Author Subject: What is the best order to fit the bits on front in your experien
Well, Ive purchased almost all of the stuff i need for a full suspension re build, my floor is covered in parts.
I've tried to set out to make it as painless as possible.
But a lot of you will have way more experience than me with stuff like this so i thought I'd ask.
The parts i have are as following:
(Again ive set out to make it all as quick as possibel by getting Fully assembled parts or things that I can assemble off the car.)
I will have Struts that I will build/or get built up if im stuck off the car while its still on the road(IE mounts, spring cups springs bumpstops dustcovers and dampers)
I will have droplinks and TRE's
A lower strut brace
Wishbones built up with all bushes and ball joints on.
What order Would be best with the least hassle.
I was thinking.
Remove old struts
Fit new ones
Remove wishbones while a mate supports the hub so the driveshaft doesnt fall out the gearbox
Fit new wishbones
Fit strut brace
Tighten the bolts up for them
Tighten balljoint bolt
then all the easier stuff like droplinks and tre's
Tighten wishbones again while its on the ground
Get it tracked
Is there a more logical order than that?
How long should it take? (both sides)
Posted 24th Apr 2012 at 13:04
strip down completely then rebuild it up so shocks and springs on first,then new bottom arms,then droplinks and tres.
and while your at it id change the box oil as no doubt you'll disturb the shafts and have a leak on your hands
should take anywhere betwen 3-6 hours id say all dependant on how good you are with the spanners and how siezed stuff is
Posted 24th Apr 2012 at 13:10
Be careful with the shafts while they aren't suspended inside the hub. You risk damaging the driveshaft seals.
As Ash says, change the oil while you are there and perhaps do the seals anyway for how much they cost.
  • Posted 24th Apr 2012 at 13:17
    See I dont know why but that s**t scares me. Im happy thinking about playing about with all the rest but shafts alwasy sounds like a MASSIVE pain from what i read on here. Im comfortable changing the gear oil as i've done that before (very recently) and it was a little girls job.
    But driveshaft seals :S
    Am i being a pussy?
    Posted 24th Apr 2012 at 13:24
    Well you would have to remove the intermidiate bearing from the O/S to get that shaft out to do the seal that side. May be classed as more hassle than you can be bothered with, but isn't difficult. Was purely a suggestion based on if several K down the line they leaked or you knocked them and put it all back together, you would have to drain your oil, remove the ball joint again etc etc. For ~£10 of seals while you are 2 intermediate bearing bolts away from doing them while it's apart.
  • Posted 24th Apr 2012 at 13:37
    gilesy
    If you are in London and need a hand doing this give me a shout
    Posted 25th Apr 2012 at 11:17
    Cheers for the offer that would be great of you, however i dont have the space in london, I was planning doing it in wales at my parents over a week off
    Posted 25th Apr 2012 at 14:41
    6waysforward
    Sorry for the thread hijack but i am 20 miles from london and i could do with a hand on some stuff if your in the mood for getting dirty gilesy LOL
    Posted 25th Apr 2012 at 20:46
    Well feed me bacon sarnies and tea and i'll help out mate
    Posted 25th Apr 2012 at 20:47
    gilesy
    That's a deal if you are the person in your avatar LOL
    And I'll work for bacon sarnies too!!
    Posted 25th Apr 2012 at 20:48
    6waysforward
    Yeh thats me in the picture but its a couple of years old now and i have got a little fatter, had a sex change and some hair loss but i still look good in those little white panties Smile
    Doing a cyclinder head change, ream beam swap and a rich w billet fly wheel over the next few weeks so i will get a full pig Thumbs up
    Posted 25th Apr 2012 at 21:05
    I may have to take you up on that offer if possible mate as it would be a HUGGGEEE help
    Posted 26th Apr 2012 at 15:57
