Red Rallye - Rolling "restoration"Wishbone Polybushes available
| Author | Subject: Front Wishbone bolt loose |
daver6
Seasoned Pro Location: Durham Registered: 08 Aug 2010 Posts: 2,379 Status: Offline |
Anyone had this happen to them? The front wishbone bolt working itself out of the subframe? ________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
mr swampy s16
**BAD SELLER** Location: out and about Registered: 22 Oct 2003 Posts: 10,550 Status: Offline |
Take it out pop a bit of threadlock on the part that goes in to the nut |
JWP EFi
have you got a lower brace fitted? this always usrd to happen to my mates 306. every week or so it needed nipped back up |
yes, happened on my brother's car, just tightened it back up (wishbones level of course) no issues since, can only think it wasnt seated properly________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
honestly3k
Seasoned Pro Location: Berkhamsted Registered: 06 Apr 2009 Posts: 2,390 Status: Offline |
This happened on my 6 and almost worked its way fully out and would've been a pretty horrific accident if I didn't have a nose under there when it started veering all over the road!Tightened it back up full strength and its been fine since ________________________________________ ''Oh, it does handle like a golf!'' Why drive a Golf....when you can drive a GTi-6? |
It's fairly common as the bushes age and perish, you can cure a lot of strange noises on old 306's by taking the bolts out, adding some lube and re-torquing them....My lower braces have a slight twist in them to give a little preload to stop them rattling out if they do slacken off, as it's quite common not to get the right torque on the bolts due to the nuts being exposed to the weather - bit of rust and s**t in there and they're not as tight as you think. ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
stan_306gti6
I've had one come loose. ![]() It didn't come right out though, but the car started to wander and was very much a handful when trying to drive at pace. It took three full turns to tighten up when I had a gander underneath and discovered it. ![]() Now, as a precaution I always check them periodically. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
daver6
Exactly the same with me, the car started to wander about. I've loctite'd it back in place, anyway ________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
luke89
Regular Location: Preston Registered: 28 Aug 2014 Posts: 486 Status: Offline |
Sorry for the thread revival.By front wishbone bolt do you man the one that goes through the front bush? |
jamiek_uk2000
Yeah, right at the front of the wishbone________________________________________ 205 GTi Red - G939 RTU - Died!306 GTi 6 Diablo - Being resurrected! Project Thread Looking for: VTS P1 Rack PR1.2 16" |
Goes into the threaded rectangle. ________________________________________ ![]() |
