displaying posts 26 to 50 of 64
Pages (3): 1 [2] 3
Author Subject: quick/short shift
devere
daveyboy wrote:
Did you fit yours yourself?
Yeh I fitted it myself. Took quite a bit of time to get it right and getting the right position on the tunnel to put the rods through. Then obviously have to make it water tight and ridy it up etc. I ended up boxing it in rather than just leaving the holes in the bulkhead/firewall.
Posted 20th Apr 2013 at 09:54
Would love to see a few pics of how you did it if its no too much trouble. I'd like to see if the holes can be sealed with some split grommets I found.
Posted 20th Apr 2013 at 10:00
use CV boots, grommets wont work well Smile
Posted 20th Apr 2013 at 10:28
devere
Il try and grab some later on when I go out to do a few bits. Well, a lot of bits. You wont make it seal with grommets, as there is to much movement side to side on the top rod. Its a surprisingly bigger hole than the rod itself to accommodate the movement.
As I said, ive boxed mine in, and then used two gaiters attached to a lip I put on the box section I put in. Il get some pictures this afternoon if I can still bend under the dash.
Posted 20th Apr 2013 at 10:37
Is there side to side movement on the rods through the bulkhead , or just back and forward with a little bit of rotation as well?
Posted 20th Apr 2013 at 17:04
there is a bit on one yes.
CV boots is what is included with the 106/saxo kit, one around the main stick and one around the smaller forward rod, the long thicker rod is under the car.
crap pic from my kitchen -
Posted 20th Apr 2013 at 17:38
Christ, it looks heavy. Does it weigh a lot?
Posted 20th Apr 2013 at 17:49
All the round bits are tubular, the quadrant isn't light but its sturdy enough.
Does weigh more than standard, but standard is very flimsy with plastic and bent bits of tin and plastic bushes, not rose joints and cartridge bearings!
Posted 20th Apr 2013 at 18:06
devere
Here are a few quick snaps I got earlier. Couldn't really get too great a shot tho...
They should give you some sort of idea. I cant really get in to take a picture of the quadrant on the subframe and the linkages etc, just too fiddly to get the camera under there at the moment while im wrestling with the steering arms and anti roll bar....
Edit: It also helps if you have a handy old rotivator that you can rob the handle from to make up a reverse cable lifter! haha.
Posted 20th Apr 2013 at 20:24
superchargedblack1997gti6
Post #35
Is youres a kit for a 306? Looks to fit well enough really want one of these ? Thumbs up
Posted 20th Apr 2013 at 20:46
devere
Post #36
I can't remember what I discussed with colin when I ordered it. I told him it was for a 306. Although at the time I was running a be3 5 speed box.
I have since moved on to a 6 speed dog box and didn't have to change anything. If anything it fitted better as i didnt have to weld the extra bit onto the selector arm of then new box to bolt the rose joint to. The new box accomodates the bolting of a rose joint as standard.
On a standard 306 box, you will need to weld a supplied tube over the round selector arm, and also drill a hole on the other arm to bolt the sideways movement rod onto. Il admit to having 2 attempts at that when i drilled the arm on my original box!!
Posted 20th Apr 2013 at 20:53
Post #37
Have you got a contact number for Colin must have one of these shifters! Many thanks Thumbs up
Posted 20th Apr 2013 at 20:54
Takedown
Post #38
google ATSPEED co uk
and theres a number for you
Posted 23rd Apr 2013 at 22:08
Post #39
*Retarded question inbound*
How do they work???
*Runs*
Posted 24th Apr 2013 at 21:52
Post #40
How do they work???
*Runs*
You use it for changing gearYes
You pull/push the lever forwards or back to go up or down the gearsThumbs up
Posted 24th Apr 2013 at 22:37
Post #41
Video of the Satchshift in operation here...
http://youtu.be/NPP8trIYM_8
And a less boring one here...
http://youtu.be/NbLcuUn5u08
Posted 24th Apr 2013 at 22:42
jamiek_uk2000
Post #42
That video seems somewhat longer than it needs to be...
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 24th Apr 2013 at 22:44
Post #43
Yeah, once you've seen it go up and down the box twice I think you'll get the gist.
Posted 24th Apr 2013 at 22:48
Post #44
LOL at the first one, gay surely the way hes handling that knob!!!Yes
Posted 24th Apr 2013 at 23:14
pebbles167
Post #45
How do I go about getting one? Contact colin direct through atspeed?
2005 Peugeot 206 GTI 180
2008 BMW K1200R
Posted 24th Apr 2013 at 23:31
Post #46
Group buy? I want one too
1. Daveyboy
Posted 25th Apr 2013 at 07:35
pebbles167
Post #47
1. Daveyboy
2. Pebbles167
2008 BMW K1200R
Posted 25th Apr 2013 at 09:28
devere
Post #48
Group buy was tried not so long ago...
http://www.306gti6.com/forum/showthread.php?id=146542
Posted 25th Apr 2013 at 20:54
blandy
Post #49
1. Daveyboy
2. Pebbles167
3. Blandy
Posted 25th Apr 2013 at 21:12
Post #50
Can someone put my name on the other list please? I haven't figured out how to copy and paste on an iPhone yet Roll eyes
Posted 25th Apr 2013 at 21:36
Pages (3): 1 [2] 3
