!
Posted 19th May 2014 at 07:57
walker_texasranger
Post #317
Looking forward to seeing the results after mapping Cool
Hilux InvincibleX daily
306 No.13 Doh
Posted 19th May 2014 at 08:16
Post #318
Great work to get it all done (well, majority of).
Hope you get it sorted today and no issues with the mapping. Hoping to see a healthy result with this Yes
Posted 19th May 2014 at 08:29
Post #319
have you measured the bore of the runners?
be interesting to see what they used on them, what power did they run?
Posted 19th May 2014 at 09:56
eddy_gti6
Post #320
Bore is 45mm. Had a couple more issues this morning with air leaks in the inlet. Made a bracket for my coilpack to sit on, blead the coolant and front end on. Thats it ready for mapping. Abit later than I was hoping but Dave says its fine, bring it along. Next update will be weather mapping went well or weather there are more issues... soon find out.
Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url &amp; =
Posted 19th May 2014 at 14:04
Post #321
that bonnet makes small children cry Sad
Posted 19th May 2014 at 14:14
eddy_gti6
Post #322
Has to be done to allow room for the inlet Laugh my ass off
Posted 19th May 2014 at 14:15
jamiek_uk2000
Post #323
Not as much as that spoiler...
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 19th May 2014 at 15:28
Post #324
The one on Chris's car?
Or this beast! Jesus christ!
Posted 19th May 2014 at 15:33
eddy_gti6
Post #325
Sorry but your all going to have to wait till wednesday to find out what happens. Got there too late today so left the car there and I will be going back hopefully wednesday if I can get the time off work to have it mapped.
Spoiler will be off 1day LOL
Posted 19th May 2014 at 15:38
