It's a 1998 Ph1 VTS in a lovely puke yellow/green which has covered 77k.
Will be broken up in the next couple of weeks while I rinse it of it's remaining MOT.
I'l be keeping the gearbox, steering rack and probably the rear trailing arms for my 205. Therefore the beam will probably be dismantled if I do this so the 21mm bars will be for sale.
Not going to write a huge list as the car won't be hanging around for long.
77k engine complete with loom and all ancillieries. Good, quiet runner £400
Unlocked ECU £50
Pair of shafts £50
Shocks and springs £30 pair
21mm Torsion bars £80
Front brake setup with discs and pads £80
Rear calipers £40 pair
2 week old exhaust backbox (Was £90 new) £40
Obviously a few other components are '6 compatible such as indicator stalk and some other bits and bobs inside.
Everything is available. As mentioned it won't be broken for a couple of weeks, but when it is it will be gone within a couple of days so shout if you need anything. May be a couple of Xsara lurkers on here.
