displaying posts 126 to 150 of 289
Pages (12): first .. 5 [6] 7 .. last
Author Subject: the ZX 16v thread
Post #126
Don't throw away the stale fuel.
Rikky can make use of it to dunk his knuckles in to harden the skin. He loves a brawl that boi.
  • Posted 7th Jun 2013 at 11:44
    Post #127
    I didn't, I put it back in and it runs fine LOL
    Posted 7th Jun 2013 at 12:33
    atterz
    Post #128
    Love it, what a nice motor!
    owain wrote:
    Posted 7th Jun 2013 at 12:39
    Takedown
    Post #129
    The master @ work Wink
    Posted 7th Jun 2013 at 19:22
    Post #130
    whoah, time flies!
    its been sat outside the garage for a few months again as I stuck the 205 inside, not dome much to it really, I sorted the weeping brake unions and bled the brakes again, and more recently just been waiting for a friend to have some spare time to weld it up for me, we did think of making a start on it today but he has a house he's painting for his dad which is dragging on a bit unfortunately, so I took it to bits again...
    20140727_121701 by WELSHPUG, on Flickr
    Unplugged the engine loom...
    20140727_121859 by WELSHPUG, on Flickr
    Faffed about with the auxillary loom adding a few plugs and wrapping it in tape, then added the DTA loom I had made, made up the last few connections to mate it to the car temporarily, then bolted the bodies on...
    20140727_173322 by WELSHPUG, on Flickr
    yes, I do have a rusty looking rad, but it doesnt leak, AND I have an alloy ordonez rad spare I can fit to it if needs be.
    I then thought, errr, allI need is to bung a coilpack on and it "should" run....
    so I did! https://flic.kr/p/ocNe87 (video link)
    Big grin
    Posted 27th Jul 2014 at 21:14
    Post #131
    Sounds nice. Love
    Posted 27th Jul 2014 at 22:18
    Post #132
    I jumped a bit when it hit the limiter on the base map, its one Sandy sent to DCC to get his 8v running, 5k rpm LOL
    need to swap the wideband from the 205, and get a laptop plugged in and make sure the sensors are all reading, check the rpm outout settings the rev counter flickers when cranking but nothing else, set an idle speed and calibrate the tps.
    also need to buy or make a stepped backplate to clear the trumpets and the longer full height gti6 injectors, or blank them, or use shorter pico style from a 182.
    Posted 27th Jul 2014 at 23:03
    RetroPug
    Post #133
    Sounds really good.
    Posted 28th Jul 2014 at 00:12
    Post #134
    Get it welded!!!
    Posted 28th Jul 2014 at 07:36
    Post #135
    waiting for Anton! bloomin house in usk has been dragging on but he's finally finished painting it!
    Posted 28th Jul 2014 at 11:16
    russbez
    Post #136
    LOL f**k me that noise was ace
    My Rallye project thread
    Posted 28th Jul 2014 at 11:33
    RetroPug
    Post #137
    Agreed, makes me wish I could afford an ITB setup.
    Posted 28th Jul 2014 at 19:36
    Post #138
    Not that expensive really when you do it the way I have.
    Satchell inlet manifold - £180.
    Bodies (91mm TH's, with the aim to use a longer manifold) £435 the pair.
    Fuel rail (not really needed, as you can use the standard one, or go twin injector) £66.
    Trumpets (may change to satchell ones, but these are jenvey) £100.
    ecu, £400 off ebay unused but pre-owned.
    Wiring stuff, £60 (made the loom myself)
    filter - donated by a mate.
    no silly linkage kits, these are direct pull type, just need a cable stop bracket, saving a good £90-100!!
    total before mapping, £1181
    Posted 28th Jul 2014 at 19:52
    Post #139
    Agreed ....sounds amazing Mei .....when you selling them to me ?
    Posted 28th Jul 2014 at 21:24
    RetroPug
    Post #140
    Thank you for the cost breakdown.
    I can't afford individual throttle bodies YET. Big grin
    Good job in September will slowly begin to change that I hope!
    For the sake of spending a bit more while you're at it...is it a good idea to get pistons pocketed and put 'hotter' cams in at the same time? That would add quite a lot to the overall budget though.
    Posted 28th Jul 2014 at 23:13
    Post #141
    they are pocketed and theres newman ph2's in there Smile
    Posted 28th Jul 2014 at 23:28
    Post #142
    I wasn't surprised one bit to read that from you Mei LOL ....
    Get it finished Thumbs up
    Posted 28th Jul 2014 at 23:38
    tsd167
    Post #143
    going to be a very nice zx
    are you going to run twin injectors?
    Posted 29th Jul 2014 at 19:03
    Post #144
    I dont need to but I can yes, one set is just plugging the holes at the moment LOL
    Posted 29th Jul 2014 at 22:55
    Post #145
    Progress!
    borrowed Antons trailer!
    20140730_170124 by WELSHPUG, on Flickr
    though when I pulled up Anton was making funny faces looking at the trailer, I hadn't realised the nearside rear wheel was steaming away, what with Dan sticking his arm in the way of the mirror all the time, and Diesel smoke going down that side of the car too LOL
    20140730_175749 by WELSHPUG, on Flickr
    looks like a lining had detached itself and got wedged, cooking all the grease from the wheel bearing too!
    in the workshop jacked up already
    20140730_175903 by WELSHPUG, on Flickr
    Posted 31st Jul 2014 at 12:19
    tvrfan007
    Post #146
    Where you up to with this now? Continuing refurb? Smile
    I'm Si btw Tee hee
    Night Blue VW Golf GTD
    Posted 6th Aug 2014 at 16:24
    Post #147
    my mate Anton has done the welding, he's just sorting a windscreen which might be done Saturday.
    Posted 6th Aug 2014 at 18:07
    Post #148
    A few weeks have passed, Anton has waves his weldy torch over the grotty bits, and finally this evening he dragged it back for me, he'd lashed up a quick throttle cable bracket from some wire to aid moving it LOL:
    Thought I'd best make a proper bracket and see if I could get full travel without lifting the pedal too far, or having to bury it in the carpet.
    a bit of steel angle, a rivnut, a threaded adjuster barrel and a 90deg v-brake noodle and I have myself a £90 saving on a Jenvey linkage kit.
    20140821_204632 by WELSHPUG, on Flickr
    20140821_205738 by WELSHPUG, on Flickr
    20140821_205802 by WELSHPUG, on Flickr
    oh yeah it has a new windscreen too Smile
    Posted 22nd Aug 2014 at 07:40
    Post #149
    more progress after work this evening, as my bodies are short and I have long trumpets, and normal length Weber gti6 injectors I needed a stepped backplate, these are usually over the £50 mark, but inspired by Kristian (Black_Mi16) who had made his own stepped backplate from some sheet steel, I cracked on with some C.A.B.A.D*
    20140822_174904 by WELSHPUG, on Flickr
    (*Cardboard And Beer Aided Design)
    20140822_181739 by WELSHPUG, on Flickr
    20140822_183116 by WELSHPUG, on Flickr
    20140822_183507 by WELSHPUG, on Flickr
    Bolted the centre piece under the trumpets to figure out where the injector securing bolt reliefs needed to be.
    20140822_190223 by WELSHPUG, on Flickr
    Transferred the design onto some steel sheet.
    20140822_191317 by WELSHPUG, on Flickr
    chopped it out.
    20140822_194531 by WELSHPUG, on Flickr
    carried on chopping and a bit of holesaw action, had nothing to hand to do the radius cut unfortunately, but it wont hurt to have some flat edges instead of curve.
    20140822_202131 by WELSHPUG, on Flickr
    Posted 22nd Aug 2014 at 20:50
    Post #150
    I did finish off the airbox, not 100%^ happy with it, I haven't much experience of welding tin and I put a bit too much heat into some parts so its not as flat or pretty as I;d like it to be.
    20140823_084153 by WELSHPUG, on Flickr
    20140823_121759 by WELSHPUG, on Flickr
    You'll notice it now has more black panels on it now, I am thinking of making the whole car black as with the old shell.
    20140823_134811 by WELSHPUG, on Flickr
    Found a few of my trim clip bags though I still need a few more, some parts will need sticking on with some structural automotive adhesive.
    20140909_183209 by WELSHPUG, on Flickr
    moved the radiator fan across to the left side and fitted an Alloy Ordonez radiator I'd got hold of, then had a fiddle about with an oil cooler to see if I could make it fit without spending loads on new pipes, gentle persuasion of the steel hard pipe and shifting some brackets on it means that no longer fouls, but the low pressure feed from the reservoir needs re-routing a little so its not rubbing on them constantly (I plan to retain the standard heat exchanger as it aids warmup, and using the thermostatic control on the oil cooler to stop it over cooling at the same time as adding extra cooling capacity)
    20140903_190109 by WELSHPUG, on Flickr
    20140903_194332 by WELSHPUG, on Flickr
    rear seats and cards fitted.
    20140905_163733 by WELSHPUG, on Flickr
    Posted 10th Sep 2014 at 14:04
