displaying posts 1 to 25 of 28
Author Subject: Loss of brakes.
keep-3
Hi, I've just pulled over as I nearly have no use of my breaks at all. When I push the pedal down it sounds like its full of air. Can any one give me any advice?
Posted 28th May 2012 at 00:17
darzmat
check fluid level
check for leaks at the calipers and servo.
did it just suddenly go?
maybe the servo itsself has failed
Posted 28th May 2012 at 00:19
midlife
Could be a split flexi or an overtightened bleed nipple has popped out, good luck
Cool
Team 330™Cool
Team "no front end or engine"
Posted 28th May 2012 at 00:23
keep-3
The pedal didn't feel quite right last night but it was still stopping the car but I've just left my girlfriends and had to pull in after about 10 mins as it feels like I have no breaks I'm about 15 minutes from home but it's deffintly not safe to drive.
Posted 28th May 2012 at 00:28
keep-3
Just noticed the pedal is stiff once the engine has stopped but when the engine is on the pedal moves easily all the way to the floor.
Posted 28th May 2012 at 00:36
As said, check the reservoir level and leaks around the car ASAP.
When the engine is switched off is the pedal stopping at it's normal point, or can you with a bit of force push the pedal all the way to the floor but it is difficult to do so?
Posted 28th May 2012 at 09:30
Tiredness kills. You did the right thing pulling over for regular breaks.
  • Posted 28th May 2012 at 09:31
    Laugh my ass off Quality...
    Posted 28th May 2012 at 09:32
    Laugh my ass off
    andrew315rawson@live.co.uk
    Moonstone phase 7 gti6
    Posted 28th May 2012 at 09:35
    Sounds like the air is leaking out of the servo, probably needs a new servo, may be cracked somewhere where.
    Posted 28th May 2012 at 12:29
    I'm not so sure Andy, just the very nature of the description of the fault sounds like a fluid issue. Yes
    He said the pedal was a little spongy the night before indicating to me that there was a slight leak then and it was sucking in air. Now the pedal goes to the floor with the engine running, the servo sounds like it's doing its job and giving plenty of braking pressure to a system which has a leak...
    Posted 28th May 2012 at 12:33
    Does the servo make the hissing noise when it's really low on fluid?
    I was just going on the hissing air noise.
    Posted 28th May 2012 at 14:24
    How did you get home in the end?
  • Posted 28th May 2012 at 14:26
    keep-3
    Not managed to have a good look but got the car home and there is a leak somewhere near the rear passenger wheel. Will have a proper look when I finish work.
    Posted 28th May 2012 at 14:32
    Glad you managed to find the issue, I suspect it's either the caliper or the flexi has sprung a leak. Yes
    Posted 28th May 2012 at 16:31
    keep-3
    Found the problem...
    part of the rear passenger brake line which the flexi connects to.
    keep-3 has attached the following image:
    Posted 28th May 2012 at 21:40
    New brake pipe time then. Yes
    Posted 29th May 2012 at 11:44
    keep-3
    Its looking that way. Doh
    Is there anwhere to buy these from cheaper than peugeot? cant find them on euro cap parts or GSF.
    The other thing is im missing the compensator which the mechanics next to my work removed when my car failed its mot 2 years ago because it was seized.
    Looking at the price of them, i dont think I'll be refitting one as I havent noticed it effect the braking at all but looks like their will be a bit of bending the pipe lines in-situ to match what they've done.
    Posted 29th May 2012 at 13:28
    smegal
    Just measure the pipe then go to any motor factors. They usually charge £1 per foot and £1 per end.
    Ex SC-6
    Now in a Megane R26
    Posted 29th May 2012 at 13:30
    keep-3
    Thanks, That sounds like it will save me a few bob! They're roughly £15 each from Peugeot.
    Anyway the sooner I can get this fixed the sooner something else can go wrong... LOL
    Posted 29th May 2012 at 13:54
    Rich E Forum Admin
    With the compensator completely removed you will permanently have a 50/50 distribution of braking force between the front and the rear, which will compromise overall braking performance and will lead to the rears locking before the fronts.
    If it had seized in an open position then that might be why you haven't observed a difference, but replacing it will improve your car's braking. Alternatively, from where you are now you could fit a phase 3 ABS unit which has EBD, and manages brake force distribution on the fly. (Phase 3's don't have compensators fitted.)
    Posted 29th May 2012 at 14:00
    keep-3
    Im not sure how it seized to be honest they just told me when I went to collect it that they had taken it off to save me the cost of replacing it and that I didnt need it.
    Would it be simple enough to fit an phase 3 ABS, Im not entirely sure what they did to the brake lines although I took some photos of the underneath which I'll post. They look like theyve been bent in all sorts of directions.
    Posted 29th May 2012 at 16:00
    keep-3
    keep-3
    Posted 29th May 2012 at 16:01
    jord294
    Bloody cowboys!!!
    I'd be right p**sed off if a garage did that to my car (it's one reason I do as much work on my cars as possible)
    A bit of wd40 would of freed off the compensator. They do tend to stick/seize, but it's an easy fix
    Posted 29th May 2012 at 16:23
