displaying posts 1 to 25 of 46
Author Subject: Front Hub nut removal
footah212
Anyone got a handy tip about how to get this fecker off?
Tried a big f off breaker bar loads of heat and it still won't budge. Do I need an impact driver or something? Maybe just a scaffold tub on the breaker bar?
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 6th Sep 2012 at 20:21
Impact gun or 2 weetabix and breaker bar.
  • Posted 6th Sep 2012 at 20:23
    footah212
    I had 92 kgs on the bar not sure another 4g will make much differenceLOL
    Not got an impact gun . Scaffold tube it is then
    Phase 2 Blaze GTi6
    PS3 - Black Ops 2
    Posted 6th Sep 2012 at 20:28
    bas_306gti
    breaker bar and with a long tube over it will do the job and somebody to push the brake
    Posted 6th Sep 2012 at 21:08
    gilesy
    I tried once to take my hub nut off. I had a 6ft bar with 2 people on it and someone pressing the brakes also.
    Only thing that happened was the square drive going into the socket twisted off the bar like it was made of cheese. Gave up after that LOL
    Posted 6th Sep 2012 at 21:12
    This. Yes
    2 metre long piece of exhaust tube over a 20" breaker bar with the vehicle being put in 6th gear and an assistant having their foot hard on the brake pedal has always done the trick for me. Smile
    Posted 6th Sep 2012 at 21:23
    Rich E Forum Admin
    If you can get an open-centre wheel such as a standard spare on then undoing them on the ground with the car in gear is a good way if you haven't got an impact gun.
    Posted 6th Sep 2012 at 21:26
    footah212
    Yeh it's on the ground with a c5 steelie on it. I' ll grab a scaffold tube from work tomorrow and give that a bash.
    The rear of the car is on stands at the moment , should be be ok if I got someone on the brake yeh? Or lower back end down do you think?
    Phase 2 Blaze GTi6
    PS3 - Black Ops 2
    Posted 6th Sep 2012 at 21:39
    Personally I would lower the rear end down if you have that option, just purely from a safety point of view.
    Posted 6th Sep 2012 at 21:43
    footah212
    Think I will , otherwise I'll probably break three or four other items when trying to fix one as per usual.
    Phase 2 Blaze GTi6
    PS3 - Black Ops 2
    Posted 6th Sep 2012 at 21:48
    i wouldn't keep trying with a breaker bar, you'll probably f**k the threads on the driveshaft. impact gun is the best bet. i would only attempt anything with a breaker bar on the wheels with all the wheels on the ground, but impact gun off the ground will be fine
    Posted 6th Sep 2012 at 21:56
    footah212
    Do you mean I might round the nut? Can't workout how the driveshaft thread could be damaged. Don' t have access to an impact gun.
    Phase 2 Blaze GTi6
    PS3 - Black Ops 2
    Posted 6th Sep 2012 at 22:03
    no you won't round the nut, you will f**k the threads on the shaft which the nut is attached to. i have had similar experience with stuck hubnuts before i used an impact gun. i used varying scaffold poles and extension methods for the bar and every time myself or a friend did it, the thread on the driveshaft was ruined and you were unable to refit the hubnut. if it's too tight for a breaker bar i'd get an impact gun on it that way you are not putting prolonged stress on a fine thread
    Posted 6th Sep 2012 at 22:05
    footah212
    Now I get what you mean.
    Phase 2 Blaze GTi6
    PS3 - Black Ops 2
    Posted 6th Sep 2012 at 22:09
    An impact gun is indeed best, as it will 'shock' the nut and thread, although I've never had a problem with using the breaker bar method. Wink
    Posted 6th Sep 2012 at 22:16
    just get a 6 foot bar and jump on it, the nut will either come loose or the knuckle on the bar snap.
    wont damage the threads.
    Posted 6th Sep 2012 at 22:17
    footah212
    Scaffold tube and breaker bar it is. Cheers lads.
    Phase 2 Blaze GTi6
    PS3 - Black Ops 2
    Posted 6th Sep 2012 at 22:20
    Let us know how you get on, I'm sure you'll be fine. Yes
    As Welshpug says, I have had the knuckle on the breaker bar snap before (luckily it was under lifetime warranty) but I've never ripped a thread out with the nut. They are quite sturdy items anyway. Thumbs up
    Posted 6th Sep 2012 at 22:24
    Roll eyes
    Posted 6th Sep 2012 at 22:26
    footah212
    I'll let you know tomorrowThumbs up
    Phase 2 Blaze GTi6
    PS3 - Black Ops 2
    Posted 6th Sep 2012 at 22:58
    Scaffold tube And pull up instead of push down or jump, I ind it more controlled to pull the bar up, no chance of smashing the knuckles and it makes you feel hard when it does crack off
    andrew315rawson@live.co.uk
    Moonstone phase 7 gti6
    Posted 7th Sep 2012 at 01:39
    jord294
    You are using the correct 35mm socket aren't you?
    Posted 7th Sep 2012 at 01:59
    smegal
    car on the ground and a jack under your breaker bar
    Ex SC-6
    Now in a Megane R26
    Posted 7th Sep 2012 at 02:47
    tvrfan007
    I've never had any grief getting them off. I put my car's steelie on, put the car down, used either 1/2" drive or 3/4" if i had one, put an axle stand next to the wheel centre to support the short extension, take the dead weight and prevent droop/twist of the bar, then jumped on the end. Works a treat. Smile
    I've never damaged a drive shaft thread though, can't understand what happened there really.
    I'm Si btw Tee hee
    Night Blue VW Golf GTD
    Posted 7th Sep 2012 at 05:24
    A more commonly available 36mm impact socket is fine. I've undone umpteen and never rounded one.
  • Posted 7th Sep 2012 at 07:24
