displaying posts 51 to 75 of 106
Pages (5): first .. 2 [3] 4 .. last
Author Subject: D9 V6 Coupe
calibra306
Post #51
playboyb wrote:
eddy_gti6 wrote:
playboyb wrote:
eddy_gti6 wrote:
What gets too hot? Oil? I wouldnt know as my oil temp guage doesnt work in the 306 witj the d8 engine. Water hardley ever sees above 80oC. May have to get an oil temp guage fitted in
Yes mate the oil does like to get a tad warm Smile
Ahh looks like am going to have to sort out a temp guage then. Been looking at an oil cooler as the filter adapter is the same as the gti6 filter only the v6 filter is slightley longer. I got a good wiff of burning oil after i have been giving it some for more than 10mins what is usually everyday on my way to work Laugh my ass off
Yeah mate oil cooler would certainly improve things, mine gets upto 100 degrees easy so watch out for it Thumbs up
Cant say what an inprovement an oil cooler will be as ive not got the V6 back yet but make sure you get a decent size one ie 16 row and also one that comes with the bigger pipe size as is needed on the V6 for better flow rate and also get a thermostat sandwich plate otherwise the oil will be constantly cooled which is not good as the oil needs to be at a certain temp to work at its best.
V6 Power!
Faster I can go the better!
Posted 20th Dec 2012 at 12:45
playboyb
Post #52
What he said! Thumbs up
306 1.8 xs moonstone blue-SOLD
306 gti6 supercharged china blue-SOLD
406 coupe D9 3.0 V6-SOLD
Posted 20th Dec 2012 at 16:11
rallyeash
Post #53
1/2 BSP fittings will suit fine
309 3dr K20 Type R
Posted 20th Dec 2012 at 19:01
playboyb
Post #54
Anyone know if its been done before?
Posted 20th Dec 2012 at 21:39
eddy_gti6
Post #55
Hmm interesting
Posted 20th Dec 2012 at 23:55
calibra306
Post #56
Not from what i have read! 5/8 is best for the V6 fine is never good enough lol
V6 Power!
Posted 20th Dec 2012 at 23:59
eddy_gti6
Post #57
Will see what i can find. What size does BSP fittings does the gti6 use?
Posted 21st Dec 2012 at 00:15
heliosphan
Post #58
Sam, nowhere near good enough. 50% of the shot is out of focus. Fire your photographer and hire a new one. Or at the very least get him/her to clean the lens.
Has anyone asked Adam if he's okay with everyone derailing his 306 GTi thread with your 406 coupe/derived engine chatter?
Bloody inconsiderate...
Posted 21st Dec 2012 at 00:18
eddy_gti6
Post #59
Here we go ebay
They can supply in 1/4 or 5/8
Posted 21st Dec 2012 at 00:22
Post #60
It's fine. There is a take off extender spike thing and probably a sandwich plate on the 807/806 and Clio v6s. The espace/vel satis might have one too.
You've got a different front end on yours - is it the later style or an eccosse one?
Posted 21st Dec 2012 at 09:20
eddy_gti6
Post #61
Adam did you get the Oil temp gauge working on the 306? or where is the best place to wire one in if you know?
Posted 21st Dec 2012 at 09:56
playboyb
Post #62
Adam has a v6 coupe aswell, so I'm sure he won't mind Smile
Posted 21st Dec 2012 at 11:12
Post #63
Yes it connected to the normal oil temp gauge. Straight connection.
Xsi doesn't have one in the dash then?
Posted 22nd Dec 2012 at 16:59
eddy_gti6
Post #64
The xsi clocks are the same as gti6 clocks. The oil level works with the ignition on but no oil temp. Onky thing that doesnt work. Where is the oil temp sensor on the v6 D8 engine? Any ideas?
Posted 22nd Dec 2012 at 22:42
Post #65
on the front of the engine near the oil filter.
Posted 22nd Dec 2012 at 22:55
eddy_gti6
Post #66
Thanks, will have a look through the week
Posted 22nd Dec 2012 at 23:08
Post #67
Update:
I'd blown the standard rear JBL 6x9s after the headunit equalisation was modified by Nico. Just finished fitting some JBL GTO938s I found very cheap on the 'bay. Needed a bit of spacing, but now sounds like I have a sub in the boot, just incredible bass!
After fitting the mount the car has felt really together and drives very well indeed. The only thing I don't like is the lack of damping over crests. The front end sort of floats, but then you get loads of damping come in with more than (what feels like) 25mm of compression. Guess its just Peugeot damping it as a GT car. Shame really, although I do have some new B4s for the front sat in the garage. Hmm.
Posted 1st Jan 2013 at 17:06
Post #68
I think they have a 'dead' spot machined in the internal damper tube the last time I chopped one up for a nosey. Helps the ride but probably what's giving that initial floaty feeling.
Posted 1st Jan 2013 at 17:14
Post #69
It feels like its been put there on purpose. It is a very good compromise, just a little alarming at mach 2 over a crest with a corner the other side. But then you have the rear to slide out of line if you need a hand finding the apex again. Never feels like 1400+ kgs
Posted 2nd Jan 2013 at 10:10
playboyb
Post #70
It does feel a tad floaty over some bumps but it handles surprisingly well for something that's 1500 kgs, I'm really liking mine to be honest, might be staying for a while Smile
Posted 2nd Jan 2013 at 10:39
Post #71
New wheels on yet? Hyper
Posted 7th Jan 2013 at 13:05
Post #72
Only just found some tyres. Been busy...
Posted 8th Jan 2013 at 09:58
Post #73
O rly? Shifty
Posted 8th Jan 2013 at 10:47
Post #74
Yeah 4x 5mm contisport 3s for 150 quid delivered. Going to 225/45/17 so quite a big width increase as the 205 pilot sports are narrow tread.
Hope to have the wheels sorted on saturday. Hope they clear the brakes...
Posted 9th Jan 2013 at 18:16
Post #75
Clear the brakes easily Yes
Posted 9th Jan 2013 at 19:35
