Now, before i ask questions the car is 170mm and 150mm from the ground at the rear jack point and front jack point respectively. Im unsure what this translates to as a drop as i don't have a standard 306 nearby to compare. What i want to know is what kinda of rake do people run on their cars? This is a drop of 20mm across the car and im unsure if this is the correct thing to do.
Also, i think i may require help finding a setting for the rear dampers, over bumpy surfaces as found on our country lanes the car skips around a bit and under heavy braking under any steering angle its almost as if the rear wants to swing round. I can understand this is a characteristic of stiff springs, but cant help but feel that better damping would at least reduce the effect. I've currently tried 4 turns from soft and 4 back from hard settings on the rear dampers and im set at around halfway for the front.
Finally, im running 205/45/16 PE3s at 32Psi if that makes any difference whatsoever!
Cheers for any help!
atterz
