displaying posts 251 to 275 of 741
Pages (30): first .. 10 [11] 12 .. last
Author Subject: S16Turbo, Here we go again!
Takedown
Post #251
Just get to it!!!!!!!!
Posted 13th Feb 2013 at 09:22
henrik c
Post #252
TE37 - alle measures?
xx108mm
65,1
wide?
ET?
Do they make those in 17"
/Henrik C
Posted 13th Feb 2013 at 10:59
Takedown
Post #253
Well some quick shots before we are installing everything by the end of the day, so hopefully we get everything wired in and do some picwhoring later on the evening.
Finish is absolutely perfect! and i love it!!
Also good to see that the 2 CF blankoff plates ive made fit good
Can only kick myself in the head for not having the a pillars done
More pics to come tonight!
Posted 15th Feb 2013 at 22:20
Takedown
Post #254
LMAO.....
Well we didnt get a far as we hoped, but the dashs in.... still need to connect some stuff, and wire the gauges etc etc.
But since we needed some pics for you guys..... we shoved some bits in their place and had a go.
Ill make some pics in daylight since the flash fcks things up...
Overal very happy with the result and itll look killer when finished.
some shots
Tomorrow some daytime pics Wink
Car is very dirty on the insde and will get some loveing when everythings in place
Posted 16th Feb 2013 at 22:33
mechanical_repairs
Post #255
Looks perfect. I do like that.
Carl
Posted 17th Feb 2013 at 09:22
jamiek_uk2000
Post #256
I want!
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 17th Feb 2013 at 09:25
Post #257
Thats awsome, did you make the carbon bits?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 17th Feb 2013 at 19:56
Takedown
Post #258
Yep Wink
Posted 17th Feb 2013 at 21:46
JWP EFi
Turbo Legend!
Post #259
takedown, what thickness of decompression plate are you using?
loving the flocked dash
Posted 17th Feb 2013 at 21:51
Takedown
Post #260
Heya mate, with this engine i wont be using a decompplate
This engine uses modified/weighed pistons wich brings it to 8.1 compression
check
http://www.dp-engineering.nl/shop-1/engine-internals.html?p=2
Posted 17th Feb 2013 at 22:00
JWP EFi
Turbo Legend!
Post #261
standard DP engineering plate with two gaskets wil get you 8.5 compression
dont take this the wrong way mate, but if your pistons were modified to give 8:1 then the crowns will be VERY thin,
to go from 10.4:1 down to 8:1 would need 3mm, possibly more machined off piston face
not unless your engine has pistons from another engine, such as the nissan SR20DET, which iirc share the same bore dia
and gudgeon pin dia
Posted 17th Feb 2013 at 22:10
JWP EFi
Turbo Legend!
Post #262
also, what fuel will you be running, E85?
I'm just curious to see how you guys are getting away with high boost and modified/stock internals
Posted 17th Feb 2013 at 22:24
Takedown
Post #263
I know, Pieter from DP said i shouldnt worry about that to much... but if it blows
ive got a S16 revised with DP decompplate and a stock revised motor on reserve... only means some more work to do when it goes boooom Wink
Posted 17th Feb 2013 at 22:28
Takedown
Post #264
Wont be running E85, that will limit me to much on using the car , since i know of only one pump that sells E85 and that one is 25km away
98 it will be...
You should drop Pieter a mail @ DP.... there are a lot of boosted peugs here on stock engines
Posted 17th Feb 2013 at 22:31
JWP EFi
Turbo Legend!
Post #265
98 it will be...
i contacted pieter about 2 years ago about decomp plates, he assured me the stock pistons and rods
can handle decent power/torque. I'm very tempted to go this route, but i would want to use ARP studs and nuts
as opposed to head bolts, but if i was to pay for decomp and studs then i may as well go for forged pistons.
plus i could rebore to 86.5mm to make 100% sure of a round bore
Posted 17th Feb 2013 at 22:44
Takedown
Post #266
What BHP you aiming for mate?
Posted 17th Feb 2013 at 23:13
JWP EFi
Turbo Legend!
Post #267
300 is my ultimate goal although i would be happy with 250, my car will be for road use, want to
keep up with some more modern machinery. a road car will benefit more from a smaller turbo
to gain the torque, but what i don't want is an engine than runs out of puff before 6000 rpm.
Big turbos will give horsepower but will only do so at high (er) rpm which wont suit a the road
For me its a balance between revs and torque
Posted 17th Feb 2013 at 23:27
JWP EFi
Turbo Legend!
Post #268
numbers are easy to think of, its what it drives like on the road
Posted 17th Feb 2013 at 23:32
Takedown
Post #269
Hmm never been out in a 2.0 16v with a GT28Rs i presume?... will spool a lot better and harder then the oldskool VAT25, wich was nice for that time, now just an oldskool turbo.
Friends ZX with GT28RS and DP plate , and 328BHP was a perfect roadcar, enough power to humiliate the "fast" cars
with your goal IMHO forged pistons is a complete waste of money, ditch the VAT25 T16 turbo, buy a GT28RS for the money you save instead of FPs, sandwichplate and your ready to have some fun...
Posted 17th Feb 2013 at 23:36
JWP EFi
Turbo Legend!
Post #270
ive got a reconditioned cosworth T3, but to use this with my T16 manifold, i will have to fit an external wastegate as there isnt enough space between the head and the turbine housing to use the bolt on cosworth wastegate.
i have been in a few sierras/escorts YB's and i love the feeling, lag, then 3000 rpm and its fun and games to the limiter
have since decided against VAT25, £1400 to rebuild mine and it would only be good for 260bhp
max reliably. this is according to my research and what turbo specialists say.
Posted 17th Feb 2013 at 23:49
Post #271
Wow loving the flocked goodies makes me want mine done now but that's a long way off getting done yet.
Posted 18th Feb 2013 at 00:25
Takedown
Post #272
Thx
Good thing youve ditched the VAT25, 1400 GBP to rebuild is crazy money, i know its a complex turbo..
but for far less money there are WAY better turbos out there indeed..
External wastegate shouldnt be the problem right...
Posted 18th Feb 2013 at 10:17
Takedown
Post #273
Well not much updates, put the heatresistant blanket on the bonnet, should prevent from fking up the bonnet Wink
crazy expensive stuff for only 50x50cm
And some random shots...
Ordered a new grille and a new logo... and ive got a nice idea!
Posted 21st Feb 2013 at 19:31
JWP EFi
Turbo Legend!
Post #274
this is pure 306 porn! how long till it's running? cant wait to see what power/torque its pushing
Posted 21st Feb 2013 at 19:40
marco gti6
Post #275
f**king awesome interior that is... aka Dutch GrimReaper LOL
PM on your way mate Wink
Posted 21st Feb 2013 at 19:45
This thread has been locked
