displaying posts 1 to 25 of 28
Author Subject: engine tapping
barnettjd77
This is the second gti-6 i have owned that taps from time to time, just wondering if the oil additive is complete bollo**s or does it actually make a difference? thanks.
A red rallye in progress!
Posted 18th Apr 2012 at 18:54
6waysforward
They all have a random tap every now and then but if its happening everytime you thrash it then your oil could be to hot or not enough oil pressure.
Not tried additives tbh.
Posted 18th Apr 2012 at 22:17
barnettjd77
Ah right, well sometimes when it's cold but then stops after couple minutes.. how can i tell or sort oil pressure?
Posted 18th Apr 2012 at 22:52
aaron6
Mine does this. Just a worn lifter. Would'nt bother worrying about it. Smile
Posted 19th Apr 2012 at 00:11
barnettjd77
I won't bother then though i ecpect a oil change/service for whole car wouldn't go a miss right now, and the cambelt LOL
Posted 19th Apr 2012 at 10:38
aaron6
Mine getter tappier when nearing an oil change, lets you know when to do it though which is nice... Smile
Should get quieter with fresh oil. Only use a genuine pug filter though as they have a non return valve in. Don't let the cambelt snap our slip either our else you will have a permanant tapper... Wink
Posted 19th Apr 2012 at 11:20
barnettjd77
Yeah they can be helpful LOL mine is due very soon I reckon.
Ah I see it's not a genuine filter on now, so will have to order one up Yes
Posted 23rd Apr 2012 at 08:47
aaron6
Might sort out your tap to a degree as the oil won't drain out the filter giving the pump more to circulate. Smile
Keep us posted what happens on oil change with genuine filter. Smile
Posted 23rd Apr 2012 at 08:55
Its not so much that the pump has more to circulate but the fact that there is oil stored in a higher location which can make its way to the head much quicker. If you have lazy tappets the hydraulic lifter treatments are very good. Just make sure you put it in just before an oil change so that once it has done its job you can change the oil and filter for new and hopefully have no more problems. Smile
Posted 23rd Apr 2012 at 10:16
aaron6
I stand erected... Cheers lover... Wink LOL
Posted 23rd Apr 2012 at 10:52
Would you suggest something like Wynn's? Or is there a preffered brand?
  • Posted 23rd Apr 2012 at 10:56
    aaron6
    I used wynns in my old one. Worked okay like. Smile
    Posted 23rd Apr 2012 at 11:18
    aaron6
    Just a quicky, it may also be worth looking to see if a plug is tad loose, had this a few months ago, it caused me an intermittent tap. Albeit, after a couple of weeks it developed into what sounded like a genuine tapper. Its free and thus worth a look.
    Posted 23rd Apr 2012 at 11:21
    Good point about loose plugs Aaron. Yes
    I normally use Wynns products and they seem to be of high quality. I would recommend them. Smile
    Posted 23rd Apr 2012 at 12:06
    Wynner! Thumbs up Thanks
  • Posted 23rd Apr 2012 at 12:07
    LOL
    Nice pun. You're welcome mate. Smile
    Posted 23rd Apr 2012 at 12:21
    barnettjd77
    Ah right i shall have a look at plugs first off then. You mean get some wynns and chuck it in the old oil before i change filter ect?
    i shall keep you posted on how it goes Smile
    Posted 23rd Apr 2012 at 12:27
    aaron6
    Yeah mate, check the plugs. If all are tight bung in some wynns and yes, keep us posted on this thread mate. Smile
    Posted 23rd Apr 2012 at 12:30
    Exactly that. Put it the old oil first and then run the engine for about 30 mins at 3000rpm I believe it is (will state exact figures in the instructions) and then drain oil, change filter and refill with new oil. Smile
    Posted 23rd Apr 2012 at 15:22
    Usually the plug closest to the cambelt.
    I'd also use Total Quartz 9000 fully synth from Peugeot instead of a semi synth as original. Mine always seemed to run better on it - was recommended by Mr Chambers Wink
    Also can be pretty cheap if you buy it in 20L tubs - £40 odd iirc
    Posted 23rd Apr 2012 at 16:16
    barnettjd77
    Cheers stan Smile shall have a look at it when it stops pis*ing it down,
    bloody car is more hastle than it is worth atm LOL
    And shall look into get 20L tub of it then as i tend to get through some!
    Posted 23rd Apr 2012 at 16:19
    Speak to Warners Peugeot in Tewkesbury about the tub, if they don't deliver then try to get your local Peugeot place to price match. Or have a look on Opie Oils as they often have good deals.
    Posted 23rd Apr 2012 at 17:01
    barnettjd77
    I shall do cheers adam Thumbs up
    I have checked the plugs and they are resonably tight though the second one in from the cambelt side was a tad loose if that would make any difference? Dunno
    Posted 25th Apr 2012 at 14:35
    i'll just be a sticky lifter! mine used to give light taps every so often,..
    in the engine rebuild last year Pugjim squeezed the crap out of them iirc and made them like new again! Smile
    of cause the 1st time they were used again they sounded like a bag of s**te I think the look on my face said it all when jim reassured me they were going to be noisy and that was normal until they filled up with oil again LOL
    you'd know if you have a taper it sounds like a sewing machine :/
    Posted 25th Apr 2012 at 14:44
    barnettjd77
    Oh right it is bloody annoying though ha,
    I for sure am not gonna think about getting it rebuilt only just started to tart it up.. clean things and paint covers ect Thumbs up
    I use to have a blaze 6 and that was constantly tapping.. until i tapped it into a telegraph pole LOL
    Posted 25th Apr 2012 at 14:51
