displaying posts 1 to 25 of 52
Pages (3): [1] 2 3
Author Subject: o ring in thermostat
ajmckeane
I have a slight leak coming from my thermostat area. I have taken it apart and found a split o ring in the house that bolts on to the stat. I have visited Peugeot today whobgave me an I ring but not the one I need. They've provided me with the o ring that fits round the stat.
Anybody know the part number for the other o ring within the black housing? Cheers
China's ALIVE !!!
Posted 16th Oct 2012 at 20:07
Providing you have the later design hose, the part number you're after is: 1343 Z4.
Hope this helps. Smile
Posted 17th Oct 2012 at 06:23
ajmckeane
Yes that's helpful Stan. Only thing is servicebox doesn't seem to recognise the code any reason for that?
China's ALIVE !!!
Posted 17th Oct 2012 at 08:58
You don't need to put the code into Servicebox, just call up the Pug dealer and give them the part number. Yes
I think it costs around 80p. Wink
Posted 17th Oct 2012 at 12:05
anyone got an exploded diagram of the thermostat / seal? i've got a BBM 205>gti6 adapter on my engine and haven't seen any mention of using an o-ring within this (other than the one which sits around the edge of the thermostat in a recess). is there another one?
Posted 17th Oct 2012 at 12:24
ajmckeane
There is one in the black housing that comes off of the stat. As far as I can see it's not listed as a separate part. Comes with the hose when you buy it. However Stan assures me that 1343 z4 is the same size. Will find out this afternoon
China's ALIVE !!!
Posted 17th Oct 2012 at 12:28
well the black housing is what is different on the gti6 engine when using the 205 BBM adapter, so i am not too worried. yet. i am sure it'll be p**sing out and not sealing properly when i run it but i'm sure i'll sort it
Posted 17th Oct 2012 at 12:33
Rikky, There's a flat O ring that goes inside the 205 metal water pipe.
The BBM adapter (when bought new) comes with an O ring where it joins the 205 metal water pipe.
To be sure, I used both and it's still drier than your sense of humour.
  • Posted 17th Oct 2012 at 12:46
    i don't have an o-ring. the adapter i bought was pre-sealed to the outlet takeoff. i was going to just gasket-seal this onto the thermostat housing but i guess i'll need the little o-ring then inside. part number 1343 Z4??
    i will ring and order one IMMEDIATELY
    then my enormous build can continue
    Posted 17th Oct 2012 at 12:59
    hang on isn't that the same part no for the bottom rad pipe fitting ring?
    if so, i bought one for my gti6 when it started leaking. but instead of fitting it, i broke it up for spares. FTW
    anyway the bbm adapter is like 60mm dia from memory so it won't be that Unsure
    Posted 17th Oct 2012 at 13:00
    the correct part number for the top hose is actually the part number for the earlier bottom rad hose o-ring not the later one that stan posted up
    stan_306gti6 wrote:
    1343 Z4
    its the same diameter but slightly fatter.
    I deduced this by cross referencing the plastic elbow (1336 J4) to the 406 as its used on all XU7J4's and 10J4R's, where the o-ring is listed separately with the top hoses, 1339 94 (DIAM INT 31 EP 3,6)
    therefore, STAN IS WRONG ! Shock and rikky scrapped a 306 because of Stan! Shock Cry
    AFAIK Rikky you don't need anything other than the standard thermostat seal with the BBM adapter as long as its the early type that does away with the plastic elbow, they have a new type now which does use the plastic elbow.
    Posted 17th Oct 2012 at 13:08
    LOL stan you owe me a china blue 306 Angry
    i'm using the metal elbow from the early 205's not the plastic one with the bleed screw in it
    gti6 had to go, 205 gti6 would not have been possible otherwise Hyper
    Posted 17th Oct 2012 at 13:35
    Just grab an O ring from somewhere to fit inside your 205 metal elbow.
  • Posted 17th Oct 2012 at 13:37
    "from somewhere" - thanks, that really narrows it down
    LOL
    i was going to just loctite 5910 the s**t out of everything and cross my fingers
    Posted 17th Oct 2012 at 14:06
    An O ring shop then.
  • Posted 17th Oct 2012 at 14:07
    1343 Z4 is the same o-ring which is used on the top hose and the newer style lower rad hose. Yes
    It's only listed on Servicebox as part of the lower hose, but it is in fact used in both places.
    Just to avoid any confusion, I am giving you the part number for the o-ring which fits on the end of the top hose which fits inside the black plastic elbow housing. Am I understanding it correctly now that you want the o-ring which seals between the black housing and the aluminium thermostat housing? If so, then Welshpug is right it's a completely different part. Yes
    Posted 17th Oct 2012 at 17:12
    woody.
    OP do you see what you've started now?! O ring debate FTW!!!!
    Posted 17th Oct 2012 at 17:31
    there is no o-ring there stan, and its not the same one on the top hose.
    Are you sure as I'm 100% positive the o-ring which fits the top hose is the same as the lower hose. Yes
    Posted 17th Oct 2012 at 18:38
    yes I'm sure, and I have explained why in my post up there Smile
    Yes, indeed you did.
    I have also just looked up a 406 XU10J4R engine for the same part. It quite clearly states that the part you're referring to: 1339 94 is the seal required UP TO RPO 07275.
    The seal part number is indeed 1343 Z4 for vehicles ONWARDS from RPO 07276.
    This is the reason I stated that if the OP had a later type hose he would need part number 1343 Z4. Smile
    Posted 17th Oct 2012 at 19:02
    But they are the same? Dunno
    Posted 17th Oct 2012 at 19:10
    Kick his ass Stan!
  • Posted 17th Oct 2012 at 19:19
    LOL
    It's not a case of that, I just know that they are the same part. Yes
    Posted 17th Oct 2012 at 19:22
    stan_306gti6 wrote:
    LOL
    And here is the thread from 2010 to prove it: Clicky
    Welshpug evens agrees it's the same part in this thread...LOL
    Posted 17th Oct 2012 at 19:27
    Stan is correctThumbs up
    Was just about to find my thread from when I askedSmile
    Posted 17th Oct 2012 at 19:47
    welshpug's post has disappeared LOL
    luckily google cache has it still so we can all laugh at him. everyone, after 3.. 2.. 1..
    LOL
    i actually googled the part number and found others using it for the bottom seal anyway Yes
    Posted 17th Oct 2012 at 19:50
    Pages (3): [1] 2 3
