displaying posts 1 to 25 of 37
Author Subject: GTI6 into 205
JWP EFi
Turbo Legend!
I'm researching the required parts/alterations needed to put a gti6 into a 205 gti, so far i've come up with this:
Reangled exhaust manifold
Thermostat/radiator hose adaptor
Relocate radiator
Wiring loom
What clutch do i use to suit 205 cable, Mi16? or is there a cable that will work with the push pull setup?
What do i do about master cylinder clearance, heard that i need to use a base model servo and cylinder?
Posted 21st May 2013 at 21:43
eddy_gti6
From what i remember you can use standard 205 clutch cable. Other than that i dont know!
why do you want to do that tho? you have 2 306s there. just get the blue one built up for track and black for road LOL
Posted 21st May 2013 at 21:47
JWP EFi
Turbo Legend!
chris, ive always loved the 205 and i'm now thinking about about getting one, weighs less than a 306 plus they are proper old school cool. totally standard looking 205 with 6 engine and chassis mods would do me fine
Posted 21st May 2013 at 21:49
beez_neez_gt
Iv used a 406 master cylinder with 6 brakes, its a bit bigger and allows the pedal bite not too low, it feels as it was with old 1.9 brakes i had before.
Iv used mi16 clutch, be3 clutch fork and be3 gear arm. Iv used vts g box so used 1.9 diff using vts crown wheel so 205/309 d shafts can be used. There are other ways but thats how i did mine.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 21st May 2013 at 21:50
I'm running a vts box and gti6 clutch with a 205 cable
You need to trim some of the plastic cam belt housing to get the master cylinder to fit
Thumbs up
I have a whole car (205 with gti6 in) you can purchase Yes
JWP EFi
Turbo Legend!
BBB, you seem to have everything i want lol. whats the crack with fitting a base spec servo, guessing its smaller?
Posted 21st May 2013 at 21:52
You don't needto relocate the radiator. You'll have to modify the fan housing a bit to clear the manifold.
  • Posted 21st May 2013 at 21:54
    you don't need to trim anything if you adjust the pedal box so the servo is raised Yes
    doing mine now and pretty much tackled everything now but do not under estimate how much you need.. a proper job means making it tidy and you'll need like water pipes and what not. plenty of bodges toucan do but worth doing right IMO
    budget about £1k for bits alone
    I've done so far:
    cambelt, waterpump, clutch (valeo), 1.6 gti box, BBM hoses and BBM thermostat adapter, solid lower pulley, wiring loom (DIY), tacho mod (mei), oil pressure mod, also needed 1.9 hubs struts and shafts as the 1.6 ones were no good. rad needs lowering still to clear inlet and exhaust manifold to reangle. but I'm doing it from bare shell, so you can do it on a smaller budget if you're in a rush
    Posted 21st May 2013 at 21:57
    you do encounter loads of small things so its hard to itemise it as such. once you're stuck in you'll see why it takes a bit longer than you'd planned
    oh moving the wiring to the opposite side of the bulkhead too
    Posted 21st May 2013 at 22:00
    beez_neez_gt
    I did that, elongated the servo holes higher yet still needed to sort the cam housing. Each 205 has different tolerances so would be a good idea to buy a car already done then modifi it how u want it and recon the engine etc so u know its top. You can only elongate so far before servo hits the car and wont go anyhigher u see.
    Pug fee`ver,
    Posted 21st May 2013 at 22:03
    JWP EFi
    Turbo Legend!
    i already know about having to move wiring, what o/e hoses can i use? any pics of peddle box mods?
    Hoses, use bbm gti6/205 kit, easy peasy.
    Posted 21st May 2013 at 22:06
    JWP EFi
    Turbo Legend!
    hmm, i hate buying shiny! although if i cant tidily reuse mix n match of 306/205 hoses then bbm it would be
    Posted 21st May 2013 at 22:08
    Give me £1300 and you can have the whole car Thumbs up
    Posted 21st May 2013 at 22:09
    JWP EFi
    Turbo Legend!
    pics please, is she a taxed and tested runner?
    Posted 21st May 2013 at 22:14
    beez_neez_gt
    Some 205's need very little cam cover modification, others loads like mine. However i have all the strength plates fitted so did make the master cy come out more.
    I agree using all BBM engine mounts and water hoses in any colour u wish, also the 106 blank one for the right side header tank block if ph 2. I have a spare one if u need it.
    Pug fee`ver,
    Posted 21st May 2013 at 22:18
    don't forget uprated lower mount, lambda boss adding in and an altered downpipe too to mate to a centre section
    Posted 21st May 2013 at 22:32
    Yeah it's surprising how much shells differ. My servo is miles away from the cover so I didn't need to touch it. Others have had to grind a fair bit off. Until you pop the engine in you don't know.
  • Posted 21st May 2013 at 22:37
    jamiek_uk2000
    Some info
    Looking for:
    VTS P1 Rack
    PR1.2 16"
    Posted 21st May 2013 at 22:43
    Jake
    Seb, I like your thinking Thumbs up
    Mine just uses 306 gti6 hoses but I want them changed do the BBM kit.
    I'm waiting for second hand ones to pop up coz I'm not paying that much for hoses!
    The 205
    205 GTI6 For Sale
    Off Racing!
    Posted 21st May 2013 at 22:47
    footah212
    I got an unused mi16 clutch in garage if you looking for one Seb
    Phase 2 Blaze GTi6
    PS3 - Black Ops 2
    eddy_gti6
    Buy a 309. Be different Cool
    Posted 21st May 2013 at 22:52
    make sure it's the right one, only one of them works and it's the 1.9 one, and a lot of the time you end up with a the 2.0 one
    mine's a genuine valeo one, part no 801042, if that helps for cross-referencing
    jamiek_uk2000
    I've been looking for a while for a nice condition 205 GTi6, but all of them seem to be either in tatters or totally stripped and caged. I've got my 306 as a track slag, want something to mess about with on the road
    Looking for:
    VTS P1 Rack
    PR1.2 16"
    Posted 21st May 2013 at 22:54
    footah212
    It's the right one. It was fitted to my old 6 engined 309 track car.
    Phase 2 Blaze GTi6
    PS3 - Black Ops 2
    Posted 21st May 2013 at 22:58
