displaying posts 26 to 50 of 52
Pages (3): 1 [2] 3
Author Subject: o ring in thermostat
ajmckeane
Well all I can say is the part Stan told me I needed was indeed the part inside the black housing.
GO STAN !!!!!
China's ALIVE !!!
Posted 17th Oct 2012 at 20:07
GO STAN !!!!!
No worries mate, glad you got it sorted. Thumbs up
Posted 17th Oct 2012 at 22:04
rikky wrote:
welshpug's post has disappeared LOL
luckily google cache has it still so we can all laugh at him. everyone, after 3.. 2.. 1..
LOL
i actually googled the part number and found others using it for the bottom seal anyway Yes
I can't believe he deleted the post, you can't be right all the time...LOL
Posted 17th Oct 2012 at 22:09
woody.
Dammit, gotta update that meme now Angry
Posted 18th Oct 2012 at 01:26
woody.
There we go Smile
Posted 18th Oct 2012 at 01:28
gilesy
Posted 18th Oct 2012 at 01:37
woody.
^^^^ Serious cat is shameful of welshbug No No
Posted 18th Oct 2012 at 08:39
LOL
There may well be only one top hose, but the sealing ring for it is still 1343 Z4. Yes
Where's that banging head on wall smiley? Crazy
Posted 18th Oct 2012 at 14:20
i am actually confused about what is being debated here now
Posted 18th Oct 2012 at 14:53
Post #35
for the rad hose:
1339 94 for the early connector
1343 Z4 for the later connector
apparently
Posted 18th Oct 2012 at 15:00
Post #36
I'm not confused about anything...No
Welshpug - Why you have argued a point regarding a part number I don't know. It was proved that the number you posted was incorrect in another thread (which you agreed with) then you go and delete a 2 year old post because you have contradicted yourself. It doesn't make sense. The bottom line is the OP asked for a part number, which I gave him. You then argued for 2 pages that it was the incorrect one and low and behold the OP buys the part and it's correct. Information dug out of another thread also proves this point and yet there's still a problem? Dunno
Posted 18th Oct 2012 at 15:32
Post #37
CAN O WHUPASS..
Seeing as Stan can't seem to read any more, or accept that he's not correct, I'll have to do it with pictures.
see, no o-ring listed with the hoses, so I think, HMM wonder if I'll find it with the thermostat plastic elbow...
oh, thats a shame, Peugeot have made a balls up, most people would have given up or bought a new top hose.
but no, I think HMMM... what other engines use the same elbow...
AHA! seems like its anything that has used an XU10J4R or XU7JP4, so I go hunting, is it with the thermostat?
Nooo, is it with the hoses I wonder?.....
BINGO!
Posted 18th Oct 2012 at 16:59
Post #38
Razz
Flip
Geek
Posted 18th Oct 2012 at 17:35
Post #39
GO STAN !!!!!
Enough said. Wink
Posted 18th Oct 2012 at 19:12
Post #40
-1 Meh
still not the right part, too thin.
Posted 18th Oct 2012 at 19:17
Post #41
So how come you are suddenly correct now and yet in Coskev's thread from 2010 (where your reply has been magically deleted) you also stated it was part 1343 Z4? Dunno
Posted 18th Oct 2012 at 19:20
Post #42
I did not state it was, I merely said it might be that number, I did not say it was.
I did some research, and found what I believe to be the correct part, the one you said was right is too thin.
the pics are there to explain it.
Posted 18th Oct 2012 at 19:21
Post #43
So the two parts are both 31mm in diameter, one is 3.6mm thick and the other 3.5mm thick.
So you're arguing the point over 0.1mm?
Besides that, there have been loads of threads on here where people have asked if they can source that o-ring separately as it appears it only comes with a new hose. The answer EVERYONE of them has got is the 1343 Z4 number and they've all bought it and fitted it and had no problems. Wink
Posted 18th Oct 2012 at 20:15
herukano
Post #44
Well this thread is a bit of a bonus for me at the moment , ive just changed my thermostat as it was stuck open . I got an o'ring from peugeot along with my thermostat but when i took out the old stat there wasn't an oring there so i didnt fit it as without a frame of reference i couldnt really work out where it went ,
does it:
A. sit on top of the thermostat between it and the black elbow
B. wrap it round the lip of the black plastic housing like a gasket ?
i orginally tried to wrap it around the lip on the housing (like b.)but it doesnt like to stay there so gave it up as there wasnt one there to start with.. its Number 10 on the above diagram.
any help you guys can give me would be good thanks
Posted 21st Oct 2012 at 21:30
Post #45
Number 10 wraps around the thermostat.
Posted 21st Oct 2012 at 21:57
herukano
Post #46
hmm misread drawing then as that one is fitted .... pug gave me a normal standard O'ring (no slit for wrapping around anything) any ideas ?
Posted 21st Oct 2012 at 22:02
Post #47
got a part number on the bag?
Posted 21st Oct 2012 at 22:16
herukano
Post #48
Good idea , didnt think to check part numbers !
it was not on the bag but was on the invoice , 134030 .
I do appear to have a small leak from the thermostat elbow , and this O'ring is described as a thermostat gasket .
Or do people use some silicone or loctite stuff ?
Posted 21st Oct 2012 at 22:38
Post #49
Ah, wrong one then, pic above shows 1340 48, no need for any sealant with the correct seals.
Posted 21st Oct 2012 at 22:51
herukano
Post #50
thanks for your help so far
ok so to be sure:
Peugeot gave me the wrong part ?
My thermostat has a rubber ring around the circumference already (came in the box) so i dont need that , just need the Gasket for the elbow to housing ? whats the right part number for that ? is that the 048 ?
Posted 21st Oct 2012 at 23:04
Pages (3): 1 [2] 3
