displaying posts 1 to 25 of 45
Author Subject: Quick brake line question?
I have to replace the metal lines that marry to the flexi pipes at front
But where do I unscrew the other end it seems to disappear off into the engine bay
Do I unscrew them at the back of the bulkhead?
I've never done changed the metal lines before
What's the difficulty rating for doing them?
I've bled brakes before so that side of things doesn't bother me!
I've already decided on standard pug ready fit ones
Cheers for the help guys
Posted 22nd Oct 2013 at 12:33
jorg
i think the lines from the front flexi should lead to the abs module, you would have to trace the lines to find which one is which.
306 2.1 S16 Tarmac Rally Car
Posted 22nd Oct 2013 at 12:35
jeffers Forum Admin
Dave if I remember correctly from when I removed my ABS, them lines run round the back of the bay along the bulkhead then down the passenger side chassis leg to the ABS pump.... An absolute Bas***d of a job as I seem to remember the drivers side one runs behind the manifold heat shield and is a complete sod to get to........
Team Running Engine again!
Team Negative Camber!
Sad
This is gona be fun then isn't it,..
It's either that or pay a garage £150 Dry
Posted 22nd Oct 2013 at 15:00
Niall
why do you need to replace it? Is it just because its damaged at the flexi end? If so, anyone near by that can replace a few inches in the arch and put a joiner in for you? Not the tidiest way but certainly thr easiest!
Posted 22nd Oct 2013 at 17:51
Failed mot because of it but yeah it's right on the bend,.
I like neat and tidy also love a challenge
Worst case ill have to push it out and over the road to the garage LOL
If someone had said what ever you do don't even attempt it I may reconsider
Ill crack open the Haynes too Smile
Posted 22nd Oct 2013 at 18:02
Niall
Is it both sides? Passengers should be fairly straight forwards but drivers will be a PITA. Will need to take out the exhaust heat shield for the drivers (can be a bas**rd with engine in situ). Will need to take out the battery, battery tray and mounting plate and earth harness to get both out.
Posted 22nd Oct 2013 at 19:30
Niall is correct, although if you remove the top engine mount you'll find it easier as you'll have better access to the back of the bay if you tilt the engine slightly forwards. Yes
Posted 22nd Oct 2013 at 19:51
Nice one guys! Yeah both front and 1 at the rear! Wink
Posted 23rd Oct 2013 at 00:38
ben306
I just replaced a few inches back on mine with a joining connector as mentioned above. Much easier and still looks fine.
My 306 Rallye Project Thread
Lap of Anglesey Coastal
3 sisters circuit
Few laps at Blyton
Posted 23rd Oct 2013 at 07:49
How hard is that to actually do?
And what do I need to do it?
Ie what size line which flairing tool and which connectors?
I've got near side rear to do too!
Any eBay links etc to what I'd need would be spot on! Thumbs up
I suppose if I fail miserably then it would be no real loss because I was going to replace that whole part of line anyway!
Posted 23rd Oct 2013 at 08:42
Ok after a bit of research I believe everything I need is here correct?
did cilcky from mobile so hope this works
Could someone just confirm the copper tubing size is 3/16 ?
Thumbs up
Posted 23rd Oct 2013 at 11:23
demondriverdan
I used 3/16ths when I replaced the brake lines in the race car. I can't look at the eBay link through work but my only concern would be that if you're using a cheaper flaring tool and trying to flare the standard steel brake pipes it could not be strong enough?
Rallye Race Car
Posted 23rd Oct 2013 at 12:08
i've got 3/16 roll and am about to do mine. bought an £8 pipe bender and it's addictive, only thing is my flaring kit seems to have "stopped working" from when i last used it a few years back, even though it's a mechanical item without any wearing parts LOL
Posted 23rd Oct 2013 at 12:15
The new crack then huh rikky?
Good call on the flair strength for steel lines!
I'll ask them that before I buy!
Posted 23rd Oct 2013 at 12:33
can you not do a compression fitting that requires no flaring as in this video skip 8mins 22secs in
should the flaring tool not be strong enough for steel brake lines?
Posted 23rd Oct 2013 at 13:43
i personally wouldn't use them, would much prefer unions due to ease of removing them too. not sure how the compression fittings would cope under constant pressure, although i know they use them in fuel setups Unsure
i'm using speedfits and nylon pipe now for my fuel setup now and love them
Posted 23rd Oct 2013 at 14:03
unions as in flaring both ends male and female nuts?
forget what i said, not even seen that video and only half read your posts. not really sure what you are aiming for? are you replacing metal with metal not copper?
i'd keep it all the same, but if you're putting a copper section into a steel bit then you're gonna have to use a good flaring tool or use a compression fit at one end and mate it to a normal union on your copper section
Posted 23rd Oct 2013 at 14:12
Crazy heads spinning now LOL
yeah I just want to cut out a part of the standard steel brake line with corrosion on it,..
and replace it with a copper brake line in its place,..
like I say I've never done this before so just want to do it right!
Posted 23rd Oct 2013 at 14:23
i'd just try flaring the existing pipe and compare how it looks against a flared copper equivalent
Posted 23rd Oct 2013 at 14:34
Posted 23rd Oct 2013 at 14:38
why don't you replace the whole lot and take your car off the road for months and end up going round in circles doing jobs and breaking stuff? that's what i'd do
Posted 23rd Oct 2013 at 14:46
How much is that steel brake pipe from Peugeot?
Perhaps buy a new one and chop it where it's joinable within the wheel arch. Granted you waste half what you've bought - but if you don't want to change the whole thing..
  • Posted 23rd Oct 2013 at 15:04
    If I remember correctly about £15 each,..
    LOL I don't fancy hacking a brand new line to bits!
    If I had to buy the complete thing then I'd rarther fit it,..
    Suppose a good length off someone breaking should do
    And a pipe bending too Dunno
    Ill try this copper one 1st
    Posted 23rd Oct 2013 at 16:20
