displaying posts 1 to 25 of 37
Author Subject: Increasing steering feel
Right then I know its not a 306, but the front suspension setup is fairly similar, the main difference being you can camber adjust at the hub. The front wishbones are attached to a subframe that is square rather than C shaped and is bolted to the body by what look to be rubber damped bolts.
At the moment i've not got a great deal of steering feel using ContiSport 3s - 225/45/17 on standard wheels.
Can I make it better by changing:
1. Spacing subframe front/back and therefore changing wishbone angle
2. Spacing the track rod ends
3. Changing from the standard ARB (uses IPD solid links)
4. Was better after spring rate went up but i'd prefer not to go higher
5. Tyre pressures seem to make little odds and the Contis are the best for feel so far
6. Increasing rear ARB thickness or rear ride height
7. Reducing the PAS pressure somehow - i've driven it without PAS and it didn't make much odds.
8. Try to remove the rubber in the subframe - not simple though I think.
I know it might seem strange but people don't tend to improve the suspension feel on these, just add more power. There is a load more to be had by making it corner better, in fact a diff would be on the cards before more power I think now. Therefore the volvo forums can't really help at the moment!
Posted 20th Feb 2012 at 13:40
First things first, is the rack rubber mounted, or solid to the subframe?
Posted 20th Feb 2012 at 13:48
Oooooh hadn't thought of that. Don't know right at the moment - its the kind of bo***cks they'd do though.
Wheres the welder gone... Devil
Posted 20th Feb 2012 at 14:30
Assume that it isn't - doesn't look it from Haynes, but have asked the question.
Certainly the older cars are solid mounted but aren't very well attached, as in they flex and come loose. Hoping to find out about mine soon.
Posted 20th Feb 2012 at 14:36
pics on tinterweb looks like 4 studs direct to the subframe.
Are there rubber bushes in the steering column?
subframe would probably quite involved but not massively difficult to sort, if you know a machinist...
bigger pulley on the pas pump maybe?
Posted 20th Feb 2012 at 15:01
People do polyurethane the front subframe mountings to make them stiffer. No one has re-made the bushes though and bear in the mind the engine is basically entirely bolted to it so I don't want loads more noise. Its not like you can physically move the subframe with a bar with it attached!
Posted 20th Feb 2012 at 15:28
bigger bar Razz
Posted 20th Feb 2012 at 15:40
Have you tried the Mitchelin pilot sport 3s, in the highest speed rating?
Stick like shit on a Blanket
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 20th Feb 2012 at 17:12
Yes, I'd say the contis are the same if not better. Bit cheaper, but not 100% on the wear just yet. Both are awesome!
Posted 20th Feb 2012 at 18:38
The wear on the mitchelins is pretty rapid LOL, we go through loads on the mondeo.
Posted 20th Feb 2012 at 18:59
Really? It took me 9k to kill mine part worn on 4-5mm.
Posted 20th Feb 2012 at 21:54
Has more torque than an R, +30Lbft on overboost too.
heavy engine in the nose maybe?
Posted 20th Feb 2012 at 22:13
Yeah it is very heavy on the tyres, But I wouldn't change them as they perform really good, it does have piles of torque though and weighs 2 ton apparently.
Posted 21st Feb 2012 at 02:16
1550 iirc, so not too dissimilar, I think the B5254 engine is quite light for its capacity being all alloy.
Posted 21st Feb 2012 at 11:13
So back on topic...
Posted 21st Feb 2012 at 13:07
Tried a little less wheel offset?
Posted 21st Feb 2012 at 13:22
49mm offset i think Shock
Posted 21st Feb 2012 at 13:40
49mm indeed!
P1 V70 wheels are 43mm offset. Otherwise they don't seem to be easy to get wheels for.
Posted 21st Feb 2012 at 14:33
xsara vts sterring rack? Whistle
Posted 21st Feb 2012 at 14:35
5x108 isnt it? same as a big pug LOL
looking at the 407, that uses similarly deep offsets around 44, apart from one ET35 7x17 Steel wheel.
will 16" wheels fit? 607 uses an ally spare wheel afaik, 7X16 ET 39
Posted 21st Feb 2012 at 14:50
They are 7.5" wide and yes 5x108 - oh really same as large Peugeot?! Hmm...
The brakes are 302s at the moment, but only one type of Volvo 16" fit over those, some mega strong Police spec things. Also tyres are cheapish in 225/45/17 so I don't want to change in a hurry.
Posted 21st Feb 2012 at 15:21
would think most shallower offset 16+17"s would fit quite easily.
same centre bore!! 65.1mm Shock
quality wheel offset+centre bore linky
Posted 21st Feb 2012 at 15:26
I can never remember with offset how it works. If I went to a 20mm offset i'd need 29mm spacers to make it the same? Or is it the other way round?
Posted 21st Feb 2012 at 15:29
yup bang on as were talking positive offsets, larger the number closer to the inner wing the wheel goes, smaller number same width = wheel closer to outer arch
Posted 21st Feb 2012 at 16:00
I don't know if they're still the same but they used to run a lot of negative scrub on the old Volvo's, so you might not need much to push it back toward neutral.
You can measure it from the strut angle.
Posted 21st Feb 2012 at 16:15
