displaying posts 1 to 25 of 33
Author Subject: Evans Powercool?
jamiek_uk2000
Has anyone on here got any experience in using Evans Powercool 180? I've heard some awesome reviews with people saying it is a must have for track days, especially since the 6 runs at such a high temperature anyway (Mine even higher when the head gasket went)
Since it doesn't boil till 180 degree's then there is no pressure in the system as it doesn't expand, so it is meant to put a lot less pressure on the engine aswell. I just wanted to know if there is anything to look out for when using it?
Plus does anyone know the capacity of the cooling system on a 6?
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 15th Jan 2013 at 23:38
swiftyboi006
Im sure the coolin system holds about 6 litres
Black p3 Love
Posted 17th Jan 2013 at 13:53
JWP EFi
Turbo Legend!
guy i know with a 300 odd bhp 205 turbo swears by this stuff, difference was night and day apparantly
Posted 17th Jan 2013 at 21:58
Expensive stuff and you need the prep stuff first as well Yes
Posted 17th Jan 2013 at 22:08
Worse cooling than plain old water.
Posted 17th Jan 2013 at 22:11
jamiek_uk2000
Well contrasting reports there, so still up in the air. I've read that almost anyone with a turbo/supercharger swears by it, but nothing so far on the N/A side of things.
What is so bad about it then Phillip, plus since your here what is the price on your lower strut braces and when are you expecting to get the uppers designed?
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 17th Jan 2013 at 22:25
JWP EFi
Turbo Legend!
£70 for 5 litres, whats the prep stuff?
1.) The amount of hassle needed to flush the system down plus filling it (plus carrying a bottle everywhere in case you spring a leak...)
2.) The price.
3.) It's worse at carrying heat away than water is. So the engine runs hotter.
Posted 17th Jan 2013 at 22:29
JWP EFi
Turbo Legend!
so whats the idea behind it? other than being good at preventing corrosion?
i remember watching a thing on wheeler dealers about this stuff, on an old Triumph because it didnt
rot the head gasket
Posted 17th Jan 2013 at 22:35
Making someone a lot of money is the idea behind it.
Posted 17th Jan 2013 at 22:38
JWP EFi
Turbo Legend!
i'm assuming this is similar stuff to 'Water wetter' that i put in my trials bike back in the day
Posted 17th Jan 2013 at 22:43
No, it's similar to just sticking pure glycol straight in the cooling system. 'Water Wetter' is a surface tension modifier, like washing up liquid.
Posted 17th Jan 2013 at 22:46
JWP EFi
Turbo Legend!
pointless then, other than stopping corrosion
Posted 17th Jan 2013 at 22:47
Has a higher boiling point ?
Posted 17th Jan 2013 at 23:00
Doesn't really help much when the engine would be overheating by then anyway Big grin
Posted 17th Jan 2013 at 23:54
jamiek_uk2000
Well I assumed (probably incorrectly) if you are running this in the car and it has a boiling point then the car isn't overheating because it is the water that is overheating in the car? The metal engine, gaskets and motor oil are all designed to much higher temps so it isn't overheating it is just running hot. Since the water isn't boiling there is nothing putting extra pressure on the system so shouldn't blow anything either?
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 18th Jan 2013 at 09:54
Also it just seems like one of those things where they are like
"Buy this, It doesn't matter how hot your engine is now"
Where are personally i would think, Just sort out your issue, or upgraded the cooling system properly.
The liquid is 70 quid but a new nissens rad is sometimes as low as 130
Then you have better fans etc which imo will all work out as better value.
Posted 18th Jan 2013 at 11:19
If the coolant is running hotter, then the hotspots they babble on about within the engine are running hotter, potentially leading to pre-ignition, plug failure, bearing failure because the oil will be taking so much more heat away, etc, etc.
Also, the pressure in the cooling system is sweet naff all even when boiling compared to internal pressures and oil pressure, etc. The only reason it looks so bad when you spring a leak is because once the pressure escapes the boiling point of the coolant drops and it all rapidly boils off, and with the expansion rate of steam compared the volume of water, it looks like massive amounts of pressure. It's not.
And of course, the problem there is, it's the leak that sets it off in the first place, not vice versa.
If you have a massively overkill cooling system and it's for a mueseum piece so you don't have to worry about coolant changes/corrosion, maybe you'd do it (Or just stick damn near straight antifreeze in) But otherwise. No.
Posted 18th Jan 2013 at 11:29
Museum piece you say Phil? Hmm
Posted 18th Jan 2013 at 11:57
LOL
You better order some for Wayne while you're at it.
Posted 18th Jan 2013 at 12:02
I'll be changing my coolant in early March mate, it's only been in there 18 months so not too long. Should be fine. Cool
Posted 18th Jan 2013 at 12:08
jamiek_uk2000
Decision made then, some distilled water and a good quality anti-freeze. I'll keep my mouth shut next time aswell Smile
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 18th Jan 2013 at 12:15
If you don't ask.....
Posted 18th Jan 2013 at 12:27
these engines run most efficiently around 88-89 degrees, so having a higher boiling point is, pointless.
Posted 18th Jan 2013 at 12:45
jamiek_uk2000
Ah right, that is the answer I needed. That's why when the head gasket went on mine it didn't like running at 110 in traffic then? Somehow the little thing has been parked up for 18 months whilst I get some money together, put jump leads on it and it started first time even with the old petrol in it. Who said that Peugeot are badly made cars!
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 18th Jan 2013 at 13:27
