displaying posts 1 to 25 of 49
Author Subject: Longer drop links for lowered car?
gb_gti6
Have ready previous posts, my car is fairly low and I see that longer drop links are better for this as I popped one off.
Just wanted to know which ones to go for, which make and model car is best to take them from?
Thanks
Team OCD
Posted 15th Aug 2013 at 17:55
allanallen
Why?
Facebook
Posted 15th Aug 2013 at 21:19
gb_gti6
I am just going from what I read on here, and wondered if people had more info on this!!
Team OCD
Posted 15th Aug 2013 at 21:42
Niall
Adjustable is what you want for this. Phil on here has done a guide on how to set them up which also gives you a good idea as to why you want them for a lowered car.
Posted 15th Aug 2013 at 22:34
gb_gti6
So can I not just use a pair of longer ones? And where do I find this guide?
Team OCD
Posted 15th Aug 2013 at 22:44
Niall
http://www.306gti6.com/forum/showthread.php?id=60931
Ive never seen set length longer ones tbh.
Posted 15th Aug 2013 at 22:47
Rich E Forum Admin
307 drop links are good for this. Same fitment and a bit longer (around 30mm IIRC).
I did about 40k on a pair of these on a lowered 306 and they were still fine when I broke the car.
Posted 15th Aug 2013 at 22:50
gb_gti6
Thanks, will have to have a look. Will be cheaper than adjustable ones I take it?
Team OCD
Posted 15th Aug 2013 at 22:56
gb_gti6
Were the 307 ones you had metal?
Team OCD
Posted 15th Aug 2013 at 22:59
Rich E Forum Admin
I think I paid £40 for a pair of TRW ones from ECP, but this would have been about 3 years ago.
Posted 15th Aug 2013 at 23:00
Rich E Forum Admin
Yep.
Posted 15th Aug 2013 at 23:04
gb_gti6
Yeah just looked at those, only about £25 but metal or plastic better?
Team OCD
Posted 15th Aug 2013 at 23:07
Niall
There is pros and cons to both. Personally i used to use plastic ones before i got adjustable as i bent a metal one before where as the plastic ones have more give in them before they break.
Posted 15th Aug 2013 at 23:09
Why?
Posted 15th Aug 2013 at 23:21
Niall
Why?
Why what? Why longer drop links? Because the distance between the shock tab and ARB resting position gets longer the lower the car is. Use a standard drop link and its constantly fighting against the resistance the ARB bushes give hence quicker wear in the drop link joints.
Posted 15th Aug 2013 at 23:49
beez_neez_gt
Would it be the same for a 205 by any chance?
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 15th Aug 2013 at 23:51
jeffers Forum Admin
I have to ask this question because there is one part of the whole discussion I don't get, the arb pivots from the same point regardless of how low the car is, so why if the car has been lowered by the same amount on both side do you need longer drop links?? *disclaimer* I have had a few beers so if I've missed something I apologise in advance!
Team Running Engine again!
Team Negative Camber!
Posted 16th Aug 2013 at 00:34
Rich E Forum Admin
Read 2 posts above yours.
Posted 16th Aug 2013 at 00:37
Rich E Forum Admin
Why?
Why are you asking why?
Posted 16th Aug 2013 at 00:39
Because the length changes which changes the angle the joint goes through, leading to excessive wear and/or complete failure.
beez_neez_gt
Yes, the cars chassis distance to the tab has a longer distance hence a longer drop link needed, short OE ones will over wear or break. Car is lower so end of ARB goes lower down hence longer links needed to keep the ARB in its OE position else drop links wear out more being too short due to the lowering.
Hope this clears it up.
Would such parts as Bilstein shocks etc accommodate this difference, ie lower tab welded in ?
Pug fee`ver,
Posted 16th Aug 2013 at 00:57
allanallen
No it doesn't, it lifts the arb up.
Whatever floats your boat anyway, I'd say an adjustable drop link would be more beneficial to dial any preload out, the benefits of that are somewhat debatable on a road car though.
Facebook
Posted 16th Aug 2013 at 06:18
jeffers Forum Admin
Allen is making more sense than anyone else on this, the anti roll bar when disconnected on both sides just pivots so i fail to see why different length drop links are needed? As i previously stated if both sides are lowered the same amount why do you need different length drop links?? The anti roll bar will still end up the same when connected as it would when the car is at standard height so i just dont see it!??! Ie when its lower the relative distance to the tabs will be the same as they where because the ARB pivots! So when you connect one side the relative distance to the tab will be the same on the other side as it always was! Roll eyes
Posted 16th Aug 2013 at 07:31
Niall
No it doesnt. The arb sits naturally at almost horizontal when nothing is attached to it because there are notches in the arb bushes that hold it here. The tab on the shock will stay at the same height from ground regardless of how low the car is but the arb will get closer to the ground the lower the car goes therefore creating a longer distance in between the shock and arb. When you fit standard drop links, they will try to pull the arb upwards but obviously this is going to put more strain on the DL bushes.
Posted 16th Aug 2013 at 07:46
Err nope, arb bushes are round inside.
Unless you alter the travel extremes the droplink is still operating within its designed window, so theres no need to change them.
Posted 16th Aug 2013 at 08:10
