Team Moonstone
Team Working Aircon
| Author | Subject: Misfire |
rob_humphrey
Regular Location: St Austell Registered: 16 Sep 2011 Posts: 448 Status: Offline |
Post #51
Wheres the injector plugs mate________________________________________ Team Moonstone![]() Team Working Aircon |
MCH_GTi6
formerly mch Location: Hayle Registered: 09 Sep 2005 Posts: 2,456 Status: Offline |
Post #52
Manifold look for green plugs with white connector________________________________________ Team Moonstone� Ph3 GTI6Team Rallye |
rob_humphrey
Post #53
just ordered new lambda aswell incase it might be that also the car smells really rich and did 20 miles to 7 litres of fuel ________________________________________ Team Moonstone![]() Team Working Aircon |
Post #54
Unplug the lambda bud car will run without being plugged in |
rob_humphrey
Post #55
how do you unplug it mate?________________________________________ Team Moonstone![]() Team Working Aircon |
Post #56
Pull the red tab out and it will unplug then. ________________________________________ ![]() |
rob_humphrey
Post #57
meant to say where is it lol________________________________________ Team Moonstone![]() Team Working Aircon |
Post #58
Down behind the battery box towards manifold It's a big ish plug with a red bit that you pull out to disconnect the wire from the plug |
pugheaven
Seasoned Pro Location: Fareham Registered: 17 Dec 2006 Posts: 4,602 Status: Offline |
Post #59
Bloody hell, what's going on with this car, didn't give me any issues at all in the week I drove it |
pugheaven
Post #60
I wouldn't bother changing the lambda sensor or anything else until you change that coil, it's going to smell of fuel... It's getting the fuel just not igniting it |
rob_humphrey
Post #61
that lambda seems to of sorted it partly going to do coils as well but it;s running allot smoother now also just thought id share an epic fail with you as well, unplugged the lambda and took it for a drive went out of my road and couldn't find second gear at all so pulled over and the lambda connector had got jammed in the gear linkage . Olly the cars given me loads of grief nothing serious though. also the exhaust smells normal again not rich ________________________________________ Team Moonstone![]() Team Working Aircon |
pugheaven
Post #62
Well it is French lol don't think Tom had any issues with it, just bad luck I guess |
rob_humphrey
Post #63
yeah oh well ill get it sorted seems like the lambda sorted it so gave it bean's to get home and just as i got home it i put it in neutral and it spluttered all over the place and spluttered when i revved it its doing my f**king nut in________________________________________ Team Moonstone![]() Team Working Aircon |
Post #64
Just change the fecking coils dude Try unplugging the power steering sensor as well as that causes all sorts of funny running issues It's at the bottom of the front of the engine blue plug - follow power steering lines |
rob_humphrey
Post #65
Cheers mate ill get them done tommorow hopefully what i really need to know is can i do that test thingy without having to drive it until it misfires ie can i just unplug them while its on my drive without of being driven anywhere will i still hear a difference or do i have to wait for it to misfire?________________________________________ Team Moonstone![]() Team Working Aircon |
Post #66
Need to have the misfire happening to do the coil thing |
rob_humphrey
Post #67
Think ive just sussed what the problem is. whilst having a look at the sensor locations i saw that the intake air temp sensor looked different to mine so i went to have a look and on mine someone has twisted it so it point right instead of downwards as a result one of the little plastic bits has snapped off that holds it in position inside the inlet. going to order new sensor ________________________________________ Team Moonstone![]() Team Working Aircon |
stan_306gti6
Post #68
The intake air temp sensor won't be affected because the mounting tabs are snapped off. ![]() As for the unplugged plug on the MAP sensor wiring, this is normal it is a 'spare' plug on the loom. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
rob_humphrey
Post #69
well it wasn't sealing propperly and was hanging off ill take it out later see what happenes________________________________________ Team Moonstone![]() Team Working Aircon |
stan_306gti6
Post #70
If it wasn't sealing correctly, it would be sucking in air and therefore would make the mixture run lean not rich. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
swiftyboi006
Post #71
^ yep and you would be revving alot________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
Post #72
Doubtful given its a small hole and it has a map sensor.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
stan_306gti6
Post #73
swiftyboi006 wrote: ^ yep and you would be revving alot Nope, it would just have a tendancy to stall. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
rob_humphrey
Post #74
All i can smell under the bonnet if fuel lol deffo coil packs me thinks ![]() ________________________________________ Team Moonstone![]() Team Working Aircon |
Post #75
if you can smell fuel under the bonnet you have a leak...________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
