displaying posts 101 to 125 of 167
Pages (7): first .. 4 [5] 6 .. last
Author Subject: Supercharged 6 owners
Post #101
m306 wrote:
Didn't someone crack their pipe work though with it all solid?
Always cracking my pipework when its solid! Wink
Posted 22nd Jun 2012 at 18:06
Post #102
LOL
Posted 22nd Jun 2012 at 18:23
spiky
Post #103
Minea not sollid completely, check my build and you will understand what I mean
What I mean is there is no where for the pope to get sucked in or anything like that
There is flex but minimal Smile, as it should be Smile
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 22nd Jun 2012 at 21:53
spiky
Post #104
Double post
MY YouTube Videos'
Posted 22nd Jun 2012 at 21:54
spiky
Post #105
As you can see here
MY YouTube Videos'
Posted 22nd Jun 2012 at 22:02
spiky
Post #106
And the silicone pipe on the left is solid as the inside has metal fitted inside Smile, so it won't squeeze or suck in
MY YouTube Videos'
Posted 22nd Jun 2012 at 22:03
ballardpaul
Post #107
Yeah mine was like that with a few silicones on the joins but could not get sucked in either.
Nissan 350Z (300 BHP)
Posted 23rd Jun 2012 at 00:17
Post #108
Mine was also like that on low boost...
Had quite a few issues with the running of the car when the silicone was being sucked in. As soon as I fixed this issue, the problems went away with stalling and the like. Wink
Posted 23rd Jun 2012 at 10:27
Post #109
Since putting the lightened flywheel and pully on mine stalls easy and sometimes cuts out if you drop the revs to quick while moving. No fault codes either :/ and ICV clean etc as well... Can only get worse when I finish charging it I immagine but will have to see. Only one place that can suck in on mine and I plan to sort soon either with rings or solid 45 degree pipe.
Posted 24th Jun 2012 at 23:10
Post #110
Armzs16 - The problem will be more pronounced with the lighter running gear as there is now less inertia to keep the engine turning. Yes
There are a couple of ways you can get round this problem. Yes
You can either change your driving style to suit the technical changes when slowing down and/or change to the later map (not sure if you already have this) which has been modified by Wayne to cut down on the stalling. Yes
By sorting out the place where you have a pipe collapsing under vacuum will also help out quite a bit.
Funnily enough, this stalling is a very common issue, although once I sorted out the collapsing hose, it never missed a beat after that or stalled, however people who have done the same, the problem still exists on most.
Posted 25th Jun 2012 at 06:19
midlife
Post #111
I'm a big believer that the stalling issue is due to the icv not being able to flow enough air so the vacuum slows the engine too quickly. Has anyone looked at either a bigger icv or even dual icv'sGeek
Cool
Team 330™Cool
Team "no front end or engine"
Posted 25th Jun 2012 at 07:21
Post #112
Wayne, the ICV is the issue. On a standard car, it controls the air flow in the plenum that's all.
On the SC cars, the same ICV has to control the air flow in the plenum, the intercooler and all the connecting pipework which is obviously a much larger surface area. Dual ICV's could be a solution, I don't run an ICV on my car as the setup is different but it's definitely an idea to think about the majority of the SC cars. Yes
Posted 25th Jun 2012 at 12:35
m306
Post #113
Oh so that explains why the larger high boost intercooler is considered worse for the stalling then.
Out of interest how much would it cost/ how hard would it be to get an icv setup that works on these?
supercharged China gti6 - Thu 16th Sep 1999 - sold
2010 megane rs250
Posted 25th Jun 2012 at 12:49
Post #114
It would be easy enough I would
Of thought.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 25th Jun 2012 at 15:39
Post #115
Why Is it not an issue on high boost?
chrisd306
Post #116
mine does stall sometimes, if you have been gunning it then stop for junction not all the time, never done it low boost with small icooler
when i had mine mapped at waynes, he just made my idle slightly higher so doesnt do it as bad
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 25th Jun 2012 at 15:55
Post #117
It is. Anything over 3k rpm on a high boost and dip the clutch it will stall. Yes
Posted 25th Jun 2012 at 16:27
chrisd306
Post #118
mine isint as bad as that Stan, its not that often that it happens
& Audi Q5 S Line
Posted 25th Jun 2012 at 16:36
Post #119
should be easy enough to fit another icv
Posted 25th Jun 2012 at 17:27
gilesy
Post #120
Has the pope ever been sucked off??? Shock
Posted 25th Jun 2012 at 17:33
Post #121
Not for years
Just the glory hole
Posted 25th Jun 2012 at 17:36
chrisd306
Post #122
he does the sucking of an its normally young alter boys
& Audi Q5 S Line
Posted 25th Jun 2012 at 17:53
jord294
Post #123
so do all the low boost SC 306s pull similiar power ????????
Posted 2nd Jul 2012 at 15:10
smegal
Post #124
Between 230 and 260 bhps
Ex SC-6
Now in a Megane R26
Posted 2nd Jul 2012 at 15:16
jord294
Post #125
I suppose that is down to how healthy and strong the engine is to start with Hmm
Posted 2nd Jul 2012 at 15:54
