displaying posts 1 to 25 of 95
Pages (4): [1] 2 3 .. last
Author Subject: Poly bushes-opinions please
JWP EFi
Turbo Legend!
i'm currently having a set of hard polyurethene bushes made up for the p bush bracket,
i have bought the ally p bushes for the berlingo/partner, pressed out the rubber bush and replacing the rubber bush with
poly also the front wishbone bush will be done the same way with a steel sleeve as per the standard setup
a friend of mine builds/repairs/maintains black cabs and machines bushes for a more permanent solution, as the soft
rubber s**te you get these days doesn't last, anyway he has told me that he barely has to change them now
i know the ride will be alot harder, i have driven a 6 that has had roller bearing conversion and i love the way they
transform the feel of the car
my only worry is the grade of the poly we are using is very hard and i fear they may break/crack
Posted 25th Jul 2012 at 21:57
Be interesting to see what they come out likeThumbs up
What are you worrried will break?
As people don't seem to report breaking RB bushes,or fixings,and they are metal to metalSmile
Posted 25th Jul 2012 at 22:22
JWP EFi
Turbo Legend!
well my mate that does the black cabs hasn't had a broken one yet, nearly 2 tons of taxi doing 1000's of hard miles
on our edinburgh pot hole ridden roads, but i'm just a bit paranoid tbh lol!
think they'l be ok, will put pics up once they've been made
cost wise, i bought 2 aluminium p bushes from Peugeot - £62 incl vat
polyurethene - £nowt!!
few beer tokens for my mate who machines them on his lathe
ps, i'm also in the process of welding up the rear mounts, just trying to figure out a way to make a jig
i must admit i never thought solid mounts/bushes were a good idea for a road car but i have driven a 6 with solid front
and rear and was really impressed, yes the ride's harder but not too hard that its unbearable
Posted 25th Jul 2012 at 22:36
davewagon
Hmm , sounds like an interesting idea, I'd definitely be interested if the price is right (and maybe after you'd road tested then for a few miles lol
Sound like a good compromise between standard and RB's
Dave
Team: Moonstone GTI-6™
Team: Working air-con™
ian7675 wrote:
Posted 25th Jul 2012 at 22:44
JWP EFi
Turbo Legend!
Dave
well i should have them on by the end of the week so will keep you informed as to how they perform
if they turn out to be any good we will make up a batch, for peeps to try.
the hardest bit is workin out the clearance fit, ie, they obviously have to be an interferance fit in the alumimium
bracket but the wishbone pin cant be too tight a fit or they'll wear out quite quickly i would have thought
Posted 25th Jul 2012 at 22:57
WTF?! you paid £62 for the bushes?! I paid £40 LOL
and if youre just tearing brand new ones apart just get the cheapos off ebay for half that again.
Posted 26th Jul 2012 at 08:54
Welshpug i keep meaning to ask you,
What part number do you use to get the posh partner van ones?
Ninja edit
Posted 26th Jul 2012 at 09:03
7057sam
eliotrw wrote:
Welshpug i keep menaing to ask you,
What part number do you use to get the posh partnet van ones?
+1
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 26th Jul 2012 at 09:30
smegal
I really would recommend just taking the plunge and getting rollerbearing bushes.
Ex SC-6
Now in a Megane R26
Posted 26th Jul 2012 at 09:40
Its a big plunge though Sad
Posted 26th Jul 2012 at 13:11
I wouldn't use the roller bearing ones on the road.
Posted 26th Jul 2012 at 13:52
smegal
Why not?
Ex SC-6
Now in a Megane R26
Posted 26th Jul 2012 at 14:00
too harsh, muchos tugging etc through the wheel, lots more noise.
epic crashes on catseyes!
Posted 26th Jul 2012 at 14:12
^^Sure that wasn't just the rest of the suspension setup? My rose joints are pretty comfortable tbfh.
Posted 26th Jul 2012 at 14:29
smegal
I'd disagree with that. The tugging of the wheel only happens on specific road conditions (lines worn in to the road so the car tries to tramline.
They do transmit a little more noise but nowhere near enough to rule them out.
IMHO they are the single best mod you can fit to a 306.
Ex SC-6
Now in a Megane R26
Posted 26th Jul 2012 at 14:31
I Thought the tugging was a normal 306 thing...
Oh well whatever is causing it atm will be replaced soon...
Cheers for the part number ! 3523 83
I assume you kept the other bushes the same?
Posted 26th Jul 2012 at 14:37
jord294
I'm with Craig ( smegal) on this. Rbs are one of the best upgrades you can put on a 6.
So much so, i've already bought a set for my china Thumbs up
Posted 26th Jul 2012 at 14:43
rest of it was 100% standard apart from the horrible toyo's.
Posted 26th Jul 2012 at 14:47
davewagon
Anyone tried the Vibrates ones that Miles is flogging??
Posted 26th Jul 2012 at 15:04
JWP EFi
Turbo Legend!
price update lol, they were actually £48, apparanty they couldn't
give me trade discount because they are special order
i originally bought 2 different sets off ebay but twice they sent
me the normal steel p bushes so i gave up and went straight
to peugeot.
Anyway my bushes are finally made, will be fitting tomorrow
Posted 26th Jul 2012 at 18:24
Depends how many miles you do on the road.
AgreedYes
They do give you great handling but if you use your car daily/to get to work they make it way too harsh IMOThumbs down
I had to get rid of mine as I was on the verge of selling the car due to the ride being so harshSad
Could be the combination of Konis/Eibachs and 205/45 16's all together that made it so hatefullDunno
But the RB bushes were what pushed it over the edge for sure.
Would highly reccomend them for a track car though,as they do tighten up the front end alotThumbs up
Posted 26th Jul 2012 at 21:43
I have driven a rallye on 205 45 and AST's and it didn't feel anything like a RJ wishboned standard wheeled rallye.
the AST'd car felt tighter but not harsh.
have you driven yours much since ditching them Kev?
Posted 26th Jul 2012 at 21:47
JWP EFi
Turbo Legend!
i have driven eddiebeanos car (totally solidified front and rear!) a few times and yes the ride is harsher
but imo its not unbearable, end of the day it depends how you want it but i'm defo going for similar setup
even though mine is my daily driver, for now anyway until i get a new family run about!
Posted 26th Jul 2012 at 22:03
Yeah,its my daily so covering circa 250-300 miles a weekThumbs up
Lasted circa 1000 miles on the RB's before they came off!Smile
Posted 26th Jul 2012 at 22:06
You can't judge that by driving a car once or twice.
I loved mine for the first week,but then it soon starts to grind on youYes
Weekend car/track car would prob be bearable,but not a daily driverNo
Posted 26th Jul 2012 at 22:09
