Author Subject: B8's and standard springs
darrengti
Since fitting my B8's and 40mm H&R springs I think the car looks too low on cyclones.
I have some fairly new standard springs sat in the garage, will the B8's work effectively with standard springs?
My other option is to whack on my 17's which don't look so bad on a lowered car.
Also, what coloured paint dots should be on standard springs? (just to make sure I do have GTi ones!)
Posted 11th Jun 2012 at 13:16
jord294
Ditch the h&r and get some eibachs.
There is absolutely no chance that a standard spring would work effectively with b8s
Posted 11th Jun 2012 at 13:25
darrengti
But is the 10mm difference between the Eibachs and H&R springs going to be that noticeable?
Posted 11th Jun 2012 at 13:28
i would go eibachs, 30mm looks just right,
Only other alternative is springs from a xsara vts wihcih will drop it about 25mm
Posted 11th Jun 2012 at 13:31
anth
If you want to run standard ride height B6's are what you want i believe.
B8's are the same but designed for the shorter spring
darrengti
Now that's annoying! Hmm, I dont want to sell what I've already got in terms of dampers. And I also really dont think ........ (10mm) is much of a difference.
Man up and accept the new ride height?
Posted 11th Jun 2012 at 13:38
6waysforward
Or sell me the b8's Smile
Posted 11th Jun 2012 at 23:30
B8's and Eibach's Cool
Posted 12th Jun 2012 at 00:32
anth
Definatley.
Posted 12th Jun 2012 at 07:32
darrengti
Was that on 50 or 55 profile tyres Ash? Maybe mine looks over tyred now its lowered.
Posted 12th Jun 2012 at 20:58
50's mate
Posted 12th Jun 2012 at 22:51
what was your opinion of lower profile tyres ash?
ok?
too harsh?
Posted 12th Jun 2012 at 23:55
ok?
too harsh?
tbh on something like parada's or eagle f1's they are ok due to softer sidewalls Smile
Posted 13th Jun 2012 at 00:07
