Author Subject: Rear Anti Roll Bar - What Steel Is It Made Off?
JimmyC379
Thinking of getting made my own rear anti roll bar here in Australia. Does anyone know the type of steel that is required to make them? I was thinking of using 4130 Chromoly steel would this suit? Or is it a certain spring steel?
Posted 25th Jul 2012 at 13:24
jeffers Forum Admin
PM ash mate, he's had the hybrid and 30mm ones made on here befor. He'll tell you exactly what you need! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 25th Jul 2012 at 13:45
JimmyC379
Cheers Jeffers!
Posted 25th Jul 2012 at 13:48
4140 in the T or U tempers should do you.
Posted 25th Jul 2012 at 13:56
JimmyC379
Hi Phil are the TB the same deal in materials tempers as the ARB's? Also do they both need to be hung vertical? They guy I was going to use can only lay the bars horizontal in the oven - the oven does not have enough height.
Posted 30th Jul 2012 at 13:44
metal steel Wink
Posted 30th Jul 2012 at 13:55
Pretty much, yes, vertical would be ideal, if you can't do that, I would support the length on a rack and let the splines hang, more important would be being careful with the quench.
Perhaps easier would be to find someone with carbide involute tooling and buy it and cut it in the 'T' temper straight from the mill?
Posted 30th Jul 2012 at 14:07
