Fusebox lid - £2
CD Changer cables (round plugs) x2 - £2 ea
Throttle Pedal -£2
Brake Pedal - £2
Clutch Pedal – £2
Nile blue ph2 pass door handle - £5
Nile/Diablo/Silver/China fuel cap blanks - £2 ea
Silver fuel cap - £2
Spare wheel hook - £4
Interior light bits galore, map lights, rears, fronts etc £2 ea
Switches – various. Hazard, Heated screen, brightness etc - £1 ea
Document holder for under pass seat x5 - £2 each
A/C model heater controls. Slight split to black plastic cover - £5
Silver central dash vents - £4
Door handles (inside) drivers and pass - £2 ea
Door handle surrounds (inside) drivers and pass - £1 ea
Drivers dash vent (ripe for boost podding) - £4
Interior mirrors x3 - £2 ea
Ph3 digital clock and temp display - £4
Ph2 radio control stalks x2 - £2 ea
Ph2 ultrasonics - £2 pair
Fuseboards x2 complete with fuses - £4 each
Pass window switches x2 - £2 ea
Auto wiper stalks x2 - £2 ea
Seatbelt sets x2 - £5 ea
GTi boot trim (3 pieces) in average condition -£5
Handbrake surround - £2
Silver front grille - £5
Silver ph3 door trims. Some clips broken and one door trim bent - £5 set
Ph3 GTi6 rear spoiler - £20
GTi6 heat exchanger - £5
Steering column - £5
205:
Black ph2 N/S rear arch trim - £10
Black ph2 N/S door trim with red strip - £10
8v inlet manifold with fuel rail - £5
8v inlet manifold with throttle body, and fuel rail - £8
205 opening rear window glass - £5 pair
205 GTi rear anti roll bar - £10
8v alloy engine mounts £5 ea
205 Jack - £5
Front washer bottle - £5
Ph2 black gear gaitor surround. Gaitor itself is in poor order - £2
Electric window switches within panels
Seatbelt slider rails next to sill x 2 pairs - £3 pair
Ph2 black heater control panel cover with clear symbols - £5
Ph2 black boot hinge plastic covers for roof lining - £2 pair
Ph1/1.5 red rear valance ‘faux fog’ cover - £5
Ph2 black internal mirror covers. Drivers side has screw holes. Minimal clips - £2 pair
Map light - £2
Ph2 black interior door handle opener. Pass side - £2
Ph1/1.5 grey interior door handle opener. Drivers and pass side - £2 ea
Ph2 black large door grab handle - £2
Ph2 black clock surround with all clip - £4
Ph2 black dash vents Left and Right. Drivers side has hold for immobiliser - £5 pair
Ph2 black central dash vents - £5
Ph2 black cufflink tray for behind gear gaitor. All clips in tact - £5
Throttle pedal x 2 - £2 ea
Rear wiper arm - £2
White bonnet hinges - £5 pair
Boot striker plates - £1 ea
Cig lighter - £1
Handbrake. No sleeve on it - £4
Ph2 black steering wheel surround. Top and bottom - £5 for both
Ph2 black lower right large dash panel - £5
Ph1.5 grey footwell kick plate drivers side - £2
Ph2 black footwell kick plate both sides - £4 pair
Ph1.5 grey handbrake surround - £4
Ph2 black handbrake surround. 2 broken fixings – FOC
Ph2 black sunvisors - £5 pair
Ph1.5 grey door cards with red carpet - £10 pair
Genuine Peugeot 205 5 door roof rack - £20
Diesel 205 twin fans in cowling - £10
Ph1 expansion tank - £10
8v cam cover - £5
Ph 2 fuel sender - £5
Spare wheel hook bolt - £5
Postage available. Collection possible from FCS at Combe next weekend if required.
