displaying posts 1 to 25 of 48
Author Subject: Couple of queries
atterz
I recently had my new beam built up and put on the car, going with 23mm bars and a 30mm ARB, this seems to be quite favoured on the forum so hopefuly ive done the correct thing! I am currently running with AVO dampers rear and AVO coilovers front, which i believe are around 280lbs springs.
Now, before i ask questions the car is 170mm and 150mm from the ground at the rear jack point and front jack point respectively. Im unsure what this translates to as a drop as i don't have a standard 306 nearby to compare. What i want to know is what kinda of rake do people run on their cars? This is a drop of 20mm across the car and im unsure if this is the correct thing to do.
Also, i think i may require help finding a setting for the rear dampers, over bumpy surfaces as found on our country lanes the car skips around a bit and under heavy braking under any steering angle its almost as if the rear wants to swing round. I can understand this is a characteristic of stiff springs, but cant help but feel that better damping would at least reduce the effect. I've currently tried 4 turns from soft and 4 back from hard settings on the rear dampers and im set at around halfway for the front.
Finally, im running 205/45/16 PE3s at 32Psi if that makes any difference whatsoever!
Cheers for any help!
owain wrote:
Posted 26th Apr 2013 at 21:58
Tyres are under inflated IMO
Std is 36 and I run 34 on 17s, I'd run 35 on 16s Yes
Posted 26th Apr 2013 at 22:00
I'd also say your nose heavy if the back is skipping about Dunno
Posted 26th Apr 2013 at 22:03
the slightly wayward feeling I would imagine is the 30mm arb!! that's significantly stiffer than standard and coupled with 23mm bars personally I feel its way ott for road use, 23mm with hybrid was wayward enough on uneven surfaces, I'm going to use 23mm with standard ARB.
140 and 143 from floor to jacking points is the standard height measurement from Autodata.
Posted 26th Apr 2013 at 22:04
atterz
Hmm i had thought it was gonna be a bit Ott for road use but upon finding my Hybrid ARB was stuck in my old beam anyway im now pretty much stuck with it, hopefuly ill see some use out of it on track this year! So from what i gather im already at standard height with the front and im nigh on +30 at the rear? Ill have a play with tyre pressures tommorrow as that doesnt require much effort! Im nearly maxxed out raising the front coilovers, id say i have 5-10mm of adjustment left in extra height before they fall off!
What dampers were you using Mei?
Posted 26th Apr 2013 at 22:14
AST on the front and Koni on the rear.
Posted 26th Apr 2013 at 22:23
atterz
I was considering running Tarmac billies rear so i have no adjustment to screw up and then talking to AST regarding somthing for the fronts.
Im really confused and want to know if the rear is higher than standard, i cant see how it would be :S!?
Posted 26th Apr 2013 at 22:27
allanallen
Too high and a bit too much rake IMO and the avo dampers will never really be up to the job of controlling your rear setup.
Facebook
Posted 26th Apr 2013 at 22:33
atterz
Balls! Ive never adjusted a rear beam so clueless with heights, if id of known your location sooner i would of requested your services! Im only in Codnor!
Posted 26th Apr 2013 at 22:42
jamiek_uk2000
You shouldn't be that high on a 205/45/16 since that is almost exactly the same size as a 195/55/15 wheel, unless the axle hasn't been dropped at all and since there is no sag due to the uprated ARB & TB it's kicking you right up. You need to drop that rear to start with and then work from there I would say
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 26th Apr 2013 at 22:54
atterz
Ill go out and remeasure today from sills down and arches down so i can compare against other peoples cars. If it is indeed raised instead of lowered is there anyone in the south wales area that can help me lower it next weekend as i have never done one. The beam is brand new so the bars should slide out easily!
Posted 27th Apr 2013 at 07:22
Who built your beam, and did you specify a ride height?Dunno
Posted 27th Apr 2013 at 07:33
jord294
When your beam was rebuilt, did you have solid mounts fitted? as if you have o/e rubber mounts, that would have an effect, and won't be helping
Personally, if I put 23mm bars in a beam, I'd of probably set the distance between shocker mounts, around 310mm. Maybe a touch less
Posted 27th Apr 2013 at 10:32
atterz
Taken today on my drive, just as i thought it was sorted as well. May as well bash my head against a wall!
Posted 27th Apr 2013 at 10:47
allanallen
Does your missis/mum know you've drawn all over the table? :p
Facebook
Posted 27th Apr 2013 at 19:51
atterz
Sacked the missus off months ago, and well i annoy my mum every time i come home Big grin
+ its my work bench in the garage
Posted 27th Apr 2013 at 19:54
jamiek_uk2000
There is something wrong there if the rear is 11mm out from side to side. Who built the beam, I would take it back to them and get them to sort it out Thumbs up
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 27th Apr 2013 at 19:56
jord294
Are you trying to say the distance between eyes of rear shock is 185mm?
Posted 27th Apr 2013 at 20:00
atterz
Im in South wales as of monday and wont be anywhere near the north for weeks, the ground isnt perfectly flat on my parents drive so i need to allow some variation for that, however the fact she is too high on the rear is still very much present!
Posted 27th Apr 2013 at 20:01
simonjames
185mm shock distance ?????? iirc 330mm is std
MY EBAY ITEMS
07943066306
Posted 27th Apr 2013 at 20:03
jamiek_uk2000
If you can't get it sorted with the builder, I would take the time out to go see Jord, he knows beams inside out and if he can't sort it out then it's FUBAR'ed. Plus on the way you get to drive on some of the best roads I've ever been on if you travel from South Wales
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 27th Apr 2013 at 20:04
jord294
If you can't sort it down south mate, fetch it up to me and I'll put it right for you Thumbs up
Posted 27th Apr 2013 at 20:06
atterz
I will do mate, the build of the beam is absolutely perfect she is brand spanking new, i can only guess the 23mm bars have provided much less sag than was accounted for Big grin The bars should pull straight out as its only been together a week today, ive just never lowered a beam and want to do it the correct way Big grin.
Ill remeasure the shocker i think..
Posted 27th Apr 2013 at 20:10
where are you measuring your sill heights? autodata is to the lowest point on the jacking points.
Posted 27th Apr 2013 at 20:11
simonjames
maybe 285mm ? that would give around 65mm drop though
MY EBAY ITEMS
07943066306
Posted 27th Apr 2013 at 20:12
