Author Subject: Soft brake pedal when cold
demondriverdan
Just remembered something odd about the brakes on the race car when we were out at Brands last week. Once we'd done a few runs in the car, each time you went out the brake pedal was quite soft but after a lap or two would get much firmer and back to how it was a the beginning of the day.
Any ideas? Not certain what was causing it.
Rallye Race Car
Posted 14th Nov 2013 at 10:38
what fluid are you using?
Posted 14th Nov 2013 at 10:41
demondriverdan
Dot 4
Rallye Race Car
Posted 14th Nov 2013 at 10:54
What pads are you using?
  • Posted 14th Nov 2013 at 11:44
    demondriverdan
    Standard Brembo pads that came on the Megane 225. I have plans to upgrade but didn't think the pad would cause the problem?
    Rallye Race Car
    Posted 14th Nov 2013 at 13:13
    Try a fluid change first and ensure you bleed the system properly.
    Posted 14th Nov 2013 at 13:30
    demondriverdan
    It's a new system as I replaced all the lines when I removed the ABS. There are no leaks and we've bled it about 5 or 6 times to make sure all the air was out.
    Rallye Race Car
    Posted 14th Nov 2013 at 13:47
    Hawkesfire
    If you have a bias valve have you got this opened up enough to let fluid through also could be a bent bracket on your callipers so the pads have to pull up before they work correctly as i had this on the back of a Mk2 escort when someone had fitted a rear disc conversion and did not get the brackets lined up straight before they welded them to the axle !!!!!
    206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!!
    Posted 14th Nov 2013 at 15:57
    Could also be the master cylinder clearance.
    Posted 15th Nov 2013 at 19:48
    demondriverdan
    We've got a bias valve, around the mid-position so some fluid should be going in. Bent bracket doesn't sound too good! Will check them.
    Rallye Race Car
    Posted 18th Nov 2013 at 17:44
    demondriverdan
    Master cylinder clearance? As in how far the master cylinder moves?
    Rallye Race Car
    Posted 18th Nov 2013 at 17:45
