"Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6
2000 (X), Moonstone
| Author | Subject: Misfire |
stan_306gti6
It will probably be fouled and wet as it hasn't been firing properly/at all.________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
rob_humphrey
Regular Location: St Austell Registered: 16 Sep 2011 Posts: 448 Status: Offline |
Ah right thanks chaps________________________________________ Team Moonstone![]() Team Working Aircon |
swiftyboi006
^ exactly what i meant i should explain myself more ![]() ________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
stan_306gti6
![]() Spend some more time reading your post then before you post it. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
swiftyboi006
CBA always on my phone, just type and post f**k it ![]() ________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
swiftyboi006 wrote: CBA I'm a lazy khent EFA (typed form my phone )________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
swiftyboi006
^what that fhek whit said________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
stan_306gti6
![]() Fair enough then. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
rob_humphrey
Update just started taking the plugs out and number 1 plug is really black at the end so hopefully this is the problem ________________________________________ Team Moonstone![]() Team Working Aircon |
Post #35
It will be the coil dude |
swiftyboi006
Post #36
The coil on that plug is shafted get it changed :thimbsup________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
rob_humphrey
Post #37
right only posted that after pulling one plug out they were all blackish but mainly brown so surely all the coils havent gone? took it out and its still exactly the same might try lambda and ecu coolant temp sensor what do you guys think?________________________________________ Team Moonstone![]() Team Working Aircon |
rob_humphrey
Post #38
oh forgot to add there was brown oily stuff on all four plugs take it this is normal________________________________________ Team Moonstone![]() Team Working Aircon |
Post #39
One of the coils is iffy Next time it does it pull over while its miss firing and start disconnecting the injectors one at a time till you unclip one and it makes no difference = that coil is th problem |
rob_humphrey
Post #40
okay mate but it only missfires when revving it________________________________________ Team Moonstone![]() Team Working Aircon |
Post #41
rob_humphrey wrote: okay mate but it only missfires when revving it Rev it by hand on the throttle body while disconnecting the injectors one at a time. If you unplug one and it makes no difference then change that coil ? All the others will make the car run really badly when disconnected It's a process of elimination to find the dodgy coil |
rob_humphrey
Post #42
thanks mate ________________________________________ Team Moonstone![]() Team Working Aircon |
rob_humphrey
Post #43
Also would itbe down performance wise if the coil was dodgy________________________________________ Team Moonstone![]() Team Working Aircon |
honestly3k
Seasoned Pro Location: Berkhamsted Registered: 06 Apr 2009 Posts: 2,390 Status: Offline |
Post #44
Yes your car would be 25% down on power as running on 3 cylinders________________________________________ ''Oh, it does handle like a golf!'' Why drive a Golf....when you can drive a GTi-6? |
rob_humphrey
Post #45
Thort it didnt feel right sounds like a scooby to sounds s**t________________________________________ Team Moonstone![]() Team Working Aircon |
honestly3k
Post #46
Yes my matey boy matt had this issue, car sounded wicked imo but didnt go wicked ![]() ________________________________________ ''Oh, it does handle like a golf!'' Why drive a Golf....when you can drive a GTi-6? |
rob_humphrey
Post #47
yeah sounds beefy as you like so just to check can i go out tomorrow morning and unplug those coils one by one to see the difference or does it have to be just after it misfires?________________________________________ Team Moonstone![]() Team Working Aircon |
stan_306gti6
Post #48
Whilst it is misfiring would be a good idea, but yes as soon as you notice it, pull over and unplug the injectors one at a time until you find that you unplug one and there is no difference to the running of the engine. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
rob_humphrey
Post #49
Ive got to unplug the injectors too ![]() ________________________________________ Team Moonstone![]() Team Working Aircon |
swiftyboi006
Post #50
If all the plugs are the same when its misfiring then maybe the injector isnt putting any fuel in? Just a thought. Make sure all the injectors and pluged in correctly________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
