displaying posts 26 to 50 of 741
Pages (30): 1 [2] 3 .. last
Author Subject: S16Turbo, Here we go again!
Takedown
Uhmm ive called him the 2nd time also again about the coils, he said use NGK BKR7E, no need to go for some fancy irridium ones, just copper, they extract heat from the cylinderhead the best, and that are the ones i need he told me....
And he told me specifically the BKR7E
Posted 25th Dec 2012 at 15:40
FatBastard
the 7 is 1 level colder than the regular part, afaik. I also have an iridium set 1 level colder. I moved to 2 levels colder once because every book on turbocharged recommended it (unless you get issues in idle).
I guess its another question to ask Pieter, once i succeed in contacting him.
Posted 25th Dec 2012 at 15:43
Takedown
Indeed, in the M3 with supercharger and 500+ bhp i also used one range colder, But just ask him what to use, he will tell you the same... Wink
Posted 25th Dec 2012 at 15:54
FatBastard
I'll swap the 7 in the next plug change. Smile
Posted 25th Dec 2012 at 16:17
Wow,awesome projectCool
Loving the grumpy dog helping out!Thumbs up
Posted 27th Dec 2012 at 11:09
Awesome project, keep up the good work Thumbs up
Posted 27th Dec 2012 at 11:23
Takedown
THx guys, having mayor problems with the custom cage, theyve made some big measuring errors, and it seems that this whole cage can go straight to the bin.
theyll come saturdayevening to inspect and do new and hopefully good measurements.
Mainhoop is to small, needs to be 10cm wider
frontlegs are way off! sit 20cm to low, not properly bend, etc etc etc
So the cage project is on hold, will start with the coilovers i think tomorrow
Posted 27th Dec 2012 at 16:13
marco gti6
That sucks mate Sad
Posted 27th Dec 2012 at 21:32
yippeekayay
Custom stirke again... I thought they stopped doing 306 cages last year as heard they had a few unhappy customers....they will sort it though I am sure. Ooops edit sorry custom....
x box "yippeekayaymofo"
Posted 27th Dec 2012 at 21:49
Takedown
Post #35
It was a custom cage, not FROM custom cages Wink
@ Marco, s**t happens bro... niets aan te doen.
Theyll make a complete new one, and one that fits! ive payed more then enough for it.
Posted 27th Dec 2012 at 22:19
rich306
Post #36
Hopefully sorted soon Smile
Richies Project Rallye
jamiek_uk2000 wrote:
- Top Tip!!!
Posted 27th Dec 2012 at 22:25
Takedown
Post #37
I hope so Rich...Wink Let us pray.. lol
Posted 27th Dec 2012 at 22:39
Post #38
Good to see you on here been following your thread on the other site for a while. I'll be interested in where you run the intercooler pipes as I'm looking to run a similar one myself soon. Need to mount 2 oil coolers behind it though ideally though.
Posted 28th Dec 2012 at 00:35
Takedown
Post #39
Armzs, you could go for the easy way and also the bad way, an intercooler with the inlet and outlet on one side.
My friends ZX build by DP engineering ( 5 years ago) came with that kind of setup, ive asked Pieter from DP what his thoughts were on that kind of setup now.... he said they would never use that type of intercooler again ( if hed said it its oke i would have used it since it makes it a lot easier)
The problem is with the big one im using is that i have to ditch the mesh in the bumper and the foglights, if you have a look at my first few pictures you can see that using a "normal" size intercooler will fit nicely and you can easily run the passengerside( your driverside) piping over the intercooler to the other side.
If you dont have airco theres also enough room to pipe it just behind the intercooler on the bottom.
Why would you run 2 coolers? im using one 12 row i think from Mocal, and there were no problems on the ZX with one , even with hard use.
Let me know
Posted 28th Dec 2012 at 09:29
Post #40
Supercharger oil and engine oil i assume? Smile
Posted 28th Dec 2012 at 09:47
Takedown
Post #41
, i had a Vortech V1 Ttrim with special impeller on the M3 (max 850BHP) that one just uses the engine oil for lubrication, i dont know if the rotrexes come with their own closedoilunit but i dont think that you have to cool that oil as wel.
the only supercharger that gets real hot as a freshlylaid s**t, is a (H)Eaton
Well as i was typing this, finally there was a postman ringing the door, about time with al this xmasbusiness.
New Zimmerman 330mm brakediscs are in
The old one are still failry good, but they look like s**t, new fresh ones will look much better and some holes are always nice.
Posted 28th Dec 2012 at 10:00
Post #42
Rotrex's have their own closed only circuit using MEGA expensive oil.
They arent totally comparable to other chargers as they are centrifugal and also spin at something silly like 100,000rpm
Posted 28th Dec 2012 at 10:13
Takedown
Post #43
Go look up Vortech V1 Ttrim
My friend holding the beast!
Posted 28th Dec 2012 at 10:42
Post #44
Yeh I'll be using a 13 row mocal oil cooler and already have the cooler for the rotrex supercharger fluid circuit. Need to take everything off the front and have a measure really.
Posted 29th Dec 2012 at 19:26
Post #45
Have you converted this to 5 stud hubs then?Dunno
Or re-drilling the discs to suite?Wink
Posted 29th Dec 2012 at 20:33
Takedown
Post #46
the discs are redrilled, gonna get that done next week(yearWink)
Well weve installed the SACHS race clutch and coverplate, the gearbox has been converted and ready for the pressureplate, tried to install the SACHS HD release bearing but that one didnt fit, so put in a stock one.
All installed and ready to go....
Installed sandwichplate for the mocal oilcooler, and oilfeed
Having a look at the swirlpot, wont be using the black hoses, most likely wil use the nice aero fittings and braided hose.
Bosch Motorsport 044 pump, and theres a Walbro 255LPH in the tank
If this is to much work for now, ill do it in a later stage...
MSD ingnition, need to make a new bracket for it
Modified cover for the MSD, stripped and ready for wrinkling!!!
They came over to have a look at the cage, and just what i thought theyre going to make complete new cage, took new measurements and i hope we wont have trouble with cage nr2.
Also ditched the front doorcards, and ordered 4 carbon doorcards, should be here in a week or 3 , since there made to order.
New pics soon!
Posted 30th Dec 2012 at 02:09
rich306
Post #47
They should've got the bloody measurements right the first time, idiots.
Looks good though buddy, liking the new shiny bits Razz
- Top Tip!!!
Posted 30th Dec 2012 at 09:50
Takedown
Post #48
Wel i ordered some carbonplates... and had a go at the glovebox
Ive got a spare one since ive made an error and got the first one the wrong way round, so perfect for you UK guys... make me an offer and its yours, its 1.5mm carbonfiberplate.
Just needs a bit of polishing or a new coat of clear
Voila a bit of clearcoat, (still needs polishing)
Fits nice, (note the car is very dirty and the dash looks blueish on the pics, but it al black inside)
Also finished the modded cover for the MSD ingnition coils
And painted the bells of the new 330ers, so they wont rust and look like s**t!
Posted 31st Dec 2012 at 12:52
Post #49
Where you order the doorcards from? I may give up with nur lol he is too busy
Posted 31st Dec 2012 at 17:14
FatBastard
Post #50
BTW, which type of Oil do you use for this engine, now that its going to be tripled in HP? Staying on the OE oil or moving to something more like 10W50 or 10W60?
Posted 31st Dec 2012 at 18:23
This thread has been locked
