£85 posted
Phase 1 bianca white GTi-6:SOLDPhase 2 blaze yellow d-turbo:Off to scrap heaven
Phase 2.5 platinum silver GTi-6:Just purchased :-D
| Author | Subject: Rich_W Alloy Crank Pulley |
astragsi237
Regular Location: Chatham Registered: 13 Mar 2009 Posts: 414 Status: Offline |
Change of mind /plans leads me to stick this up for sale! Bought from Rich a week ago,Brand new & still in its packaging.£85 posted ________________________________________ Phase 1 bianca white GTi-6:SOLDPhase 2 blaze yellow d-turbo:Off to scrap heaven Phase 2.5 platinum silver GTi-6:Just purchased :-D |
astragsi237 wrote: Change of mind /plans leads me to stick this up for sale! Bought from Rich a week ago,Brand new & still in its packaging. £85 posted Failed to undo the bolt then |
astragsi237
Yup It just wouldn't give in so the originals staying on________________________________________ Phase 1 bianca white GTi-6:SOLDPhase 2 blaze yellow d-turbo:Off to scrap heaven Phase 2.5 platinum silver GTi-6:Just purchased :-D |
jbradders
Regular Location: Strood Registered: 01 Dec 2008 Posts: 150 Status: Offline |
If you want to try getting it off again I've got a makita cordless nut gun it removed my mates one.I'm from strood as long as your from Medway in Kent. |
jord294
bigbadbowen wrote: astragsi237 wrote: Change of mind /plans leads me to stick this up for sale! Bought from Rich a week ago,Brand new & still in its packaging. £85 posted Failed to undo the bolt then ![]() ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
fatlapit
EPIC FAIL LOL________________________________________ |
astragsi237
jbradders wrote: Thanks for the offer pal but my cordless didn't get it un done,nor did a air gun :-S I've run out of ideas,so its up for sale If you want to try getting it off again I've got a makita cordless nut gun it removed my mates one. I'm from strood as long as your from Medway in Kent. ________________________________________ Phase 1 bianca white GTi-6:SOLDPhase 2 blaze yellow d-turbo:Off to scrap heaven Phase 2.5 platinum silver GTi-6:Just purchased :-D |
An air gun wouldn't undo it? What is it powered by, a foot pump?Don't give up. ________________________________________ ![]() |
dangti6 wrote: An air gun wouldn't undo it? What is it powered by, a foot pump? Was it a decent brand gun?surprised me what a difference a snap on gun made compared to a unbranded one ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
Ingersol rand air gun I have at work will breeze it off... Lol your gonna need to get it off next time you need a cambelt done so don't give up with it matey .________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
paulvancraen
Junior User Location: Breda Registered: 24 Jun 2009 Posts: 83 Status: Offline |
Stick it in fifth, let someone step on the brakes (hard)Or if the engine is out of the car you can use a flywheel locking tool (from midlock for example) Then get a 5 ft. long pipe and put that over the extension (don't use your ratchet for this, it will break) My 320Nm airgun also failed to loosen it... The above method works garantueed |
paulvancraen wrote: Stick it in fifth, let someone step on the brakes (hard) Or if the engine is out of the car you can use a flywheel locking tool (from midlock for example) Then get a 5 ft. long pipe and put that over the extension (don't use your ratchet for this, it will break) My 320Nm airgun also failed to loosen it... The above method works garantueed ![]() do you think thats good for the clutch though? ________________________________________ Red GTB1756 powered Fabia VRS daily driver,LBSC Gti6 eater........Mac1 ZR R1 kit car build in progress. |
paulvancraen
How else are you going to loosen it with the engine in the car? (if the airgun doesn't work...)I've done this a number of times and never had any problems with it ![]() You can always get a bigger airgun though |
jmh306
Regular Location: Eastbourne Registered: 03 Aug 2009 Posts: 321 Status: Offline |
Removed mine in the car with a long extention bar and a long pray bar with a axel stand to support the extention bar. Fly wheel was locked off aswell.________________________________________ FB: South Downs French Car ClubDiablo 6 2001 low boost Diablo 6 2000 100% standard working air con Vw Caddy tdi work van |
barnettjd77
Regular Location: dorchester Registered: 12 Nov 2011 Posts: 483 Status: Offline |
pelt it with a hammer and a long bar, vibratiions always loosens things on the agricultural front ![]() ________________________________________ A red rallye in progress! |
Seasoned Pro Location: Southwark Registered: 18 Jul 2010 Posts: 4,865 Status: Offline |
Dont be a pussy, f**king get a massive pole on it.________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
edhunter
Regular Location: Sofia Registered: 29 Nov 2009 Posts: 118 Status: Offline |
Is the pulley still for sale?If yes, I am interested. |
