displaying posts 1 to 25 of 49
Author Subject: Oil Pump Sprocket Design
Disco_Stu
Hello,
When I was at my last track day I had a conversation with another 306 owner who gave me lots of advice of different bits and pieces.
The main one that concerned me was a comment around the oil sprocket. He said that on the earlier models the oil pump sprocket is just held in place with the torque of the bottom pulley bolt. However on the newer engines it is driven using the woodruff key.
I can't for the life of me remember which mine had (I think it was the older style).
He mentioned that you can fit the new 'woodruff' style sprocket to the older engines.
My questions:
> Can the new style sprocket be retro fitted?
> Is it worth while? he mentioned about the sprocket slipping whilst changing down on track?? (is it really an issue or no problem as long a torqued up correctly)
Stuart
Peugeot 306 Gti-6 Track car (soon to be supercharged)
Project page
Blog
Posted 16th Oct 2012 at 21:12
clen666
I think most people recommend fitting the newer design, I've not heard of any failures but they must have changed it for a reason
Team 'unintentional rat look'
Posted 16th Oct 2012 at 21:22
jeffers Forum Admin
Yes the new style can be fitted no problems it is a direct replacement, it's about £17 from pug so if you happen to have the engine apart yes it's worth changing for peace of mind. Thumbs up
EDIT* I've not heard of a failure in anger but they can be known to slip after a cambelt change presumably due to incorrect torque BUT something that drives on friction alone can't be a good thing.....
Team Running Engine again!
Team Negative Camber!
Posted 16th Oct 2012 at 21:41
miles
Yes you just need the Drive gear and key, Pain to fit as the belt and sump has to come off, the only time I have known them not to work is after a belt replacement, all the 205 1.9 and Mi16's use the same idea, strange as the 1.6's are key'd
www.pugracing.com
Posted 16th Oct 2012 at 23:12
I changed mine to the later design a few years ago on a previous engine. Yes
I didn't fancy taking the chance of it ever slipping. It probably won't as long as you keep the torque correct on the crank pulley, but I wanted the piece of mind that it was key driven. Wink
Posted 17th Oct 2012 at 06:17
Disco_Stu
Thanks for the feedback guys Thumbs up
I think I will just check the torque for now, but if I need to do anything in future around that area I will get it changed
Project page
Blog
Posted 17th Oct 2012 at 17:56
could always give it a few spots of weld Smile
Posted 17th Oct 2012 at 18:12
What? Onto the crank? Erm?
Posted 17th Oct 2012 at 18:39
no, fecking eejit LOL: weld the sprocket to the keyed hub!
Posted 17th Oct 2012 at 18:54
LOL
Think for the price of it (around £17) I'd rather fit the later design. Yes
Posted 17th Oct 2012 at 18:56
rich_w
I have seen several engine failures as a result of loss of oil pump drive - I change the oil pump sprocket to the later single piece type on all the engines I build.
You also need an extra O ring for the crankshaft, which the ones with the earlier drive don't require.
Contact Details:
07732 822546
Posted 18th Oct 2012 at 08:43
O ring you say Hmm
Stan?
Cry
  • Posted 18th Oct 2012 at 09:03
    jeffers Forum Admin
    dangti6 wrote:
    O ring you say Hmm
    Stan?
    Cry
    This ^^ can somebody tell me what ring i need before I refit my sump in the next day or two?? Sad
    Posted 18th Oct 2012 at 09:08
    O ring slides onto the end of the crankshaft before the oil pump drive goes on IIRC.
    Its a pretty thin looking little beastie and it's easy to forget about (Which I have done!) Dry
    Posted 18th Oct 2012 at 09:11
    jeffers Forum Admin
    Hmmm best get myself on servicebox and have a look.... And il wear my glasses this time!! LOL
    Posted 18th Oct 2012 at 09:13
    Rich E Forum Admin
    0514 92 - 47p all in.
    Posted 18th Oct 2012 at 09:14
    jeffers Forum Admin
    Thank you Rich your a star! Big grin
    Posted 18th Oct 2012 at 09:15
    24seven
    If it's been built properly then I wouldn't worry too much. When you think about it the only thing stopping the timing slipping out of place on the '6 engine is the friction of a single bolt through the camshaft pulleys (on the later design) although they can't slip beyond a certain point. On a lot of modern engines they have plastic pulleys and no mechanical keying whatsoever, purely the friction of the bolt.
    Posted 21st Oct 2012 at 22:19
    Yeah, the woodruff key should only be for location and last resort, the actual drive should transfer through the clamped faces.
    Posted 21st Oct 2012 at 22:23
    With the woodruff key though you do have that extra security. Smile
    Posted 22nd Oct 2012 at 09:44
    24seven
    Have you seen how small they are? They're not designed to take much force at all.
    Posted 22nd Oct 2012 at 11:21
    Maybe, but the crank sprocket itself drives off of it. Yes
    Posted 22nd Oct 2012 at 12:22
    naah, as phill said its the clamping force of the bolt that holds it in place, all the key does is locate it.
    Posted 22nd Oct 2012 at 16:49
    Well yes, but it's still a good fail-safe. I'd rather have it than not. Yes
    Posted 22nd Oct 2012 at 18:50
    jeffers Forum Admin
    Well i've bought and fitted the extra o'ring today before closing up my new bottom end, although i dont really understand what that o'ring does its as it should be! LOL
    Posted 24th Oct 2012 at 18:45
