Author Subject: help required
mike rallye
i am in the process of removing my old axle for a new one. but when i bought my scorpion exhaust there was some sort of gasket between the centre pipe and backbox,is this normal? as the joins on the backbox look excatly the same as the centre pipe.
i have also noticed there is a pipe inserted on the centre pipe,which i dont think should be there either? he is couple of pics
any info and replys would be grateful as i need this back together by saturday,and am unsure what to do
cheers mike
Posted 24th May 2012 at 21:46
yes theres a ring gasket between the 2 olive ends Smile
Posted 24th May 2012 at 22:37
mike rallye
ok cheers for that ash, can i get new from europarts or is it looking like demon tweeks job?
Posted 24th May 2012 at 22:49
Try scorpion direct ?
Tweeks may do them as well ?
Posted 24th May 2012 at 22:57
demon tweeks jobbie
atterz
Is this the same for a standard exhaust, as i cant stop the mid to backbox joint leaking at all!
owain wrote:
Posted 24th May 2012 at 22:59
nope.
Posted 24th May 2012 at 23:20
To be honest I'd use that broken olive with plenty of paste once it was all clamped up it wouldn't leak Thumbs up
Also proper pug clamp are way better than s**tty after market clamps Thumbs up
Posted 24th May 2012 at 23:23
jeffers Forum Admin
A decent moter factors can supply them rings, couple of quid at the most, i bought one from mine earlier this year. I f you get stuck shout up and il pick one up and send it out! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 24th May 2012 at 23:40
atterz
Any idea how to stop a standard mid to superspring backbox leaking? Ive used massive amounts of paste already!
Posted 24th May 2012 at 23:49
woody.
Chop and weld? Or backbox off and pretend you have a magnex and chill out down mcd's with your homeboiiiiis Thumbs up
Posted 25th May 2012 at 02:30
mike rallye
cheers for the replys guys,and if i get stuck jeffers i will let you know Smile
Posted 25th May 2012 at 08:43
no paste and a new clamp from pug.
or fit the original backbox and stop being a chav Razz
Posted 25th May 2012 at 09:59
