displaying posts 1 to 25 of 87
Pages (4): [1] 2 3 .. last
Author Subject: 1.6 conversion to the 2.0l gti6 running crap
Teshboi1988
need to know whether the cam pulleys the inlet n outlet are the same? if not how can u tell difference between 2? my guy thinks maybe the cam pulleys where mixed....
phase 3 Hatchback V reg 5Door GTi6
Posted 10th Mar 2012 at 10:29
Std pulleys are the same I think ?
I'd check you idle control valve on the inlet manifold first Thumbs up
Posted 10th Mar 2012 at 10:32
Teshboi1988
idle control valve... have u got a pic of where the pipe goes to and from.... im doin a conversion from a 1.6 and a lot had to be changed..
Posted 10th Mar 2012 at 10:43
Pulleys are the same. Yes
ICV pipe goes from the main intake pipe (where the filter is) to the ICV itself.
Posted 10th Mar 2012 at 10:55
Teshboi1988
il got no standard air box filter... got engine from jst the throttle body. is that were u mean
Posted 10th Mar 2012 at 11:10
Hmmm maybe its missing and that's your problem?
It's attached the throttle body and is kinda underneath the cable. Has a little pipe connected to it.
Posted 10th Mar 2012 at 11:27
Look at your throttle body the icv I on the back of that ? It's black and held in with 2 m8 or m10 bolts. You can change it or try cleaning it ?
Posted 10th Mar 2012 at 17:35
Teshboi1988
yea i had cleaned ICV. bt still same. its responsive wen u push accelerator. bt running poorly...
i fitted wossner forged pistons
Posted 12th Mar 2012 at 07:02
Teshboi1988
right heres the crack
i had a 306 1.6. gearbox kinda exploded...
so looking on ebay found a guy who sold me a gti6 engine conversion kit... ecu, loom, gearbox etc...
so then i converted to the gti spec....
suspension brakes exhaust, subframe steering rack etc
whilst i had engine out i thought id wack some wossner pistons in, n do the whole shabang n replace all the bits that wear..
bigends smallends
stem seals..
new gaskets
new crank n cam seals
cambelt
auxbelt
had engine block bored out
had head skimmed
flywheel skimmed
valves lapped
new clutch (proformance)
everything has been cleaned
and serviced it
got ecu programmed to key...
n boom it started...
but.....
its running shit, its idling at 20 then slowly dies n cuts out....
HELP
Tesh
Posted 12th Mar 2012 at 07:06
Another thread and you still havent answered my question about the pistons!
Roll eyes
Posted 13th Mar 2012 at 17:03
Teshboi1988
sorry. wossner forged pistons
next question i need to no whether the fuel pump needs to be changed? from the 1.6 to the 2.0l?
atm it is fueling it. but my mechanic thinks it may b overfueling??
Posted 13th Mar 2012 at 21:16
Teshboi1988
or the timing is out... but going to redo timing 2mz... its out a tooth that y it may be running s**tty..
if the timing is out wood that be the cause of fuel and smoke dripping out throttle body?
thanks
Posted 13th Mar 2012 at 21:30
Get a new mechanic?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 13th Mar 2012 at 22:14
Teshboi1988
so wot yes no??
Posted 13th Mar 2012 at 22:17
Fuel and smoke dripping out of the throttle body...Erm?
By fitting the Wossner pistons have you altered the compression ratio?
Posted 14th Mar 2012 at 00:50
Teshboi1988
yea they high comp pistons. so how do i go about altering the compression??
Posted 14th Mar 2012 at 07:55
Teshboi1988
does any1 no whether the fuel pump gta b changed from the 1.6 to 2.0l? i no the fuel lines had to be changed. done that... bt what bout pump??
Posted 14th Mar 2012 at 08:03
Yes, you should be swapping the fuel pump over to the GTi-6 one. Yes
When you say the pistons are high compression ones, what compression figure do they actually give? The standard pistons give a compression ratio of 10.8:1. If the pistons you have installed have altered this then the engine's mapping will need to be changed to accomodate this.
Posted 14th Mar 2012 at 08:49
no, same fuel pump.
Posted 14th Mar 2012 at 09:10
no, same fuel pump.
Is it?
I stand corrected...Yes
Posted 14th Mar 2012 at 10:39
yarp Smile
only the SPI phase 1's had a different pump.
Posted 14th Mar 2012 at 10:55
yarp Smile
Learn something new everyday. Wink
Posted 14th Mar 2012 at 10:56
Teshboi1988
ok kool thanks....
right so i need it mapped right ok...
hmmm... how much isit roughly for it to get mapped..
and just a curious question
whats the advantages and disadvantages of lowering or raising compression??
Posted 14th Mar 2012 at 20:06
anth
You need to get in contact with chip wizards to have these ecus mapped.
Posted 14th Mar 2012 at 20:17
anth
And to answer you other question.
High compression is for na engines the higher compression the more efficient the mix of air and fuel become which produces more power.
Low compression is for turbos- your throwing compressed air into the chamber.
That's the basic explanation anyway someone else could probably tear that apart Wink
Posted 14th Mar 2012 at 20:21
