displaying posts 1 to 25 of 33
Author Subject: Group Buy Stud Conversion
daver6
Right, a few people want the conversion and I would think we're all in the same boat with trusting Grayston.
Basically, Peugeot Sport items will cost around £170 or Grayston at around £40. There will be a HUGE difference in quality, that isn't to say that Grayston won't be fit for purpose however.
What are our feelings? Is it worth contacting a company that could produce the studs and nuts? I suspect we'll not save much on the AI-Tech made parts available from Demon Tweeks
Wishbone Polybushes available
Posted 23rd Jul 2013 at 13:24
drewhughes
whats the advantage to a stud conversion?
Posted 23rd Jul 2013 at 13:25
you can have different wheels! Yes
Posted 23rd Jul 2013 at 13:31
Easier to fit the wheels back on
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 23rd Jul 2013 at 13:33
Doh that kind of stud conversion!,...
I looked into this you can get some nice Shiny Nuts!
and yeah obviously easier to fit wheels!
Posted 23rd Jul 2013 at 13:36
daver6
Easier to fit wheels
Easier to fit wheels with spacers (using long studs and open ended nuts)
I guess it looks like a Micra too?
Posted 23rd Jul 2013 at 13:54
demondriverdan
Speedshack do studs that I know a few people run with good results. Might be worth contacting them?
I'm interested but obviously need a price or a rough idea before I can confirm completely.
Rallye Race Car
Posted 23rd Jul 2013 at 13:57
daver6
Speedshack actually do a group discount for multiples. They also sell Grayston parts, which a search on here or 205 drivers will throw up a few Q.C. issues with nuts tapped off centre or with s**t threads.
You'll also find people who have run them for years without issue.
My main issue is that with Grayston, there's thread into hub > shoulder > wheel nut thread. The shoulder smaller than pitch diameter so there's no physical 'stop'. You rely on loctite to keep the stud captive.
Posted 23rd Jul 2013 at 14:05
I'm a bit confused, But if we get ones that are definitley good quality and are pretty inexpensive i might be interested Smile
Posted 23rd Jul 2013 at 14:07
beez_neez_gt
If a wheel decides to come off it means you are less likely to have a damaged wing like what happened to mine.
For a proper fit, always tap every hole for each stud, iv used three so the forth iv used a locking bolt and used the spare for other cars so wheels go on easy.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 23rd Jul 2013 at 14:11
how often do wheels come off tho?
Actually It happened to me Once in a small van but I'd only had it 2 days so f**k knows who had been working on it.
I'd be up for it if the quality was top notch but I'd rather have the standard bolts than some s**tty cheap stud conversion
Posted 23rd Jul 2013 at 14:14
buying them for the sake of it FTW
Posted 23rd Jul 2013 at 14:19
3mm drill bit through each stud and 4 R clips holding you wheel on for quick release FTW
  • Posted 23rd Jul 2013 at 14:22
    get them because you can
    Posted 23rd Jul 2013 at 14:23
    daver6
    Well, the Grayston bits will be usable but won't leave you wiping up after yourself after you've inspected the threads. But then even retail, they're less than £40.
    The Pug Sport will be much more similar to the AI Tech items and will be great quality and more than likely have a little lead on the stud to get the wheel on even easier.
    Posted 23rd Jul 2013 at 14:25
    Posted 23rd Jul 2013 at 14:34
    If the wheels come loose the studs will just bend/snap anyway, still f**k yer wing up.
    Posted 23rd Jul 2013 at 14:36
    daver6
    The picture WelshPug has put up is of Pug Sport items from France that an ex-member on here managed to sort out. Rumour has it they're on the go on 106RR forum, but the thread looked dead the last I saw.
    As you can see, the shoulder is nominal width so will provide a stop when fastening into hub
    Posted 23rd Jul 2013 at 14:42
    they weren't pug sport items but made to the same spec.
    http://www.106rallyeforum.com/forum2008/showthread.php?p=835320
    http://www.306gti6.com/forum/showthread.php?id=107525
    mark _ omalley14 @ hotmail . com
    Posted 23rd Jul 2013 at 15:00
    demondriverdan
    Would it be possible to do a group by on just the studs? Don't think there'd be any problem with using Grayston nuts on decent studs?
    Rallye Race Car
    Posted 23rd Jul 2013 at 15:15
    I'd rather use the matching ones tbh.
    Posted 23rd Jul 2013 at 15:19
    demondriverdan
    That's fair, was just an idea really!
    Rallye Race Car
    Posted 23rd Jul 2013 at 15:24
    you could do it, no reason not to specifically, but given the quality has been hit an miss I'd not risk it personally.
    Posted 23rd Jul 2013 at 15:58
    daver6
    Right chaps, there we go.
    I'd be happier paying £100 for a decent set as above rather than the £55 I've been quoted for Grayston bits
    Posted 23rd Jul 2013 at 16:13
    beez_neez_gt
    Those are the studs I have fitted, 12.9 so less likely to all break if a wheel decided to come off again the studs will give you a bit of extra time. There was no signs of the wheel coming off when it happened, wih studs at least you get a saving grace.
    Just another little reason to have them, I wouldn't tough any less than 12.9 though especially for semi track use etc.
    Pug fee`ver,
    Posted 23rd Jul 2013 at 17:59
