so, the question is; who has used them? and did they produce any judder or noise in their operation?
Red Rallye - Rolling "restoration"Wishbone Polybushes available
| Author | Subject: Clio Pads |
daver6
Seasoned Pro Location: Durham Registered: 08 Aug 2010 Posts: 2,379 Status: Offline |
Hello, I know you can run Clio 172 pads with our callipers and that they're 1mm smaller in all dimensions, so, the question is; who has used them? and did they produce any judder or noise in their operation? ________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
JWP EFi
Why would you want to do this? i would imagine they would move about in the caliper, |
jeffers
Forum AdminLocation: Leeds Registered: 14 Dec 2003 Posts: 3,702 Status: Offline |
I use clip fitment pads in my track car the only noise is when you reverse, they shift in the caliper causing a clunk, apart from that absolutely no problems! jsa666 wrote: Why would you want to do this? i would imagine they would move about in the caliper, Because Carbon Lorraine rc6's are over £50 cheaper in clio fitment! So I can deal with a slight clunk when reversing to save over £50 in a car that very rarely reverses! ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
Seasoned Pro Location: Southwark Registered: 18 Jul 2010 Posts: 4,865 Status: Offline |
Cheaper :p I thought they were the same though ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
jeffers
eliotrw wrote: Cheaper :p I thought they were the same though There is a slight size difference but for the saving it's worth it, it's as said above roughly a mm in pad length iirc. ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
JWP EFi
jeffers wrote: I use clip fitment pads in my track car the only noise is when you reverse, they shift in the caliper causing a clunk, apart from that absolutely no problems! jsa666 wrote: Why would you want to do this? i would imagine they would move about in the caliper, Because Carbon Lorraine rc6's are over £50 cheaper in clio fitment! So I can deal with a slight clunk when reversing to save over £50 in a car that very rarely reverses! ahhh, he didnt say he was wanting to fit uprated pads! i suppose if you wanted to be fussy you could always fit anti rattle spring clips to stop the clunk when goin from reverse |
jeffers
jsa666 wrote: jeffers wrote: I use clip fitment pads in my track car the only noise is when you reverse, they shift in the caliper causing a clunk, apart from that absolutely no problems! jsa666 wrote: Why would you want to do this? i would imagine they would move about in the caliper, Because Carbon Lorraine rc6's are over £50 cheaper in clio fitment! So I can deal with a slight clunk when reversing to save over £50 in a car that very rarely reverses! ahhh, he didnt say he was wanting to fit uprated pads! i suppose if you wanted to be fussy you could always fit anti rattle spring clips to stop the clunk when goin from reverse I don't know if the op wanted to fit uprated pads, I was just throwing in my experience of possible noises and my reason for using them. As for the cost of standard pads in Clio fitment compared to pug fitment I wouldn't know really. But if there was a small saving to be had IMO it would be worth using them, just turn the stereo up when reversing lol! ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
I've got a mate who is using 182 pads and they asked me to let you know that they work fine. ![]() ________________________________________ Goldie the track car. |
daver6
Thanks chaps!It's the use of the smaller pads I'm asking about as the M1144 pads are a cheaper than Pug specific. I'm obviously just concerned that 1mm is quite a size difference ________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
jeffers
daver6 wrote: Thanks chaps! It's the use of the smaller pads I'm asking about as the M1144 pads are a cheaper than Pug specific. I'm obviously just concerned that 1mm is quite a size difference They work fine, as I say just a slight clunk when reversing. ________________________________________ Team Running Engine again!Team Negative Camber! My Budget track engine build thread! Now appearing at a Trackday near you!! |
Buy a 172 to go with them ![]() ________________________________________ ![]() |
daver6
dangti6 wrote: Buy a 172 to go with them ![]() Haha, good thinking. I knew I was missing something! The only Clio I'd have has a Williams badge on it ![]() ________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
spiky
Seasoned Pro Location: Cardiff Registered: 13 Oct 2006 Posts: 2,310 Status: Offline |
i'm running clio calipers on the rear and 205 pads mintex 1144i run RC5+ on the front, might go for rc6 next ________________________________________ Do you need a 205 > 306 gti6 plug and go engine loom? PM METORQUES for all your braided fuel line needs MY YouTube Videos' SUPERCHARGED 205 GTI6.... are you Fooking nuts!.... ummmm YIP ![]() 268+BHP and 860kg = FUN |
They're the same Steve ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
I'm running a 205 caliper on the back of my Clio. Winner.________________________________________ ![]() |
I'm runing no calipers on my clio WINNER |
daver6
I think I'll give these a go what's the worst that could happen? ![]() ________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
crash and die in a big fireball of fury?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
daver6
haha! If that does happen, Rallye owners can add another £20 to the asking price________________________________________ Red Rallye - Rolling "restoration"Wishbone Polybushes available |
