displaying posts 226 to 250 of 1018
Pages (41): first .. 9 [10] 11 .. last
Author Subject: My 306 Dimma project, Mainly photos
eddy_gti6
Post #226
Any more pics of your fuel system setup inside the car?
Posted 9th Nov 2013 at 23:40
pugheaven
Post #227
not yet, ill grab some tomorrow but its still a work in progress, if you type in AN6 PTFE on ebay you will see all the parts you need, they are a pain in the arse to make but once you got the hang of it its pretty easy, marking the unions whilst making them isn't so easy..
You can buy proper vice jaws to make things easy but I didn't bother Doh
Posted 9th Nov 2013 at 23:46
eddy_gti6
Post #228
I probs wont be making them anyway. Will leave that for my mate to do haha
Posted 10th Nov 2013 at 00:11
pugheaven
Post #229
Not a very big update again but got a few little bits done
Fitted the carbon boot lid and catch pins to see how much work is needed to make the best out of a s**t fitting boot lid... Not sure if you can see but the bottom part of the boot is not parallel with the bottom panel, the bottom of the boot has not been trimmed straight and is arced so there is a bigger gap in the middle than at the ends....The top part of the boot lid hits the roof when I try to open it so some trimming will be required, I have compared the shut lines to my other car which has a 5mm gap all the way down the side whilst the carbon has anything from 5-10mm Sad good old nur-motorsport! Not sure if im going to be able to sort the shut lines but I will do my bloody best!
I then went and got some high tensile bolts for my top mounts and strut brace, Iv never seen another one of these strut braces in my whole time of pug ownership (10 years) I love how it hugs the bulk head and fingers crossed it can stay fitted as I don't think installing the engine will be an issue with it in place
Posted 15th Nov 2013 at 16:39
pugheaven
Post #230
Forgot to add that I fitted the bottom mount with a group "A" fork bush that i got from baker bm
Posted 15th Nov 2013 at 16:52
pugheaven
Post #231
I know its a bit pointless installing the rest of the cage at this point but I really had a bad feeling that it wasn't going to fit properly due to it being manufactured out of the car so tonight I decided I would test fit it Crazy
The bolts are not done up tight but at least all the bolts fit lol
Bit tight in places and needed to lever the rear cage away from the shell to get the door bars in Unsure
Posted 19th Nov 2013 at 21:32
pugheaven
Post #232
I kind of wish that I placed the windscreen bar higher up so that it was actually against the roof but I copied my safety devices cage and that's where it was located on that...
I have decided this is my last ever build and next time I will buy a car that's already done, don't get me wrong I love getting my hands dirty and starting from scratch but its so time consuming and expensive
Posted 19th Nov 2013 at 21:35
eddy_gti6
Post #233
Looking good mate, making good progress on this.
Posted 19th Nov 2013 at 22:01
pugheaven
Post #234
Trying to do as much as I can at the mo as work have asked me to go back out to afghan again in feb, I said I would never go again but the money has made me think twice lol
Thanks for giving me the dimensions of that cooler but I think im going to either use the rs500 set up if not ill be getting pro alloy to make me a custom rad and cooler!
I should be getting my flocked dash back next week and im going to send my hubs of to get machined this week so hopefully ill be able to crack on over Christmas rebuilding the car while I get some work done on the engine
Posted 19th Nov 2013 at 22:15
pugheaven
Post #235
I got my flocked dash back today so I sorted out the wiring and reinstalled it
Hopefully get this fitted tonight or tomorrow
Went and got the steering rack mount from the grey car today do I should be able to fit the accelerator pedal, I also got the heater unit from the grey car as it's got a new'ish matrix fitted
Posted 25th Nov 2013 at 17:26
pugheaven
Post #236
Cracked on with the car last night and this morning :-)
Fitted the heater unit and blanked off the air outlets so that it only comes out of the windscreen vents, tightened the fuel and brake line bulk head fittings, fitted the rest of the pedals and then finally fitted the dash and connected all the electrical connectors, I then fitted the wiper motor just to finish that area off
This afternoon iv really got to send my hubs off to bridgecraft engineering as iv been meaning to do it for a while and could really do with having them back so I can get the dimma back on it's wheels
Posted 26th Nov 2013 at 16:10
pugheaven
Post #237
Well that's the hubs sent away now so I came home and did a little more
First on my list to do was hoover the inside of the car out and take out all the rags etc that I used to protect the floor whilst I was messing around inside.
Looks a lot tidier and cleaner inside now, iv still got to securer the loom to the floor
I then made some carbon panels to cover the 2 fuel tank access holes ( I will need to cut 2 holes in the smaller panel for the supply and return fuel pipes
Not sure if I will keep it on there but I decided to heat shrink the handbrake handle for those cold track day mornings lol
When I was down the flock shop I noticed he had flocked some rocker covers and was surprised when he said that the flock will cope with the heat so that made me think...
I was going to get the engine bay fuse box and ecu box hydro dipped in carbon but after a little think I didn't really want fake carbon after all the money spent on real carbon so iv taken the plunge and given him my fuse box to do to see how it comes out...
I cut the battery box off of the ecu box so that is ready to be taken to get flocked once I see how the fuse box looks
Im starting to come to a work stop again until I manufacture some seat subframes and start to strip the super high boost
I will probably get the original dimma wheel up to the wheel specialists soon and get them done in gloss black and then its time to strip Rich W's old car, take the engine to lynx, get loads more bits powder coated etc and then carry on rebuilding it over the Christmas holiday
Posted 26th Nov 2013 at 16:13
pugheaven
Post #238
Balls, iv only just noticed after looking at the pic that the weave of the carbon for the fuel tank covers are different direction Angry sod it im not making another one and don't want to many fixing holes so they are staying like that now Whistle
Posted 26th Nov 2013 at 16:19
Post #239
i couldn't live with that if i'm honest
Posted 26th Nov 2013 at 16:20
pugheaven
Post #240
Meh... I could make another one at a later date but I'm too itchy atm
Posted 26th Nov 2013 at 16:36
eddy_gti6
Post #241
Wish i could be bothered to put this much effort into my 205! Inside is looking very tidy there Cool Coming on well
Posted 26th Nov 2013 at 17:37
rallyestyle
Post #242
Great work mate, keep going! I ever i had the time and the money this is the kind of thing i have dreamt of doing! Thumbs up
Just Drive It
Posted 29th Nov 2013 at 20:36
pugheaven
Post #243
Ah balls, I just did a tidy up of my photo bucket account as I had lots of duplicate photos and now iv lost lots of pics on this thread Thumbs down
Posted 8th Dec 2013 at 09:32
pugheaven
Post #244
Got a little more done to this but not a great deal and not a lot more I can do without stripping Rich's old car and even then im waiting for my hubs, straight cut gear set etc.
I will try and replace the pics that have been deleted one day as this thread is a good place for me to store all the hard work that I have put into it if I ever come to sell the car
Tidied the wiring up inside and secured it to the shell
Iv got loads of braided line now so have started to route that but again I am at a loose end literally until the engine is in
Posted 17th Dec 2013 at 18:07
pugheaven
Post #245
As iv sold the kw's that were fitted to rich's car I decided to strip the rear beam and fit my powder coated parts to it to make it look a bit cleaner
This beam will only be used until I get the wide track beam sorted so its not as clean or refurbished like everything else that has been fitted to this car
Fitted my new powder coated baker bm mounts and coated mounting frame/brackets along with powder coated brackets for the new brake lines and handbrake cables
Posted 22nd Dec 2013 at 21:52
eddy_gti6
Post #246
Cant wait to see the final thing. Going to be show room condition Cool
Posted 22nd Dec 2013 at 22:32
pugheaven
Post #247
One with it fitted to the car, trying to fit a beam on your own sucks
Posted 23rd Dec 2013 at 13:40
superchargedblack1997gti6
Post #248
Looking good buddy this is a truly great restoration should be around for many years to come.
Posted 23rd Dec 2013 at 13:53
jamiek_uk2000
Post #249
I fitted my beam on my own. I swore a lot
Looking for:
VTS P1 Rack
PR1.2 16"
Posted 23rd Dec 2013 at 13:58
Post #250
Same. Laugh
Posted 23rd Dec 2013 at 14:36
