displaying posts 276 to 300 of 434
Pages (18): first .. 11 [12] 13 .. last
Author Subject: Eddy's VLR + Omex 600
eddy_gti6
Post #276
Or you could just PX me Dave haha. Thinking black but quite like the silver too
Posted 6th May 2014 at 21:03
eddy_gti6
Post #277
Finally a step in the right direction. Just had a phone call off dave @ autolink who will be mapping my car. He has booked me in for Monday 19th May. Jim has I think finished sorting my omex loom, now just need to mess around getting a fuel rail sorted out to fit. Other than thats its ready to bolt on. New oil pressure gauge and volt gauge arrived today as I wasn't willing to spend £55 on a racetech sender! Been told by Dave its perrty pointless fitting an AEM once the car is all set up and he will run his own wideband while mapping the car. I still have a clearance issue I need to sort out between the inlet and the bonnet so going to try lifting the back of the bonnet a little and see if that gives me the clearance I need.
Posted 7th May 2014 at 08:59
eddy_gti6
Post #278
Bored waiting to go to work so decided to fit my gauges. Oil pressure sender still needs fitting but other than that there in. Im sure the volt gauge should be lower than 14 as well or is that about right? Iys around 12.5 with ignition and and 14 when car is started
Posted 7th May 2014 at 13:45
Post #279
14 is a healthy alternator.
Posted 7th May 2014 at 13:58
eddy_gti6
Post #280
That good to know Big grin thought it should have been around 13-13.5 for some reason LOL
Posted 7th May 2014 at 14:29
eddy_gti6
Post #281
Just a little update. Not much been happning this week really, just been waiting for friday to came so I can get on the ramps and fit most of my goodies Smile
In the mean time I have bought a few little bits and bobs.
* AEM wideband from dcc
* 21mm torsion bars
* hybrid ARB
* torsion bar adjuster screws
Looks like I have got a decent rear suspension setup Cool should go well with my bilstein b4 rear shocks and pugsport solid axle mounts.
Posted 20th May 2014 at 23:30
Post #282
You'll need better dampers to match those Yes
Posted 13th May 2014 at 17:59
eddy_gti6
Post #283
I have GAZ GHAs up front but never got the rears when I bought them off here what I wasnt happy about! Been searching for a set of gaz rears but dont come up very often. What would you recommend I use?
Posted 13th May 2014 at 18:36
Post #284
b6's or 205 tarmac would be good.
Posted 13th May 2014 at 18:41
p-silva21
Posted 13th May 2014 at 18:42
Post #286
myself and DCC have very similar 205's at the moment, fronts are inverted large spring gravel dampers, but I have bilstein gravel rears and 21mm bars, and Dan has 21's and GAZ.
my car seems so much more composed.
Posted 13th May 2014 at 18:45
eddy_gti6
Post #287
Any of these? Think the 1st 2 are the same?
Bilstein Group A
Bilstein tarmac forest
Bilstein Group N
Posted 13th May 2014 at 18:56
Post #288
yep they'll do the trick, not sure specifically what the damping rate is on mine, I believe 360/250 so not as stiff as those first two but more rebound than the group N.
205 grpN/challenge 350/200
205 Forest 360/250
205 tarmac 460/250
306 Forest 500/275
306 tarmac 600/300
Posted 13th May 2014 at 20:10
eddy_gti6
Post #289
Would you recommend uprating my front springs on my GHAs to something around 325lbs? With forest rear dampers, hybrid ARB and 21mm bars?
Posted 13th May 2014 at 20:50
Post #290
What's on the front now?
Posted 13th May 2014 at 21:28
eddy_gti6
Post #291
GAZ GHAs but no idea on what spring rate? What ever they come with standard I would have thought what im sure are around 275lbs I read somewhere. With spoox adjustable top mounts
Posted 13th May 2014 at 21:38
Post #292
I'd leave as is for now, give it a go Thumbs up
Posted 13th May 2014 at 21:40
eddy_gti6
Post #293
Dont really want to go too stiff as its my daily car. I will try it out once I get everything fitted. Fingers crossed the engine is strong and I get a good map on Monday I may book up for cadwell park on the 8th June as I dont think I will bother with FCS.
Posted 13th May 2014 at 21:55
eddy_gti6
Post #294
Today is the day I move to the next level Cool Just down at JBM now making a start on getting the VLR inlet fitted and omex on ect... will update later on tonight.
Posted 16th May 2014 at 10:42
superchargedblack1997gti6
Post #295
Good luck mate hope it goes smoothly!
Posted 16th May 2014 at 10:45
eddy_gti6
Post #296
Well had a long day. Been up since 5pm yesterday afternoon. Had night shift 11pm till 7am this morning then headed straight down to Jims for 9am to make a start on the car.
Started off stripping the front end and inlet off ect. Fitted VLR and just went from there.
As you can see from the picture above the fuel rail was causing an issue fouling the bonnet. This was the 1st job to sort out. Removed the fuel return and regulator and welded up the hole and fitted a new return on the end of the rail. Next job was to fix it yo the inlet what required modifying the mounting brackets. Heres the finished product with the 384cc injectors fitted.
Next up was to fit the AEM and oil pressure sender what wasn't to hard and didnt take too long. Mounted the FSE fuel pressure reg while just made a start on the loom. Glad I got the easy job LOL
Got all the omex loom plugged up to find there was no TPS plug, had been cut off for some reason. Decided to fit the map senser in the back of the inlet and made a start sorting out whats needed off the standard loom. Also made a relocation kit for the battery to be moved into the boot. Next fitted the throttle body to the inlet. This is pretty much as fsr as we got today. Oh apart from finding out there is no way the standard rad is going to fit so going to plumb in a 205 rad setup tomorrow as jim has a nice thick high flow rad sat on the shelf Cool
back there tomorrow for a 9am start to see how much more we can get through. Done quite well today so fingers crossed I will be ready in time for mapping monday morning Smile
Posted 16th May 2014 at 20:52
Niall
Post #297
Look forward to seeing the results monday!
Posted 16th May 2014 at 20:59
eddy_gti6
Post #298
Me to if I have it ready in time. Only got tomorrow, think jim is busy sunday but am sure I will be able to squeeze in a few hours if need be.
Posted 16th May 2014 at 21:02
jamiek_uk2000
Post #299
In the time you've started this thread till now I think I may have opened my car door a few times and gone "Uh... I'll do it tomorrow"
I just don't have the time!
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 16th May 2014 at 23:14
eddy_gti6
Post #300
Thats why you make time. 30 hours I was up yesterday. Im impatient and want everything done there and then LOL been waiting ages to get this VLR on but been little things stopping me but now I have everything its finally happening. Fi gers crossed i have not wasted my time.
Posted 17th May 2014 at 04:39
