displaying posts 51 to 75 of 118
Pages (5): first .. 2 [3] 4 .. last
Author Subject: Examples of induction?
Post #51
Laugh my ass off
Here's one of mine Razz
Posted 2nd Dec 2012 at 17:24
Post #52
looks standard to me Unsure
Posted 2nd Dec 2012 at 17:45
Post #53
Laugh my ass off
Laugh my ass off
Excellent!
Posted 2nd Dec 2012 at 18:55
24seven
Post #54
That's such a p**s-poor bodge of a job Mei. It's not even finished! Razz
Posted 2nd Dec 2012 at 19:09
Post #55
Wont make it go any faster with no injectors thats for sure
Posted 2nd Dec 2012 at 19:11
Post #56
They're underneath Wink
rad left out for mega ram air effect Big grin
Posted 2nd Dec 2012 at 19:12
blandy
Post #57
are you going to run a filter with your bodies? got same set up soon to go on my rallye but gotta get a filter squeezed in which is going to be fun
Posted 2nd Dec 2012 at 19:19
Post #58
why are the injectors underneath? clearance or something? or suparpowarrr?
Posted 2nd Dec 2012 at 19:21
Post #59
I guess the hole is blanked off then Smile
Posted 2nd Dec 2012 at 19:23
Post #60
yes will have filter, yes injectors underneath for clearance. Smile
this manifold I wont be using though as it doesn't fit in the ZX under the bonnet with a filter, might fit a 306 though.
Posted 2nd Dec 2012 at 19:30
Post #61
aaron6 wrote:
I maintain that the best all round set up is the standard set up with a modified airbox running a decent filter. You don't have to worry about puddles, it sounds reasonable and gives a good sharp throttle response. I've tried and seen lots of different methods and for my liking this is the best all rounder. Smile
Don't let the resident airflow expert 24seven see you write that!!!!!Shock
No way does it work better,he worked it out on a piece of A4 between breaks of learning his 9 times table you know.........Roll eyes
I'll say it again,it does not work on paper!Whistle
You NEED to have a 306 standard snorkel piped into them to get the max performance out of that set upYes
No way will you gain anything having nice cold air going straight into those TB's and into your engineNo
I've been converted by 24seven the air intake expertThumbs up (on paper he is anyway)Roll eyes
Posted 2nd Dec 2012 at 20:40
24seven
Post #62
coskev wrote:
grumpy old man ramblings
24seven wrote:
For best performance, leave the standard air box in place if you're using the standard manifold. If it's just the noise you want, do whatever.
Forget to put on your reading glasses?
Posted 2nd Dec 2012 at 20:49
Post #63
Laugh my ass off love this thread!
Posted 2nd Dec 2012 at 20:50
swiftyboi006
Post #64
Laugh my ass off
Black p3 Love
Posted 2nd Dec 2012 at 21:17
woody.
Post #65
LOL at this thread. Tbh, I highly doubt the 'ram air' style thing makes any noticable difference to the standard setup?
Oops almost forgot to put IMO!!
Posted 2nd Dec 2012 at 21:29
Post #66
You've moved the intake from the postion of high static pressure (low airspeed due to blocking from the radiator and cowling), to an area of low static pressure (high airspeed due to venturi effect between bonnet and slam panel)
That's not ram air, that's exactly the opposite in fact.
Where's the 'FAIL' smiley when you need it? Smile
Posted 2nd Dec 2012 at 21:36
Post #67
... thus I propose we declare this phenomenon "gay air" LOL
Posted 2nd Dec 2012 at 21:39
Post #68
Thats all well and good,very cleverThumbs up
But why out of the three types of intake I've used does my car drive better and create good power with it like this?
Not that I'm really interested TBHBig grin cause I'll be leaving it as it is because it worksThumbs up
Posted 2nd Dec 2012 at 22:35
Post #69
Finished your homework early chav?Thumbs up
Posted 2nd Dec 2012 at 22:36
24seven
Post #70
Laugh my ass off
Though on a serious note, I hope you don't react like this when hearing your daughter "talk academically"... For her sake!
Posted 2nd Dec 2012 at 22:38
dan86
Post #71
Wouldn't the surface area of a cone filter in the standard airbox be less (causing more of a restriction) than a performance filter that fits full length inside the airbox?
Posted 2nd Dec 2012 at 23:06
24seven
Post #72
No Think of it like this. If you pull your jumper sleeve over your mouth and try to breathe through it, you can feel the restriction through the thicker material. Now go into your mrs' drawer and do the same thing through a pair of her tights.
The idea with cone filters is that you trade off having poorer filtration (and thus dirtier air going into the engine) in exchange for easier breathing. That's the reason standard panel filters are so much bigger and have so much more surface area than aftermarket cone filters - the holes the air passes through are smaller so you need more holes to flow the same volume of air = bigger filter.
Posted 2nd Dec 2012 at 23:14
playboyb
Post #73
I'm so happy I started this thread Thumbs up
306 1.8 xs moonstone blue-SOLD
306 gti6 supercharged china blue-SOLD
406 coupe D9 3.0 V6-SOLD
Posted 2nd Dec 2012 at 23:17
dan86
Post #74
My Mrs just walked in on me nestling my face into her tights and inhaling heavily... Awkward!
Do K&N use a different filtration material on their cone filters than their direct replacement filters?
The reason I ask is because in my opinion a cone filter that is small enough to fit in the airbox must have a smaller surface area than a direct replacement. (Comparing cone and direct fit performance filters made from the same filter material)
Posted 2nd Dec 2012 at 23:31
24seven
Post #75
They're both the same type of filter with a paper medium, whereas something like a pipercross uses foam. The K&N will have a coarser "print" in it allowing more air through, but they have a light oil soaked into them to help trap the fine particles that wouldn't normally get through, hence you can wash and re-oil them.
Posted 2nd Dec 2012 at 23:42
