Well i need a new rear beam so if you have a good one spare, i could meet you half way for a swap
***Breaking*** Ph3 Silver GTI 6 High Boost
displaying posts 26 to 41 of 41
Pages (2): 1 [2]
| Author | Subject: Free bottom end |
6waysforward
Seasoned Pro Location: Benfleet essex Registered: 30 Oct 2005 Posts: 3,168 Status: Offline |
pete_rallye wrote: I'd like this but not collecting it from Essex! If anyone happens to be heading from Essex to or past Yorkshire on the M1/A1 I'd happily offer you some petrol money for bringing it up! Well i need a new rear beam so if you have a good one spare, i could meet you half way for a swap ________________________________________ ***Breaking*** Ph3 Silver GTI 6 High Boost![]() |
pete_rallye
Seasoned Pro Location: Yorkshire Registered: 12 Dec 2002 Posts: 5,253 Status: Offline |
I have a beam and lots of new bits but it's very much a work in progress at the moment! Plus it's destined for my race car once completed... ________________________________________ Oulton Park in a BTCC 306 vid 1Oulton Park in a BTCC 306 vid 2 Lap of the 'ring |
pete_rallye
rikky wrote: does someone pay you to kill engines pete? surely you haven't broken another? Nope, just not fixed the other one(s) yet. Block is mashed so need a decent block, or 2... ________________________________________ Oulton Park in a BTCC 306 vid 1Oulton Park in a BTCC 306 vid 2 Lap of the 'ring |
ash
Six Addict Location: Chelmsford Registered: 25 Mar 2003 Posts: 7,520 Status: Offline |
Pete I can pick it up and store it for you until you need it. |
ash
.... Until you are passing! |
I'm could also find a home for this Ash ![]() ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
pete_rallye wrote: I have a beam and lots of new bits but it's very much a work in progress at the moment! Plus it's destined for my race car once completed... That sounds interesting, care to elaborate on that at all? ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
pete_rallye
Not much to elaborate on really. Its just a standard beam I have stripped, painted, and bought new bearings and seals for! Figured the one on my btcc car has seen better days so am building this one up to swap onto the car, if it ever works again. Then I had a kid, garage roof started leaking etc etc and so I haven't got round to putting it back together yet! Ash, if you could, it'd be much appreciated, will be down south sometime! ________________________________________ Oulton Park in a BTCC 306 vid 1Oulton Park in a BTCC 306 vid 2 Lap of the 'ring |
So the Touring cars apart from camber and toe changes, ran a pretty much standard rear beam setup? Did they retain torsion bars etc?________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
pete_rallye
Post #35
Yep, although with the solution f shocks the tb didn't do much, but they do with the Penskes... there are a few other little additions to the beam also but nothing life changing. ________________________________________ Oulton Park in a BTCC 306 vid 1Oulton Park in a BTCC 306 vid 2 Lap of the 'ring |
Post #36
What thickness TBs and ARB are you running? Or is that classified? ![]() ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
pete_rallye
Post #37
Nah, currently 23.5mm bars and the original touring car ARB which is like a sleeved standard bar. I'm not sure why they did the ARB like this, I can only assume regs. But I am likely to change ARB depending on circuit/conditions, as I have a standard bar, hybrid bar and 30mm bar, plus this original btcc one. Might possibly change tb's too depending on circuits, depends a lot on if the shocks have the scope to cope with smaller bars in or not. Its going to be a lot of trial and error once it's up and running again, although a suspension place near me seems to be a firm believer that softer spring rates and thicker ARB's is the way to go, and has the results to back it up too. ________________________________________ Oulton Park in a BTCC 306 vid 1Oulton Park in a BTCC 306 vid 2 Lap of the 'ring |
Post #38
That rings true with a conversation I had with a guy from Aurok the Ohlins dealers, he was horrified when I told him I was intending to run 25mm bars and said with the right dampers there was no way I needed to run such a stiff TB. Interesting.________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
Post #39
What do you run up front? And do the touring cars use aluminium uprights or stock cast iron jobbies?________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
pete_rallye
Post #40
There's an adjustable blade style front arb with 2 different thickness bars. Hubs are standard iron jobs as per the regs. ________________________________________ Oulton Park in a BTCC 306 vid 1Oulton Park in a BTCC 306 vid 2 Lap of the 'ring |
pete_rallye
Post #41
Pages (2): 1 [2]
