displaying posts 76 to 100 of 115
Pages (5): first .. 3 [4] 5
Author Subject: Rotrex Supercharger whining
pugheaven
Post #76
Yep not cheap but like you said above you could just use pc fans for a lot less cash as long as the flow enough air!
Posted 23rd Oct 2013 at 23:27
Post #77
Yeah, just grab a PC fan with thermistor speed control, be about 15-20 quid.
Posted 23rd Oct 2013 at 23:29
jamiek_uk2000
Post #78
I'd love to see how long it would last though...
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 23rd Oct 2013 at 23:37
doof
Post #79
They're not going to be waterproof are they.
Posted 24th Oct 2013 at 00:00
Post #80
I've run some underwater before!
Posted 24th Oct 2013 at 00:07
pugheaven
Post #81
Pretty sure iv seen some water cooled pc's use them to circulate the water so I guess you can get water proof ones
Posted 24th Oct 2013 at 00:20
allanallen
Post #82
Doof, when you say 'max inlet temps of 80' I'm guessing you mean the oil inlet temp rather than the charge inlet temp? Sorry I'm perhaps reading it wrong but if I was told max inlet temp for a charger i'd take it as air/charge temp?
Facebook
Posted 24th Oct 2013 at 06:26
doof
Post #83
Sorry it was definitely oil temperature in to the charger.
Posted 24th Oct 2013 at 07:55
m306
Post #84
How is it going to get that hot? Its not got any combustion like an engine, or exhaust temp like a turbo so hos does it generate that much heat?
supercharged China gti6 - Thu 16th Sep 1999 - sold
2010 megane rs250
Posted 24th Oct 2013 at 09:59
doof
Post #85
Remember ambient temp in the engine bay is probably 70 degrees. Its still spinning at Over 10000 rpm and will naturally generate heat conpressing air.
Posted 24th Oct 2013 at 10:07
m306
Post #86
Oh i see, thanks
2010 megane rs250
Posted 24th Oct 2013 at 12:44
doof
Post #87
Ordered a new 'charger today after taking the old one off at the weekend. Think the datestamp on my old 'charger was 12/09 so nearly 4 years old. The input shaft hasn't snapped, it still spins though it's extremely stiff to rotate it by hand. I'm not sure exactly what to expect but I'll be in touch with Rotrex again tomorrow to see what they say.
Speaking to Richard at TTS he said that a 13 row cooler should be satisfactory on these and they don't position their coolers behind fans either so I think I'm just going to run without but plumb in a temperature sensor and keep an eye on it.
Posted 28th Oct 2013 at 17:13
doof
Post #88
Anyone know how to get the metal boost pipe off the supercharger outlet? It looks like it's either pressed on or welded on but I've given it a pull and it won't budge.
Also, does anyone know if the inlet of the supercharger is standard? I don't have it to hand (or any good pictures) but it looks like there's a 4 bolt flange pressed / welded on to allow the throttle to bolt up to it.
Posted 29th Oct 2013 at 15:43
rallyestyle
Post #89
It could be welded, depends how the orginal owner wanted to do it.
Its not standard no No As you say there is a flange welded on which allows the tb to bolt up correctly. Will struggle to get that apart again i suspect Yes
You could possible just hold on to that part though as i cant imagine it will be need for anyone to assess damage to the carger Unsure
Just Drive It
Posted 29th Oct 2013 at 16:30
doof
Post #90
Just to confirm, I spoke to Nick at Lynx and the throttle adaptor is just a press fit so I should be able to pop that off and reuse it. The high boost pipework is welded on though so I'll have to look at either swapping the housing (which i'm not keen on) or getting another pipe made up and welded on. I'm not really keen on welding the new outlet on though but I'm not sure how else to do it. How are other boost pipes normally attached to superchargers? Surely silicone is good enough for 1 bar?
Posted 30th Oct 2013 at 12:52
Hawkesfire
Post #91
I have just used a silicone hose on mine for HB and its been ok?
Marty
206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!!
Posted 30th Oct 2013 at 13:22
m306
Post #92
Some of the pipework is already silicone hose and copes fine.
2010 megane rs250
Posted 30th Oct 2013 at 15:07
Post #93
If you have a silicone joiner on the charger outlet, it will collapse when off boost. Yes
Posted 30th Oct 2013 at 17:56
m306
Post #94
Dont come off boost then LOL
2010 megane rs250
Posted 30th Oct 2013 at 18:52
rallyestyle
Post #95
I pressed mine in and then got it welded although as you say it wasnt a requirement.
For the outlet from the charger i used one of these bad boys...
As long as there are no major gaps between pipework then silicone couplings are fine :-)
Just Drive It
Posted 31st Oct 2013 at 10:39
pugheaven
Post #96
Did any one find out the min/max oil temp for the charger/fluid?
Posted 19th Nov 2013 at 17:35
doof
Post #97
I'm still waiting for my charger from TTS so not really looked into this. The max temp was 80 degrees but I don't know about min / ideal operating temps. I'm going to stick with the same size oil cooler but plumb in a temp sensor so I can keep an eye on it. Will report back how that goes.
Posted 26th Nov 2013 at 11:35
doof
Post #98
As if I wasn't already p**sed off with Rotrex enough I'm still sat here waiting for my supercharger that I paid for back in October. I was offered a 10 day lead time by TTS but here we are nearly 3 months later and I still have nothing! I started off really pleased with TTS and now I'm just being fobbed off and Richard is barely responding to my emails.
Might email Rotrex and have a moan to make myself feel better.
Posted 10th Jan 2014 at 11:11
rallyestyle
Post #99
Doh Whats the reason they are giving you?
Just Drive It
Posted 10th Jan 2014 at 12:06
Post #100
probably none judging by the sounds of it LOL
i would be tempted to tell them it's a hire car and you're going to be passing on a £60 a day bill for car being out of use LOL
this may have happened to me when waiting for a £1000 payout for a smashed up gti6 a few years ago Whistle
Posted 10th Jan 2014 at 13:36
